Question about Refrigerators
Fluctuating temperature on fridge and freezer
The freezer keeps fluctuating temperatures. It's supposed to be set at 0 but it goes as high as 24 degrees for no reason. The fridge will do the same thing just not quite as much. I can't use the freezer at all due to this. Any ideas what's going on?
  • JRush Jan 16, 2009
    My fridge is too warm and freezer too cold despite following all the steps in the trouble-shooting guide.
  • Anonymous Mar 13, 2009
    Temperature Set Mode for 0 temp keeps climbing
duby1990
  • 370 Answers
SOURCE: Kenmore fridge and freezer not cooling
Check to see if there is any ice built up on the back wall of the freezer. If so thaw the ice and take the back wall out of the freezer. next check to see if the fan is running in the freezer (evaporator fan) This fan is what circulates the air from the freezer to the fridge. If it does run then you have a defrost problem (if ice is on the coils and back wall). Then replace defrost timer, heater, and thermostat.
Posted on Nov 20, 2008
  • 531 Answers
SOURCE: Fridger temperature selector does not reach the set temperature
check if you have frost build up in the freezer
Posted on Apr 07, 2009
SOURCE: Defy Fridge temperature dial is confusing - which way is colder?
0 = off, 1 = cool, 2 = cooler, ..... 7 = coldest.  0 - 7 Nothing to do with the degree the fridge is set to.
Posted on Jun 06, 2009
Sea Breeze
  • 4654 Answers
SOURCE: ge profile bottom mount and temperature control
Since it's less than a year old it should have a pretty good service warranty. A relay or confusion on the mother board is most likely the problem. I could send information to put it into self diagnostics but I think you may come out better by calling your nearest GE authorized service center. If you hear the compressor clicking and or no movement of air below the unit unplug it just to prevent any further damage.Your refrigerator is too new for me to tell you how to work on it is what I am trying to say, Thanks Sea Breeze
Posted on Sep 13, 2009
  • 256 Answers
SOURCE: Freezer temperature fluctuating way up.
Your problem could stem from an issue with the defrost timer, the compressor or its attachments (e.g.: relay, capacitor, etc.), or the freezer/evaporator fan motor. Contact an appliance service company.
Posted on Feb 11, 2010
My fridge keeps freezing everything what is the best temp to have it set at. It is an aurora model RB411M3
I recommend moving the thermostat to the exact center position, unplug, then plug in the refrigerator. Wait 24 hours for the fridge thermostat to reset and to thaw automatically. Then, I recommend a fridge thermometer, available at most grocers or kitchen supply stores. If you can't find one, use a digital thermometer with a probe. Place the thermometer hanging from the center of the center shelf. Keep the refrigerator temperature at or below 40° F (4° C). The freezer temperature should be 0° F (-18° C). Allow 24 hours for any thermostat changes.
Apr 08, 2017 | Refrigerators
What is the normal fluctuation range of a top freezer in a freeze-refrig combo? That is if I set the temperature of the freezer a 0 F, at what temperature should the freezer come on to keep the air i
Hello Richard;
My name is Peter. I am a retired field service refrigeration technician.
The normal range for a freezer is -2 to +2 Deg. F.
The normal range for the fresh food section is 35 to 40 Deg. F.
If you set your freezer at 0 Deg. F. it will stay at 0 Deg. F.
When the freezer temperature drops below 0, your compressor will kick in to bring the freezer back to 0 Deg. F.
Dec 15, 2014 | Frigidaire Refrigerators
What shld settings be as food is freezing in fridge it has side by side knobs saying colder mid less cold it is a westinghouse fan forced frost free freestyle unit
The settings are "relative". Someone with this fridge in Montana may need to run the same fridge with different settings than someone in Texas to get the same temperatures.
Many manufacturers recommend that the fresh food compartment should be 34 degrees F, and the freezer -10 to 0 degrees F. To set this properly, place a thermometer in the freezer (that can display temperatures as low as the desired temperature). Adjust the thermometer for the correct freezer temperature before going on to the fridge. A fully stocked freezer could take 12 hours or more for temperatures to stabilize after making changes to the thermostat. Once the -10 to 0 degree temperature has been achieved, set the fresh food compartment temperature.
Place a thermometer (that can display below freezing) in a 6 (or so) oz flexible plastic cup of water and place on a shelf in the fridge. A glass of water could break if the temperature gets below 32 degrees if the water turns to ice. The water acts as a buffer to rapidly changing temperatures when the door is opened to read the thermometer. If the fridge is "full", allow 24 hours for the temperature to stabilize before making changes.
If the fridge and freezer are empty, changes may be seen in just a few hours or less. Otherwise, wait the 12 / 24 hours for the freezer / fridge compartments.
I hope this helps and good luck!
Sep 06, 2011 | Freezers
It is a french door, items in the fridge part are freezing, what should temperature in freezer and fridge be?
The factory presets your temperatures to the MID / MID setting of 0? for the freezer and 37? for the refrigerator. Refrigerator adjustment range is -15? to +15? in the freezer and 33? to 47? in the refrigerator. Depending on ambient temperatures the temperatures will be + or - 6? the set point. Whenever you make a temperature adjustment, you need to wait 24 hours to notice any temperature difference.
To adjust your temperatures: Adjust controls according to your Use and Care guide. Start out by making sure your settings are at the factory setting of MID / MID. Make only one adjustment: Adjust one control and wait 24 hours before making another adjustment.
To measure temperatures: If you try to measure temperatures, it is important to follow these directions: Fresh Food Section: Put thermometer in a glass of water. Check the temperature during the first door opening after a long (8+hours) non-usage period (such as overnight or when you arrive home from work). Frozen Food Section: Put thermometer between two bags of vegetables. Check the temperature during the first door opening after a long (8+hours) non-usage period (such as overnight or when you arrive home from work).
For more information it may be helpful to look at http://www.whirlpool.com/ or contact your local whirlpool support number
May 17, 2011 | Whirlpool Refrigerators
I am having LG GR-B352 YC , what is the best temperature that i can keep initially and future??
Generic instructions to set temperatures in fridges:
Many manufacturers design these appliances to operate at 0 degrees F in the freezer and 34 to 36 degrees F in the fresh food compartment.
To set the temperature correctly, fill a glass with water (8 to 12 ounces) and place a thermometer capable of indicating 32 degrees and up into the glass with water (if the temperature goes below 32 degrees, the water will freeze - so no need to find a thermometer that indicates any lower). Place the glass with the thermometer in it on a shelf and wait. Putting the thermometer in a glass of water helps preserve the temperature reading while the door is open. You can skip the water and glass if you want - but you'll need to read the temperature as soon as you open the door.
The freezer will require a thermometer capable of displaying 0 degrees F. Place it on a shelf where it can be seen readily - but preferably in the rear - between items (to prevent the warm air from driving the indicator up when opening the door to read it).
It will probably be easier to set the freezer temperature first. Adjust both the freezer and fresh food thermostats to mid-points (if the fridge is empty - otherwise skip this step). Adjust the freezer thermostat up or down as needed to reach the desired 0 degree F temperature.
Once the freezer adjustments are complete, adjust the fresh food compartment thermostat as needed up or down to reach the desired temperature for it.
If you fridge is fully stocked, it may take some time for the temperature to stabilize and warm / cool the fridge's contents completely. This is further affected by how often the door(s) are opened and for how long. 24 hours is often claimed - but you might be able to sneak an 8 - 12 hour soak before reading the thermometers.
After the temperatures are set, you may find that the lower part of the fresh food area is partially freezing - simply adjust the thermometer up *slightly* as needed.
Please rate this reply if it was helpful - good luck!
Aug 11, 2010 | Refrigerators
The fan just started getting noisy. However, the fridge has not been able to stay as cold as it used to. I had a problem where the coils froze up because of a blocked drain. I fixed that but just has not...
You may hear the fans spinning at high speeds as when the refrigerator is first plugged in, when the doors are opened frequently or when a large amount of food is added to the refrigerator or freezer compartments. The fans are helping to maintain the correct temperatures.If either door is open for over 3 minutes.
set the temperature correctly as well:
The temperature controls are preset in the factory at 37°F for the refrigerator compartment and 0°F for the freezer compartment. Allow 24 hours for the temperature to stabilize to the preset recommended
settings.
Jun 15, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Fridge is freezing in the lower part of the fridge...vegetable and meat compartments
have you check the temperature?
settings.
Jun 13, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Do the kenmore refridgerators have a daily defrost cycle? If so, how long does it last and what is the temperature fluctuation? The freezer is empty right now, and the temperature fluctuation seem to go...
All refrigeration products have a defrost set point. Most residential units defrost about every six to eighteen hours. This process should take about 30 minutes to 1 hour. The temp goes up so high inside because there is a heating element in the coils to thaw any residual ice. The temp should not exceed about 45 degrees though. If it does the the compressor is signaled to come back on and start cooling again. This is perfectly alright. The time at higher temp is not enough to spoil the food. Hope this helps. Good luck.
Nov 18, 2009 | Kenmore Refrigerators
Jan 07, 2009 | Refrigerators
Bosch Fridge Freezer Classixx
This button is the winter/summer setting.
If you switch it on so as the red mark shows this is set for the summer setting.
What it does is allows the interior light to come on very dimly when you shut the door.
The fridge then thinks it is too warm and starts to cool down more, designed for when the ambient temperature is high.
Hope this helps
Deep diver
Dec 22, 2007 | Refrigerators
Refrigerators Logo
1,275 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
