Question about ASUS VIA KX133 Chipset K7V-T Motherboard
Switch settings for CTS 208-4 on an asus MBd.7V with a K7 Athlon 950 Mhz
Which swiches are supposed to be on & which ones off on the little blue CTS 208-4 1234
2 Suggested Answers
stergiou88
  • 66 Answers
SOURCE: Set up ASUS A7S333 to K7
The mobo is able to work without drivers, but you will not have the best performance. If you want drivers you can search to the ASUS site or google.
Posted on Oct 08, 2009
ASUS A7S333 BIOS settings with Athlon XP 2600
Why are you guessing, jfoster?
1) http://support.asus.com/download.aspx?SLanguage=en&m=A7S333&os=
2) Or direct link to motherboard user manual,
http://dlsvr04.asus.com/pub/ASUS/mb/socka/sis745/a7s333/e982_a7s333.pdf
3) http://en.wikipedia.org/wiki/List_of_AMD_Athlon_XP_Microprocessors#Athlon_XP_.22Thoroughbred_A.2FB.22_.28Model_8.2C_130_nm.29
STARTING with the Athlon XP Thoroughbred A/B (Model 8, 130nm),
models that are 2600+,
go down through the charts, and find the Part Number that matches the one you have.
There you will now have the;
A) Front Side Bus (FSB)
B) Multiplier
C) Voltage
Question,
What is a, "Wierdly enough it dores boot the freedos on the harddrive OK." ???
For additional questions please post in a Comment.
Regards,
joecoolvette
Mar 21, 2013 | ASUS A7S333 SIS745 K7 266MHz...
Early AMP processor up to 200 MHZ
Athlon (slot A)
K7 microarchitectureDesktop CPU Up to 1 GHz Up to 512 KB L2 cache 200 MHz FSB
http://www.cpu-world.com/CPUs/K7/TYPE-Athlon.html
Aug 14, 2009 | DEC Computers & Internet
2600+ with ASUS MB A7V266-E/AA
Here is the CPU Support list from Asus Support, for the Asus A7V266-E,
http://support.asus.com/cpusupport/cpusupport.aspx?SLanguage=en-us&model=A7V266-E/AA&product=1&os=17
Scroll down the list. 34th one down, that is listed.
1.Did you get the Athlon XP 2600+ that has a 266MegaHertz, (MHz), Front Side Bus? (FSB)
The AXDA2600DKV3C?
There is an Athlon XP 2600+ that has a 266MHz FSB, and one that has an FSB of 333MHz. <-This one Won't work.
Model number ->AXDA2600DKV3D will Not work.
Both are Thoroughbred A/B Core models.
The AXDA2600DKV3C has a 12.5x multiplier.
Your 1900+ has a 12x multiplier. (AXDA1900DUT3C) They both have an FSB of 133MHz. (Shown as 266MHz because AMD processors are 'Double-Pumped')
A.The AXDC2600DKV3C will not work. It has a 16x multiplier. (Thorton Core)
B.The AXDC2600DKV3D will not work. It has a 333MHz FSB. (Thorton Core)
C.The AXDA2600DKV4C will not work. It has a 15x mulitplier. (Barton Core)
D.The AXDA2600DKV4D will not work. It has a 333MHz FSB. (Barton Core)
E.The AXDA2600DKV4E will not work. It has a 400MHz FSB. (Barton Core)
2.Are the jumper blocks -> CPU RATIO, and SYSCLK, still set in the Jumper Free Mode?
By the factory default settings these jumper blocks, (DIP switches), should already be set to Jumper Free Mode.
The white DIP switches should be in the OFF position. (The white switches will be DOWN, towards the numbers on the jumper block CPU RATIO. They will be UP, away from the numbers, on the jumper block SYSCLK))
The CPU RATIO jumper block is right above the processor. It is a blue rectangular block.
The SYSCLK jumper block is down the motherboard, right below the AGP graphics card expansion slot. (And above the first PCI expansion slot)
If those two jumper blocks are not set to Jumper Free Mode, set the DIP switches in the jumper blocks to this setting.
Now go into BIOS Setup. In the main menu use the Right Side Arrow key on your keyboard, and highlight Advanced.
If -> CPU Speed is set to Auto, you won't have access to set your CPU parameters. If it is set to Manual, you will see them. If it's set to Manual, write down the headings, (CPU:System Frequency Multiple, System/PCI Frequency (MHz), and so on) Write down the numbers to the right of these headings. If something goes wrong, you can go back into BIOS Setup, and change them back.
1.CPU:System Frequency Multiple should be
12.5X
2.System/PCI Frequency (MHz) should be
133/33
3.System/DRAM Frequency Ratio should be
(Auto)
4.CPU Vcore should be (1.750)
5.CPU Level 1 cache, and Level 2 cache should be (Enabled)
6.CPU Level 2 cache ECC Check should be (Disabled)
7.BIOS Update should be (Enabled)
8.PS/2 Mouse Function Control (Auto)
9.USB Legacy Support (Auto)
10.OS/2 Onboard Memory >64M (Disabled)
Leave the rest alone.
The AXDA2600DKV3C uses 1.65 volts, has a 12.5 clock multiplier, and a 266MHz FSB. (You will see 133MHz, and set all your settings to 133MHz. AMD processors are 'Double-Pumped'. Intel processors are 'Quad-Pumped')
Aug 10, 2009 | ASUS A7V266-E (A7V266-E AA/PA/WOR)...
I would like to find the spec manual and what cpu slot it has.
I tried to get the exact link, but the website will not allow it.
Go to this page, and put in your model number, and you will find it really easy.
http://support.asus.com/download/download.aspx?SLanguage=en-us
This board is a socket A for AMD processors.
You will need adobe reader to get this manual.
Apr 16, 2009 | ASUS A7N8X Motherboard
How fast of an amd athlon processor can i use in a biostar m7mkb?
According to these specs 500 Mhz and up
http://www.motherboard.cz/mb/biostar/M7MKB.htm
Your motherboard supports a slot A Athlon.
The fastest looks like up to 1Ghz as according to CPU World:
http://www.cpu-world.com/CPUs/K7/TYPE-Athlon%20(Slot%20A).html
Hope this info answers your questions. Feel free to comment if you need further info from me.
Rate me please when you get the chance.
Mar 04, 2009 | Biostar Slot A M7MKB Motherboard
What are pentium III Equivalents
Athlon 1.3GHz cpu
Celeron 300A processor.
These are a few and courtesy of Tech Enclave here is a link about a place in China that produced a CPU called Godson II which is the equvalent of a Pentium III as well.
http://www.techenclave.com/cpu-mobo-corner/chinese-made-cpu-chip-equivalent-pentium-2595.html
Hope this helps.
Feb 27, 2009 | Intel Pentium 3 , 450 MHz Pentium III...
K133ASA via Apollo motherboard cpu upgrde
Socket A/462 can take any AMD K7 family processor. The fastest you could get would be the Athlon XP 3200 I believe, but that could also include the Athlon 1400 and the Duron 1800. So it looks like you can make a significant upgrade of yhe processor.
Jan 28, 2009 | Computers & Internet
EliteGroup K7S5A (does not say pro on the board)
According to their website, the board can take:
AMD Athlon XP (Throughbred up to XP2600+)
AMD Athlon (including Thunderbird)
AMD Duron (including Morgan)
You can then overclock the processor with a BIOS upgrade available at http://www.ocworkbench.com/2002/ecs/k7s5abios/cheepobios.htm.
It has one 4X AGP slot so it can take any AGP video card, assuming the card is backwards compatible (8x -> 4x).
Jan 13, 2008 | EliteGroup K7S5A Pro Motherboard
ASUS A7S333 upgrade solution
MPN: A7S333
Product Type: Motherboard
Form Factor: ATX
Width: 30.5 cm
Depth: 21.9 cm
Compatible Processors: Athlon, Duron, Athlon XP
Processor Socket: Socket A
Chipset Type: SiS745
Max Bus Speed: 266 MHz
BIOS Type: Award
Storage Controller: ATA-100
amd 3200 + anthlon ok with fsb 266 mhz soket a
Jan 10, 2008 | ASUS A7S333 Motherboard
PROCESSOR
Your M/B support Socket 462 (also called Socket A) is a PGA socket designed for AMD K7 family of processors. This socket can be used with AMD Athlon and Duron processors ranging in speed from 600 MHz to 2200 MHz (3200+) and with bus frequences ranging from 100 MHz to 200 MHz (400 MHz DDR)
Athlon (Socket A) (600 MHz - 1400 MHz)
Athlon XP (1333 MHz - 2333 MHz, or 1500+ - 3200+)
Athlon MP (1000 MHz - 2133 MHz)
Duron (550 MHz - 1800 MHz)
Sempron (socket A) (1500 MHz - 2200 MHz, or 2200+ - 3300+)
Mobile Athlon 4 (850 MHz - 1400 MHz)
Mobile Athlon XP-M (Socket A) (1200 MHz - 2200 MHz, or 1400+ - 3000+)
Mobile Duron (650 MHz - 1200 MHz)
I Recommend to go for Athlon XP with good cooling fan. :)
Dec 18, 2007 | EliteGroup K7AMA Motherboard
ASUS VIA KX133 Chipset K7V-T Motherboard Logo
245 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
