Question about Samsung HC-P4752W 47" Rear Projection HDTV-Ready Television
Rear view projection tv sp42w5hfx
Hi there i have a samsung rear view projection tv model no sp42w5hfx ave replaced the stk chips cause the colours where distorted but theres a slight bow on the writing i need the sequence toget in the engineers service menu on this model and also the settings
  • 6 more comments
  • benny1951 Jan 20, 2009
    hi there i have a rear view projection tv model sp42w5hfx i need the sequence to get in the engineers menu also the settings as i cart access the free down load links plz can you help
    you told me put the tv in dynamic mode but mine aint got that its got cool 1 & 2 warm 1 & 2 and normal
    i just cart seem to enter the service engineers menu plz can you help
  • benny1951 Jan 21, 2009
    hi i try this solution mute 183 but no joy its very fustrating do you have any other ideas how to get in the service menu
    hi there am in the engineers service menu whast the settings also do you have tyhe information how to change the lines as i cart down the service manual to my samsung sp42w5hfx rear view projection can you help
    hi there i cart get down load the link to the service settings on a sp42whfx rear view projection tv regards dave
    hi there i have a sp42w5hfx rear view projection tv i need the service menu settings as i cart download them from the links plz help
    hi there my email is benson76@btinternet.com could you plz forward the settings for the engineers service menu on my sp42w5hfx rear view projection tv would be very gratful
  • Samsung Master
  • 19,396 Answers
You find repair manual here.
You need to download all 8 parts , after downloading all files , unzip files using WinRAR .
Posted on Jan 23, 2009
  • 11,896 Answers
Key Functions
mute-1-8-3 to gain access
7,8,9 = select R, G or B
+100,0,PRE-CH = mute R, G or B
INFO = test/normal
4 = shifts from point to line, grid move
2 = restore factory
SOURCE = H/V select
ADD/DEL = Save
S.MODE = exit
MUTE = cursor forward
P.MODE = cursor back
Volume +/- = moves convergence left or right
Channel +/- = moves convergence up or down
1 = zero's all convergence settings (ugly!)
U/D/L/R = move cursor
SELF FOCUS = saves the convergence adjustment - do before exiting
Posted on Jan 21, 2009
    Genius:
  • 1,913 Answers
Reattch all connection check your power supply and earthing works properly.also reset all settigns to factory deaults.check screen resolution is propely.
  • kishor khatri
    kishor khatri Jan 24, 2009
    u need to take it to service shop.
  • 50 Answers
Go to this website www.eserviceinfo.com, click search, type in the mfg: the brand of your unit, type also in the enter ?: the model of your unit: for ex: Enter ?: sp42w5hfx Search: Samsung, after you type the brand and model, click search, you can now see the results of your search.
click the Samsung sp42w5hfx_xeu.part.1.rar to open this link, after you click there's another page that opens and scroll down to it and click Download >> To download the file, please click here ! << Download, and save the file wherever you like it.
Now, double click the file to open it and click the alingment and adjustments, and follow the instructions on the manual to get the engineers service menu and settings of your projection tv. Hope this one's help.
Good luck, have a nice day. Godbless
    Sergeant:
    Novelist:
  • 326 Answers
Try mute 183 and enter the service menu to change the settings accordingly
Posted on Jan 20, 2009
    Scholar:
  • 87 Answers
If you replaced the STKs there should be no bows in the picture.Fine tuning is normal but severe bows means you still have a problem.I work on a lot of Samsung and usually I also have either a pico fuse open up that kills the -33VDC or +33VDC.The other thing that happens is that usually atleast 4 resistors that open up.These are 4.7 ohm resistors right in front of the amps.I feel that if you did not look any further than the amps, you still have a problem.I`ve never repaired a convergence amp circut that required major adjustments,usually just a little touch up in customer menu.
  • Albert Vasquez
    Albert Vasquez Jan 20, 2009
    If you want to fix this unit it would be eaiser if you took the advice of an actual TV technician.I know that you have alot of information thrown at you and 90% of it is wrong.I work on these things every day and I do not search the internet to waste your time with guesses.I can share information with you that will help get your unit fixed.The first question I have, is what was the complete number of the STKs that you replaced and where did you get them from?
    Scholar:
  • 160 Answers
Click the link for manuals and instructios guide: http://www.free-service-manuals.com/cgi-bin/page.cgi?g=Detailed/45940.html&d=1
hope this helps.--rate the solution if it helps you.
  • 10,594 Answers
Service code sequence is not a problem but service data handling can be and little mistake will mess the TV.
I would suggest to get service manual from HERE for free to do convergence data adjustment as per procedure.
Please download all 8 files and use WinRaR to unzip.
Good luck.
  • 8 more comments
  • Shahid Electronics
    Shahid Electronics Jan 20, 2009
    You did not mentioned any further help you need? Now you have service manual and this is technical document of this TV with all tech details including service data.
    As you said, you can not access to free download link so procedure to access service menu is appended below...
    1. Turn on the TV, and then select “DYNAMIC” on the picture adjustment mode.
    2. Turn off the TV(STAND-BY).
    3. Enter the service mode by pressing the remote control keys in the following sequence:
    Display -> Menu -> Mute -> Power ON
    Note : If necessary, re-do steps 1~3.
    Initial display when the service mode is switched.
    Below is an image of service data screen... you will see...
    If you wish, I can email you complete service manual.
    Without any feedback or comments, rejection of every solution is not helpful to solve your TV problem.
    At least comments or reason of rejection should be there.
    Thanks for these words.
    I'm telling you from Service Manual and I'm ready to email it to you.
    Your TV is Samsung SP42W5HFX and I gave you FREE download link. For some reason, you can't download it then let me email you this repair manual to help you out.
    You can use your Yahoo or Gmail email to receive repair manual to proceed further. If you don't have email on yahoo or gmail, sign up an account and let me know to forward the manual there.
    Here is an image of convergence adjustment section in repair manual which let you know how to perform convergence adjustments.
    You should argue or question the solution but simply rejecting will not help us to solve TV problem.
    Please try to understand. We all contributed here are to help you out.
    Shahid Electronics Jan 21, 2009
    If you feel any difficulty, click ASK ME button to guide you more.
    Please provide me your email address and enable me to provide you Free Service Manual of Samsung SP42W5HFX TV. Once you have repair/ service manual in hand, it would be very easy for you to fix this TV.
    I hope you are getting my messages here.
    OK, Thanks for giving email address.
    repair manual is on its way.
    I send the repair manual in 3 emails on your provided address. Let me know that you got emails. You need Acrobat Reader software to view repair manual (pdf files)
    If you need further help, let me know.
    Genius:
  • 1,550 Answers
You can get the service manual from the link below
Click this link
Try this in your remote 7 8 9 to select R G B, 4 to select moving part a line, full line or the whole matrix.
S.mode to save your setting.
Adjusting using arrow keys.
  • SAM ANDERSON Jan 20, 2009
    The link was not placed properly here is the link for the manual
    http://www.free-service-manuals.com/cgi-...
I have a Samsung Model PCN5425R Rear Projection TV. When I try to set the convergence, the red will not move whatever I do, but the blue works fine.
If it is rear projection set it uses either two of the STK-392-020 OR STK-392-040 CHIPS FOR CONVERGENCE OUTPUT.
BOTH WILL HAVE TO BE REPLACED; NOTE THAT THESE SETS ALSO HAVE "PICO" FUSES ON THE BOARD FOR EACH CHIP--no movement means one of the fuses is blown because the chip shorted.
This can be a do it yourself repair if you are handy; total parts cost if the parts purchased on Ebay is under 30 dollars.
Let me know if I can assist you and if you have any questions reply to the posting here.
REGARDS, SD TECH
Aug 10, 2010 | Samsung PCN5425R 54" Rear Projection...
Samsung rear projection tv wont turn on.
Replace your STK ics both of them. STK392-040 go by number on parts
Nov 15, 2008 | RCA D52W19 52" Rear Projection Television
Colors are out of line
When A REAR PROJECTION TV has coloured outlines or a 3D image the Convergence Circuits most likely need attention.
Replacing the output amplifiers (located within the Convergence IC's) allows the pictures to line up correctly, and no more color outlines.
This is the most common fault in all makes of rear projection TVs.
Some models of TV require major disassembly and considerable shop/manufacturer's support to repair because of their design that causes other power supply or vertical deflection problems. The poorly designed products require a "bench" repair that can typically cost from $350 t0 $700.
Some TVs are designed for on-site repair and have more reliable circuit design that does not usually cause damage to other parts of the TV when convergence chips fail. The ones that usually allow reliable on-site repair are JVC, Samsung, Sony and Hitachi.
It is normal to have some resistors in the circuit burn up or increase in value from the heat (from 2.2 ohms to 5 or 10 ohms). These resistors must be replaced with the right value or the chip may fail again.
This is not a simple repair like changing batteries or a fuse. Reading through the other posts shows many that try and end up with bigger problems.
Your JVC uses STK 392-110 IC's. Misinformed people replace the IC's with other "new and improved" IC's, like STK 392-150. These are devices with different characteristics and require different value resistors in the circuit. Replacing with the STK 392-150 will cause overheating of the resistors and a damaged IC.
If you are in Calgary, I can help. If not, get someone that has experience working on your JVC. My website is below with some costs and explanation.
calgaryconvergencerepair.weebly.com/convergence-explanation.html
Good Luck,
Easyab
Jul 11, 2008 | JVC AV-56WP74 56" Rear Projection...
Jvc 65 inch I'art tv
1024x768 Normal 0 When A REAR PROJECTION TV has coloured outlines or a 3D image the Convergence Circuits most likely need attention.
Some TVs are designed for on-site repair and have more reliable circuit design that does not usually cause damage to other parts of the TV when convergence chips fail. The ones that usually allow reliable on-site repair are JVC, Samsung and Hitachi.
Good Luck,
Easyab
Jul 06, 2008 | JVC AV-56WP74 56" Rear Projection...
Jvc convergence
1024x768 Normal 0 Convergence
Good Luck,
Easyab
Jun 18, 2008 | JVC AV-56WP74 56" Rear Projection...
JVC Television
Good Luck,
Easyab
Jun 05, 2008 | JVC AV-56WP74 56" Rear Projection...
Wavy green lines at top of tv
Good Luck,
Easyab
Jun 02, 2008 | JVC AV-56WP74 56" Rear Projection...
My samsung rear projectiontv is showing in 3d
Hi, your convergence circuit has failed, the stk`s and any burnt resistors will have to be changed, if you know how to solder and un-solder proficiently and can use a volt meter it`s do-able if you don`t have this knowledge call a tv tech, generally runs $250 to $350 depending on where you live, call around and ask for estimates to fix the "convergence circuit", if you still have questions e-mail me back, Happy New Year, BMW Rider
Dec 26, 2007 | Televison & Video
Convergence problem with samsung sp42w5hfx
Hi.
Post your email address & I will send convergence set up manual.
http://dysonmanuals.inc.io/
Chris..
Nov 04, 2007 | Televison & Video
Samsung HC-P4752W 47" Rear Projection HDTV-Ready Television Logo
373 people viewed this question
Henry  Thomas
Henry Thomas
