Question about Haier hwr10xc6 Air Conditioner
Haier AC Problem Troubleshoot.
I recently got a new airconditioner. The fan works on it, but the compressor does not engage. It draws alot of power momentarily, then shuts off. I also bypassed the thermostat, yet the compressor still doesnt start. When the air conditioner tries to start the compressor, the voltage on the power line drops from 115volts to 60volts, it seems like its drawing alot of power when its trying to start the compressor. The air conditioner i bought is a basic model, with mechanical control.
  • 400 Answers
Your compressor is faulty, you could test this with an ohm meter or a mega tester to confirm that you have continuity between windings and earth or that the insulation on one of the start or run windings has overheated and broken down. Before you give up though, you can try to change the compressor capacitor, with same rated microfarad capacitor.
Posted on Mar 05, 2009
When I recently turned my fan to either defrost or heat/defrost the engine acts like it wants to stall and the AC indicator begins to blink. No other heater setting creates this problem. After blinking...
THE DEFROST SETTING CALLS FORE THE AC COMPRESSOR TO ENGAGE TO DRY THE HUMIDITY. THE CAR IS STALLING PERHAPS BECAUSE OF THE LOAD PUT UPON THE ENGINE BY THE ENGAGEMENT OF THE AC COMPRESSOR. THE COMPRESSOR MAY BE LOCKED UP
Mar 08, 2015 | AC Cars & Trucks
No electrical power to AC Compressor. The switch light comes on in car when AC power button is turned on.
  1. Check if air blows with the fan setting turned to high.
  2. Check that the radiator cooling fan engages when the A/C button is pressed.
  3. Locate the compressor.
  4. Turn on the A/C.
  5. Check if the compressor's clutch has been engaged.
  6. If the clutch engages, the fault is elsewhere.
  7. If the clutch does not engage, check for power to the clutch.
These steps might help find the problem.
Sep 16, 2013 | 1997 Ford Escort
AC does not work 2000 Ford windstar
first thing check AC compressor fuse.the AC compressor clutch should engage when you turn on airconditioner if AC compressor dont come on and fuse okay compressor clutch is open or low on refrigerant you need check your AC refrigerant low pressure side and high pressure side need a manifold gauge set. best let garage check out AC system could need system recharged or could have leak in the system.
Jun 19, 2013 | Cars & Trucks
Compressor and fans do not turn on until rev engine
I passed this question the first time I read it, so I will take a stab at it now.
The fans don't come on until the compressor has pumped the freon pressure up to say 150 or 200 psi. And the compressor clutch has to have voltage to engage the clutch.
I wonder if the clutch is going and needs 14 volts instead of 12 to engage ? Or the relay that powers the clutch ?
Speeding up the engine would increase voltage from the alternator.
This is assuming the serpentine belt is tight and everything else is working correctly.
I think I would swap the relay with another and put a meter on that circuit to the ac clutch to see what it takes to engage it.
Jul 24, 2012 | 1992 Buick Regal
AC (57915.622) fan hi & low working, compressor
Here is a tip about troubleshooting your air conditioner...
There are many things that can cause your air conditioner not to cool...
AirConditioner Trouble - Review the Possibilities
heatman101
Jul 14, 2011 | Heating & Cooling
My 1991 isuzu trooper heater blower fan is not working, nor when i turn it to the airconditioner the compressor does not engage. i checked all the fuses except the ac relay fuse block, what could the...
if the lower fan speeds dont work but the fastest speed does the heater fan resistor block needs replacing. If the highest fan speed doesnt work leave it on there and check for power at heater blower fan, if power is on one wire and the other is an earth the blower motor fan needs replacing. Use a normal globe test light to check this. If no power on any wires to fan go back and check all fuses in car and under bonnet with same test light. If fuses are ok possible open circuit wire to fan.
Jan 13, 2011 | 2004 Isuzu Rodeo
The engine makes a whirring sound when the air is on. The sound is quite brief, but when it is occurring there is power loss from the engine, the sound is very rythmic in its occurence.
The A/C compressor robs alot of Horse power from the engine...
Defrost will engage the compressor too...
The whirring may be the coolant fans engaging (drawing air accross the A/C Condenser ).
All of this falls into the ' normal opporation ' catagory , and should not warrant any worries.
Sep 25, 2010 | 2000 Ford Focus
My Duo-therm Brisk-Air by Dometic rv ac wont cool.(The fan runs )
Usually just listening closely will give you a rough idea where to look for problem. When you have the fan on and switch to cool, (with temperature turned down low obviously) do you hear any type of "moaning" sounds from AC unit, or see lights in RV dim slightly indicating that compressor is trying to engage? Is the breaker tripping when compressor tries to engage? Do you hear a "click" from AC unit when switched to cool? If none of that happens, then I'd start thinking thermostat, or compressor relay. Normally if it's a faulty capacitor, the compressor will try to engage but will make a "moaning sound" and usually trip the breaker due to excess current draw. Someone experience in electrical should be able to test relays etc, but whoever does work on it, should be aware that those capacitors, as well as hydro in general are very dangerous to work with. The ("zap",- Shock) that you can experience from a capacitor or hydro, can be fatal.
May 27, 2010 | Dometic Rooftop RV Air Conditioner
I have an airconditioner a Kelvinator KSR20C Split system
Your condensor fan motor has more than likely gone out. This fan should run at all times when the unit is on. Since the fan isn't working then the motor must have gone out.
Dave
Nov 16, 2009 | GE Zoneline AZ38H12DAD Split System Air...
During low voltage period window AC compressor shudders and kicks off, but fan runs, when voltage returns normal compressor runs.
low voltage issues causes higher amp draw and equipment to run a lot harder. whats causing the low voltage problem to the equipment? high amp draw of the compressor could be causing it to overheat and trip until the compressor physically cools down.
May 27, 2009 | Dometic Rooftop RV Air Conditioner
Haier hwr10xc6 Air Conditioner Logo
464 people viewed this question
Top Haier Heating & Cooling Experts
Tom Chichester
Matt
Matt
Level 1 Expert
Vincent Schnittert
Vincent Schnittert
Level 1 Expert
Are you a Haier Heating and Cooling Expert? Answer questions, earn points and help others
