Question about Sony Playstation 3 (PS3) Console
Playstation 3 80 GB will not boot up to start menu
When I turn on my system it will not bring up the options menu. Everything in normal until it get it where the options menu should come up. There is just a black screen.
  • lokiju Jan 25, 2009
    i have the same problem. :-/
  • jmjolles Feb 18, 2009
    I hear start-up music and see black screen with wave, but no menu is displayed and I can not do anything.
I had the same problem with the 40 gb and bought new 250 gb hard drive at best buy for $95 and now it running faster wish i would have know i wouldve bought one when i bought the system
Posted on Feb 21, 2009
    President:
  • 2,653 Answers
If you can get to it without it freezing use the System Restore function under:
System->Settings>Restore PS3
If you can't get to it because of freezing you should put your hard drive into another PS3. It will see it as a new drive and prompt you to format it. Afterwards put it back into your PS3 and it will do the same thing again.
It doesn't matter which PS3 yours or the one you put your hard drive into, they're all the same as far as the process goes.
This will sort everything out.
Posted on Feb 20, 2009
Start my pc on safemode
Windows 2000 and XP users Tip: If you are running Safe Mode because you cannot get into Windows, you may want to first try loading the last known good configuration.
To get into the Windows 2000 and XP Safe mode, as the computer is booting press and hold your "F8 Key" which should bring up the "Windows Advanced Options Menu" as shown below. Use your arrow keys to move to "Safe Mode" and press your Enter key.
Note: With some computers, if you press and hold a key as the computer is booting you will get a stuck key message. If this occurs, instead of pressing and holding the "F8 key", tap the "F8 key" continuously until you get the startup menu.
Trouble Getting into Windows 2000 or Windows XP Safe mode - If after several attempts you are unable to get into Windows 2000 or Windows XP Safe Mode as the computer is booting into Windows, turn off your computer. When the computer is turned on the next time Windows should notice that the computer did not successfully boot and give you the Safe Mode screen.
Please select an option:
Safe Mode
Safe Mode with Networking
Safe Mode with Command Prompt
Enable Boot Logging
Enable VGA mode
Last Known Good Configuration (your most recent settings that worked)
Directory Services Restore Mode (Windows domain controllers only)
Debugging Mode
Start Windows Normally
Reboot
Return to OS Choices Menu
Use the up and down arrow keys to move the highlight to your choice. Once you're done in Safe mode if you want to get back into Normal Windows restart the computer like you normally would and let it boot normally. Click here to get additional information about getting out of Safe mode.
loading the last known good configuration.To get into the Windows Vista and Windows 7 Safe Mode, as the computer is booting press and hold your "F8 Key" which should bring up the "Windows Advanced Options Menu" as shown below. Use your arrow keys to move to "Safe Mode" and press your Enter key.
Note: With some computers if you press and hold a key as the computer is booting you will get a stuck key message. If this occurs, instead of pressing and holding the "F8 key", tap the "F8 key" continuously until you get the startup menu.
Trouble Getting into Safe mode - If after several attempts you are unable to get into Safe Mode as the computer is booting into Windows, turn off your computer. When the computer is turned on the next time Windows should notice that the computer did not successfully boot and give you the Safe Mode screen.
Choose Advanced Options for: Microsoft Windows Vista
Safe Mode
Enable Boot Logging
Enable low-resolution video (640x480)
Last Known Good Configuration (advanced)
Debugging Mode
Disable automatic restart on system failure
Disable Driver Signature Enforcement
Description: Start Windows with only the core drivers and services. Use
when you cannot boot after installing a new device or driver. Once you're done in Safe mode if you want to get back into Normal Windows restart the computer like you normally would and let it boot normally.
Aug 13, 2014 | Computers & Internet
My Playstation 3 (60 GB) will not connect to wifi. It has connected before but until recently (2/3 weeks and i am now sick of waiting) it hasn't worked. I have tried to turn off the modem and router...
mmk first thing is that you will need to get your playstation into safe mode
step 1 make sure the system is off (solid red light)
step 2 hold down the power button until the light changes from green back to solid red
step 3 hold down the power button you will here a series of beeps coming from your system listen for the quick double beep (less than one second between beeps) then take you finger off
step 4 you should see a message about plugging your controller in follow thos and 6 options should come up
step 5 choose option 3
if this does not resolve repeat above steps 1-4 and choose option 5 (this will erase everything)
step 6 if the above does not resolve it is a hardware issue and you will need to contact sony
Nov 10, 2011 | Sony PlayStation® 3 (60 GB) Console
My ps3 freezes upon start up, or shortly after. sometimes it freezes when trying to get into safe mode. sometimes i just get a black screen and my controllers won't connect. everything worked fine on...
You can try the steps below. Its from PlayStation Forum:
1. Turn off Playstation®3.
2. Hold the power button down; the system will turn on and turn off once again.
3. Once the System has been shutdown, re-press you finger until you hear 2 consecutive beeps
4. When you hear the 2 beeps take finger off power button.
5. You will be prompted to plug in your controller via USB and then hit the PS button
6. The Recovery menu will pop up.
The current Recovery Menu supports:
• Restart System: Restarts the PLAYSTATION®3 System.
• Restore Default Settings: Reset all system settings back to default.
• Restore File System: Checks for corrupt/missing system files.
• Rebuild Database: Rebuilds the OS for the PLAYSTATION®3.
• Restore PS3 System: Fresh restore; Deletes everything and starts from Scratch.
• System Update: Update the PLAYSTATION®3 System
If the above steps still does not solve the problem, then I think will have to update your Ps3.
Update your PS3 (in the settings menu the 1st option).
Go on the internet browser on the PS3 then go on the menu press triangle then on one of them there are delete cookies and the delete the others as
well as cookies.
You could also try this as well: put the PS3 on then press the eject button (with no disc in) then hold it and switch the PS3 off at the back with your finger on the eject button still holding it, then put it back on and the fan test should be working this may cool it down. It might be over heating.
But if your problem is not still solved, then maybe you should call sony for further assistance.
I wish you good luck
Aug 15, 2011 | Sony PlayStation® 3 (60 GB) Console
Ps3 wont load game circle is there that shows that it is loading but it never loads
I had a similar problem. My PS3 did not start the disk based games. Those disk based games were not visible in the game menu. I did not have problems with the normal movie DVDs or Movie Blu Rays. Those were working fine.
In case you have the similar problem, you should try the following steps;
The PS3 has a special Recovery Menu, which you can access in the following way;:
1. Turn off Playstation 3.
• Restart System: Restarts the PLAYSTATION 3 System.
• Rebuild Database: Rebuilds the OS for the PLAYSTATION 3.
• System Update: Update the PLAYSTATION 3 System
Select option "Rebuild Database".
After PS3 has executed the DB rebuilding operation, the disc games will be visible again in the menu and are starting automatically when inserted to PS3.
Jun 18, 2009 | Sony Playstation 3 (PS3) Console
Disk not reading
I had a similar problem. My PS3 was not starting the game discs when I inserted those to PS3. Also those game discs were not visible in the game menu. I did not have problems with the normal movie DVDs or Movie Blu Rays. Those were working fine.
After PS3 has executed this DB rebuilding operation, the disc games will be visible again in the menu and are starting automatically when inserted to PS3.
Jun 17, 2009 | Sony Playstation 3 (PS3) Console
Will not load games
I had a similar problem. My PS3 did not load the disk based games. Those disk based games were not visible in the game menu.
I did not have problems with the normal movie DVDs or movie Blu Rays. Those were working fine. Also downloaded games were working ok.
Jun 14, 2009 | Sony Playstation 3 (PS3) Console
Playstation 3
Jun 14, 2009 | Sony PlayStation® 3 (60 GB) Console
Ps3 will not play any games
Jun 07, 2009 | Sony PlayStation® 3 (60 GB) Console
Problem with playstation 3 games and blue-ray
definitely a prob with the blueray laser u need to bring it back to shop or sony as there is no way u can fix it yourself.
Jan 02, 2009 | Sony Playstation 3 (PS3) Console
MY PS3 DOSENT READ MY GAMES
I did not have problems with the normal movie DVDs or Movie Blu Rays. Those were working fine. Also downloaded games were working ok.
Dec 24, 2008 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
543 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
marley mcelhinney
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
