Question about JBL PB10 Subwoofer
JBL PB10 Subwoofer that makes loud hum/crackle noises.
I reviewed similar problems on this site, but didn't see a helpful response. I'd like fix it myself if parts are available and reasonably priced, so any assistance there would also be appreciated. Thanks.
5 Suggested Answers
  • 20 Answers
SOURCE: PB10 Loud Hum and Crackle- LED Lights mixed Red/Green
Hello, Jesse. I doubt I can help, but there is at least one SIMPLE thing you can try - with maybe a 10% chance it wil return your unit to normal: Unplug the unit for 30 seconds, then plug it back in to a DIFFERENT outlet. Oh, yes - there are NO fuses or other "reset" devices. I'm sorry I couldn't offer you more help.
Posted on Jul 26, 2007
renosean
  • 492 Answers
SOURCE: Thump at the time of shutoff
The amplifier in the sub as with any other amplifier has a capacitor in it. Essentially a battery that holds a charge. When you trun things off such as subs or amps with a powerstrip instead of the intended on off button, the power supply has been cut, but the capacitor is still energizing the unit. So it catches the noise in the line.
Posted on Mar 08, 2008
blueextc3221
  • 15935 Answers
SOURCE: JBL PB10 subwoofer, it makes a loud burp noise when it comes on.
In the industry - It is called "Turn-On Thump".
There are some manufacturers that eliminate components like noise filters on enry level lines to save money.
There is no way to lessen this noise without ripping the amplifier apart and having a technical knowledge of the way amplifiers work. It would involve hard-wiring a slow charge capacitor in the turn on line so it gradually builds power instead of getting it all at once.
Thanks for using FixYa - a FixYa rating is appreciated!!
Posted on Feb 10, 2009
budmrtn
  • 11361 Answers
SOURCE: JBL PB10 subwoofer sounds distorted and lights on the front flash
More likely to be the Class D power amp module, but you should look through the service manual to make sure all the parts are installed correctly. My PB10 AMP module went out and you cannot get one anymore.
http://manuals.harman.com/JBL/HOM/Service%20Manual/PB10%20sm.pdf
Posted on Nov 10, 2009
budmrtn
  • 11361 Answers
SOURCE: jbl pb10 subwoofer will not come on, that is the
Download service manual here:
When I plug it up it makes a loud buzzing humming sound that's unconteollable with the volume.
Buzzing is usally AC line noise leaking into an un-shielded cable somewhere or a floating ground. If the AC plug is reversable, try that. make sure all audio cables are pluh\gged in tightly at each end and routed away from or at right angles to any power cords and away from other sources of strong magnetic fields like TV's. I've also seen variable track lights induce noise but it's usually minor.
If it still does it with no cables attached it's an internal amp problem.
Dec 31, 2010 | JBL PB10 Subwoofer
Nov 10, 2009 | JBL PB10 Subwoofer
Feb 10, 2009 | JBL PB10 Subwoofer
Mar 07, 2008 | JBL PB10 Subwoofer
Jbl subwoofer
There is actually some good news.  I had this problem with my PB10s (1 have 2 PB10s and 2 PB12s) It is one of 2 things, the first is that it could be a capacitor and resister combination on the amplifier board (which was the fix for our PB10 with the same problem), or 2nd, the AMP IC, which is not available for the PB12. hmmm
Sep 10, 2007 | JBL PSW-D112 Speaker
Jul 25, 2007 | JBL PB10 Subwoofer
JBL PB10 Subwoofer Logo
339 people viewed this question
Top JBL Audio Players & Recorders Experts
Michael Edwards
Michael Edwards
Level 1 Expert
 Grubhead
Grubhead
Jerry Greenberg
Jerry Greenberg
Are you a JBL Audio Player and Recorder Expert? Answer questions, earn points and help others
