Have a Linksys WRT54G router. Can I make this a secure network. I am signed in to the administration screen - 192.168.1.1
  • 741 Answers
Yes change the information for the WEP Key. That is your network password. If someone wants to use your wireless network then they have to type in the WEP key. Let me know if you have any further questions. Don't forget to rate this 4 stars before you log out.
Posted on Jan 16, 2009
How do i secure linksys wrt54g router?
Using web browser enter the default ip of the linksys device. Make sure a port on the router is connected to your PC. Also ensure you configure the PC is on same subnet as your router. Login with the default credentials. This should take you to the router interface where you can set up SSID and security for your WIFI
Feb 22, 2015 | Linksys Computers & Internet
Im trying to find my password for my router but i cant.
Reset Button
Note:
Resetting the router to the factory defaults will delete any changes you have made to the router, including any security settings. This should be used as a last resort.
The first method involves simply pressing a button located on the back of the router. The image below (courtesy of Linksys) shows where the button is located.
Linksys WRT54G Reset Button Location
To reset your router, use the following steps:
  1. Press the reset button for 30 seconds.
  2. The settings should now be returned to the factory default settings, meaning any changes you had made would be deleted.
  3. Open up your Web browser and enter "192.168.1.1′ in the address bar.
  4. For the login, leave a blank ID and enter "admin" as the password.
The router has now been reset. Follow the steps in Securing Linksys WRT54G Wireless-G Router to secure your router and create a good wireless network security.
Through the Web Administration PagesThe second method involves logging into the Web administration pages of the router. Use the following steps to reset the router using this method:
  1. Open your Web browser and enter the IP address of your router. By default, the address is "192.168.1.1′.
  2. Enter your user ID And password when prompted. Hopefully this has been changed, but if it hasn't, the default is no ID and "admin" as the password.
  3. At the top of the Web page, click "Administration" and then "Factory Defaults".
  4. Beside "Restore Factory Defaults", click "Yes".
  5. Now click the "Save Settings" button at the bottom of the Web page.
Your WRT54G wireless router should now be reset to the factory defaults. Ensure you follow the steps outlined in Securing Linksys WRT54G Wireless-G Router to secure your router and maintain your wireless network security.
SummaryThis post has provided two methods you can use to reset your Linksys WRT54G Wireless-G router. If you are having problems with your router, try resetting the router to the factory defaults, and then make the changes again and see if the router starts working again.
Sep 24, 2011 | Linksys Wireless-G WRT54G Router
I need the Network security key to add my lapptop to the router.
http://www.pcwintech.com/screenshots-linksys-wrt54g-linksys-firmware
First, let's log on to the router.
  1. Open your internet browser and type http://192.168.1.1 in the address bar. This is the default IP address of the browser.
  2. In the login box that appears type 'admin' (without quotes) in both fields. 'admin' is the default username and password.
Write down the SSID
  1. In the Wireless > Basic Wireless Settings menu you will see the Service Set Identifier or SSID. The SSID differentiates one wireless network from another. It is the 'network name'. Write it down, or copy paste it to a text file. You will need it later. You can first set your own SSID if you like.
In the Linksys WRT54G router you will find the wireless security options under Wireless > Wireless Security. This page allows you to set wireless encryption options.
here you will find you wireless key. this can only be done by a machine connected directly by network wire. make sure you are connected first. wireless is unable to connect unless it is directly connected.
Sep 14, 2011 | Linksys Wireless-G WRT54G Router
How to change password
to change the password, assuming you have not changed the default administration passwords point your browser to "192.168.1.1" Once there you should have a login screen. linksys default is "administrator" AND "admin" as the username and password. Here you should have access to the full control panel. You can change the wireless password as well as any other settings.
Mar 07, 2011 | Cisco Linksys WirelessG Broadband Router...
Need to find ssid number for my Linksys Wireless-G WRT54G Router
This Utility program will help you locate few details of your network like :
1. SSID ( network name )
2. WEP/WPA Key ( Your network security key )
3. The PC/Laptop IP Address
4. Router IP address
5. Which all Devices are connected to your Router/Network Wireless
6. Which all Network are available nearby your place
7. Let you access the Router Configuration
Click here to Download the HP Network Diagnostic Utility
Download the file on Desktop and Run the program ( Ex. File name = HPNDU.EXE )
Follow the Instructions on the Screen and do accordingly
* Please rate this solution with Thumbs up and comment to help us improve providing support
Nov 12, 2010 | Linksys Wireless-G WRT54G Router
How do i setup a password to secure the router?
access the Admin site of yout router
http://192.168.1.1
default authentication
user: blank
password: admin
after login, click administration. then setup the new password
eric
Oct 30, 2010 | Linksys Wireless-G WRT54G Router
I cannot link my my Ipod to my router. What must
Make sure that the wireless network key which you are punching is right,If it's WEP key,then try putting a dollar "$" sign before you give the WEP key.
In order to re-check the wireless network key of your router,follow following steps:
1> By default ip address of all linksys router is 192.168.1.1.Open the internet browser & clear address bar at the top completely & type default gateway of yours computer which you are getting from router
2> Default username is blank & password is "admin".Otherwise give router password.Again if it is not working type default password which you usually give to your computers
3> Finally,you will be on router setup page;in top click on Wireless tab --> Wireless Security
4> Here you can re-check that your wireless network password.
If u need technical help in order to do the above changes in router have a words with linksys technical suppoprt.
Dec 08, 2009 | Linksys Wireless-G WRT54G Router
Pin number acces denied
If you have forgotten your password, it is wise to reset the router, Resetting the router to the factory defaults will delete any changes you have made to the router, including any security settings. This should be used as a last resort.
  1. Press the reset button for 30 seconds. The settings should now be returned to the factory default settings, meaning any changes you had made would be deleted.
  2. Open up your Web browser and enter “192.168.1.1′ in the address bar.
  3. For the login, leave a blank ID and enter “admin” as the password.
The router has now been reset. Follow the steps in Securing Linksys WRT54G Wireless-G Router to secure your router.
  1. Open your Web browser and enter the IP address of your router. By default, the address is “192.168.1.1′.
  2. Enter your user ID And password when prompted. Hopefully this has been changed, but if it hasn’t, the default is no ID and “admin” as the password.
  3. At the top of the Web page, click “Administration” and then “Factory Defaults”.
  4. Beside “Restore Factory Defaults”, click “Yes”.
  5. Now click the “Save Settings” button at the bottom of the Web page.
Your WRT54G wireless router should now be reset to the factory defaults. Ensure you follow the steps outlined in Securing Linksys WRT54G Wireless-G Router to secure your router.
Hope this helps.
Oct 22, 2009 | Linksys Wireless-G Broadband Router
How do I change the name of my wireless connection? I have the Linksys WRT54G and right now it says Linksys. I want to change it so that I can tell which connection is mine. Thanks.
All Linksys routers have a web interface to them. You should be able to go to http://192.168.1.1 or something similar (see your manual) in Internet Explorer.
Once you’re in your administrator panel you can setup the name of your wireless network, and I would recommend that you flip on some type of security as well so, your neighbors/coworkers don't get to play on your connection!
Hope this helps!
Jul 07, 2009 | Linksys Wireless-G WRT54G Router
Computers & Internet Logo
David Payne
David Payne
