Question about GE JVM3670 Microwave Oven
Front vent fell off
The front vent fell off..looks like a piece broke up..and the front/top vent just fell off..the plastic piece behind the vent will need to be replaced.. Can this easily be done..can I buy the part/s and do it myself?
  • 5,911 Answers
This should be a very easy fix. I assume you are talking about the plastic vent grill on the top of the oven above the door. There should only be a couple of screws holding it in from the top. The grill then should tilt out from the top first then from the bottom to remove. Since you said that it had fallen off, it sounds like the tabs where the screw holes are have broken off. This is a common problem. You can buy the part by ordering from the manufacturer, or from most repair websites. All you need is the model number from the microwave. Good luck.
Posted on Jun 19, 2007
SOURCE:
I have a GE Microwave Model # JVM133OBW. The interior light went out. How do I replace it?
Typically you remove the vent cover just above the door that goes all the way across the top of the unit. There are 2 or 3 phillips screws in the front of it, or on top. You take out that plastic vent grill and look behind it. There is another screw in the center that holds down the panel the light bulb is held in. So, remove that screw and lift up on the panel holding the bulb. Make sure you unplug the Microwave before you take out the bulb. Sometimes the glass will seperate from the base and the wires inside will twist together and blow up your circuit bosrd. SO UNPLUG FIRST!!! On that top grill some have the screws on the Top of the unit, but you just have to find the screws that hold that top front grill in place. Some of the grills have to slide to the side a bit to come out. I am sorry I do not have exact instructions on YOUR machine. But it really is not that difficult. It could be a screw in type bulb or a small push in Halogen. Good Luck
Oct 16, 2017 | GE Microwave Ovens
I have a Panasonic Dimension4 Microwave/Convection (the genius) and the push button door opener malfunctioned I think the bolt in behind fell off and it is disconnected and is it fixable thank you
Unfortunatley Panasonic has discontinued a lot of those parts. All of those pieces are plastic. I have actually repaired a few of those release buttons and levers by modifying them and puttng a bolt where the plastic tab or nub sticks out. Basically it is a pivot point and it has to be in the right spot and supported. One hint, I have NEVER had success with any kind of super glue or plastic cement on that kind of plastic they use in there. Thats why I modify it and bolt in something to make it last. Fabricated to fit. Not easy. It is a shame they dont still have parts for them they were such great machines. Sometimes the tabs on the ends broke off or sometimes it is the end of the lever that breaks. Have to unplug and take off outer cover and go look behind the front panel at the door parts. Good Luck!!
Oct 01, 2017 | Panasonic Microwave Ovens
I have a Panasonic Microwave Model NN-SD277. How do you access the workings of the door opener button? It is broken so the door won't open.
You have to remove the outer cover, the plastic lift levers are behind the door open button / lever. Caution!, panasonic discontinued a lot of those and getting a replacement part can be hard at times. Dont waste your time trying to glue it. After watching people try to glue or epoxy those cheap plastic parts for so many years. I have to warn folks to not waste your time trying. .It will not hold!!!! Look online and try to find a replacement part somewhere. It will be one of two parts. the door open button you push, or the door open lever that the front button pushes against. If you unplug the unit and remove the outer cover simply look behind the front control panel and when you push the button to open the door you will see where it is supposed to lift to open the door. The broke part is your problem, may be a piece laying in the bottom.
Aug 14, 2017 | Panasonic Microwave Ovens
How do i replace the light bulb in my maytag microwave oven. the bulb broke in the socket.
The cooktop light bulb(s) is(are) located on the underside of the microwave oven, and is(are) replaceable. Remove bulb cover screw, and open the bulb cover. Replace bulb, close bulb cover, and secure with screw. Cavity light: The cavity light bulb is located behind the vent grille at the top front of the microwave oven, under the bulb cover, and is replaceable. Remove 2 screws on the vent grille, tilt the grille forward, and lift it out. Open bulb cover and replace bulb. Close bulb cover, replace vent grille, and secure with screws.
For more information, your owners manual can be viewed here (scroll to the bottom of page 4):
Maytag MMV1164WB Owners Manual Page 4
Feb 11, 2015 | Maytag MMV1164WB Microwave Oven
Need help replacing handle on whirlpool microwave model MH1150XM
Remove two screws on top at front in order to remove plastic front vent grill. Then the door lifts off pin hinges. Lay door flat on surface. Plastic trim snaps off with gentle prying (start at bottom middle and bottom hinge side). Then remove six screws holding notched metal section with door latch. This piece will also snap out (several visible clips holding it around edges). Then remove door handle screws, Replace handle and reverse process to put back together.
Jul 29, 2009 | Whirlpool MH1150XM Convection/Microwave...
Can't remove a1985 GE Microwave Mode3l jvm61001 fro0m the wall.
this microwave oven slides out of its casing. here's how: first shut the power to the unit by the breaker from your main panel. on the mw oven remove the underneath rightside vent filter. unplug the large white connector that you see in through where the filter was . Dont break it. its locked and keywayed. next remove the top front plastic horizontal louvered front vent by one phillips screw on each end of the vent left and right. then remove the next two phillips screws you see under where the vent screws were. then remove the 3 shoulder screws underneath the front edge of the case bottom then slide that piece of **** oven out of its casing. I'm sure you will know what to do next. Good luck!!
Oct 21, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
My mocrowave fell and the front plastic on the door broke. The inside is not affected. Is it safe to use the microwave
The front plastic bezel on the door does not provide any shielding from the microwave energy inside the cooking compartment. As long as that is the ONLY damage and you haven't compromised the door, door frame or protective gasketing around the door opening then you should be safe.
Sep 14, 2008 | Microwave Ovens
GE JVM3670 Microwave Oven Logo
443 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
vince
Jimmy
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
