Question about Coleman Powermate Proforce 2500 Generator
Coleman powermate 2500 generator : engine runs good ... little to No power on recepticle ... vom reads 2. volts
    New Friend:
  • 5 Answers
To what I know about this model - it IS NOT inverter type. Electrical motor works pretty much like car alternator with out reftifier. The ONLY magnet on rotor is a small, 1x2 initiation magnet, that helps to start the induction current. After that, induction current thru rotor is controlled by AVR (automatic voltage regulator) in a way, that output voltage stays at needed level.
The fact that you read 2.0 volts on output - tells you that your initiation magnet is OK. One of few things went wrong, in probability order: winding on rotor, AVR module, winding on stator, brushes woar out.
Take back cover off from electric generator part, use voltmeter to measure continuity on stator (2 or 3 poles, must be within 50 ohnm), continuity of rotor thru brushes ( normally within 100ohm). If broken - have to restore windings. It is DIYable for rotor, but hardly possible for stator. If those are ok - most probably your AVR is dead, you can not test it yourself, so get a new module to try (but try to make arrangements for return, if there it was not the reason).
Just fixed Champion 3500 generator myself, purchased for $50 as broken.
Posted on Jan 13, 2010
Sounds like you need to remagnitize your alternator, you can do this yourself but do it like this.
FIRST AND FORMOST STOP THE ENGINE AND WAIT TILL IT MAKES A COMPLETE STOP! AND LOCK OUT THE ENGINE SO IT WILL NOT ACCIDENTALLY START.
 pull the spakplug wire off the engine this WILL HELP ENSURE IT WILL NOT START. next take an old 120v power cord and cut the plug off with atleast 8 inches of wire on it. if it is a 2 prong wire or 3 it doesnt matter. grab your self 2  nine volt alkaline batteries, try just one battery first by plugging in the cord into a 120 volt receptical on your generator and make sure the circuit breaker is in the on position. MAKE DAM SURE THE GENERATOR IS NOT RUNNING BEFORE YOU DO THIS OTHERWISE YOU COULD BE ELECTROCUTED. it is quite safe as long as the generator is NOT RUNNING. put one lead on one terminal of the nine volt and the other lead on the other terminal and you will see a small spark if done right.MAKE SURE YOUR NOT DOWNWIND OF GASOLINE FUMES! if you have a 3 wire cord do not use the green ground lead use only the black and white or blue and brown. if its a two wire cord you cannot get it wrong. tap the wires on the battery terminals a few times. this shoud have remagnitised your rotor and stator. remove the cord from generator completely and put it away from kids and the incredibly stupid for safety. restart generator and plug in an appliance to see if it is making electricity. I recommend using a true rms digital voltmeter to check the voltage it should be between 110 and 130 vac rms for non regulated generator sets. if the 9 vold didnt do it you can use 2 nine volt batteries in series to flash the field. SAFETY FIRST ! ELECTRICITY CAN KILL, YOU DO THIS AT YOUR OWN RISK, I AM NOT LIABLE FOR ANYONES STUPIDIY. IF YOU ARE UNSURE HOW TO DO THIS THEN DO NOT DO IT! TAKE IT TO A QUALIFIED REPAIRMAN. LIFE IS IRREPLACIBLE SPEND A FEW BUCKS TO FIX.
Posted on Feb 08, 2009
My coleman 2500 powermate generater leak from top of carburater, help
The carburetor needs to be rebuilt - the float valve is stuck open.
Jul 05, 2014 | Coleman Powermate Portable Generator...
I have a coleman 5000 that won't hold voltage at 110 volts under load. It fluctuates up and down. The motor is running steady. What could be the cause of this?
govenor problem maybe does the engine sound slower when a load is on.
you will need something to read the power frequency
3000 rpm produces 50hz uk
3600 rpm produces 60hz
so if you have a meter to measure frequency you will also know what speed the engine is running at
Feb 27, 2010 | Coleman Powermate Powermate 5000W...
How do you convert the (2) 240 volt outlets to one twist lock connector on a coleman powermate maxa 5000 er genset
Make an Umbilical recepticle adapter. Buy the recepticle install the recepticle in a 4" electrical BOX on a plate with two manufactured 3 prong power cords plugging into the 2 outlets and terminating at the new Box twist lock recepticle you made.
Feb 09, 2010 | Coleman Powermate Powermate 5000W...
I'm reading 130VAC on the output. Can this be
It should read 115v-120v with full load. Yes, you can slow the engine down just a little, depending on the engine, there will be a high rpm adjustment. 130v with full speed, no load, is really not too bad.
Nov 26, 2009 | Coleman Powermate Powermate 5000W...
My Generator is putting out voltage on both the neutral side and positive side of 110 Volt recepticles. When hooking a meter to both sides (Neutral & Positive) it is showing 184 volts! It burnt up a...
Check the voltage with a meter in all the recepticles with your meter leads in the left and right slots on the plugs. Is that 184 volts AC there? If so, your gen has big problems with the voltage regulator. Let me know what you read. You can check the right slot of each plug to the round ground hole on the plug too, should be 120 volts there.
Jul 01, 2009 | Coleman Powermate Proforce 6,000 Watt 12...
I have a Coleman Powermate Pulse 1750 generator. The engine runs fine but lately I've noticed I'm only getting approx. 105 volts. Any suggestions.
Engine speed is low, does your meter read frequency? Set for 60 Hz @ speed. I doubt there is a voltage regulator adjustment. This may help
Jun 25, 2009 | Coleman Powermate Premium Plus 6250W...
My powermate pm0647000 stopped generating electricity.
Flash it !
Start your generator, plug a single speed drill into the recepticle, while the generator is running make sure the drill is in the forward posistion then turn the drill chuck couterclockwise with your hand untill your generator power's up.
This simple fix " excites " the stator.
Good luck !
Sep 29, 2008 | Coleman Powermate Premium Plus 6250W...
Coleman Powermate Proforce 2500 Generator Logo
2,281 people viewed this question
Top Coleman Electrical Supplies Experts
John Trevino
Craig Butler
Craig Butler
Phil Walker
Phil Walker
Are you a Coleman Electrical Supply Expert? Answer questions, earn points and help others
