Question about Reddy HD30 Heater
Infra red heaters wont stay lit flame in the tubes
This heater is new ,everytime i light both heater heads they stay lit for a few minutes then the flame seems to go back in the tubes behind the screens .is what they call flashback if so what is the problem and how can i fix it ?
I purchased the same heaters and encountered the same problem. I found the problem to be with the gas. I purchased a new tank from a different retailer and the heater now works fine. Not sure if there was condensation in the tank or what the difference was but this worked for me.
Posted on Mar 06, 2009
    Scholar:
    New Friend:
  • 70 Answers
Have you tried to heat up thermal couple for a couple of minutes. It takes a few minutes for the flames to actually starts heating thermal couple you might have to move thermal couple a little closer to heater flames
Posted on Jan 21, 2009
New kozy world natural gas heater. Pilot light wont stay lit snd heater flame wont stay lit.
Are you holding down the pilot light button long enough for the heat sensor probe to get hot and turn on the gas valve? It takes up to 3 minutes
Nov 20, 2016 | World Heating & Cooling
Pilot turns on and so will unit for about. 5 minutes...pilot flickers as if there were air blowing into it...any suggestions? It is. A Pro-com MD100TBA
the flame confirmation thermocouple might need looking at biased on your description , this item sits inside a stainless steel metal tube that's about 1.5 inches long an is someplace around the edge of the heater , this item confirms that the main flame has lit and shuts off the pilot most times too . this is why I believe it is not working
Jan 18, 2016 | Procom 10K BTU, Vent Free, 2 Plaque...
I have a Mr Heater infra red propane wall heater. My problem is it turns itself off (pilot light) after running for an hour or two. I have no problem getting it turned back on but for some reason it d
Your pilot flame should be blue with a small yellow tip, and it should cover the thermocouple (a small rod in front of the pilot light). If the flame is too small and doesn't cover the thermocouple, it may be adjusted too low, or you have low gas pressure or you have a leak in your gas line coming in to the heater. If the flame looks like a lazy yellow flame, you are probably not getting enough air to the flame. Check that your air openings around the pilot are not clogged up. If the flame looks like a waving blue flame then you probably have excessive draft at the pilot. If the pilot flame looks good and covers the thermocouple, then the thermocouple might be bad. Best of luck. I hope I have helped.
Nov 23, 2013 | Heating & Cooling
I have a model VN3000D Infra-Red heater and it WOULD burn on the #1 setting but now won't stay lit at all. The pilot is a blue flame with small yellow tip and is on natural gas. Is this a thermocouple...
Any time you see yellow tip on pilot it a sign that pilot needs cleaned. Use air to clean it then relight, look to see that the tip of thermcouple is in the pilot flame. your pilot light would out as soon as you release the pilot starter button if it was thermcouple. You can go on line and find all like of heater parts. My shop has nine instock.
Feb 07, 2011 | Vanguard International VN30TB Infra-Red...
Wont stay lit
If dust gets into the pilot safety device called an ODS (oxygen depletion sensor) then the safety thinks the air is low and kicks the pilot off. To remedy it I flush the pilot with a little rust buster. This cleans the dust out without disturbing the air flap. I have repair photos and a neat demo video that shows how it works HERE
Feb 21, 2010 | Dyna-Glo D-E36 Infra-Red Wall Mounted...
Pilot flame burns above pilot tube in propane heater. the sensor does not register. the pilot top of the tube shoul glow red. I have cleaned the tube, in few occasions it has lit and worked for above 10 to...
Hi it there a leak on the pilot causing it to burn that high can you adjust the pilot gas going in to the pilot ?
have you cleaned the pilot injector out or is the hole in the injector too big
Jan 25, 2010 | Williams 2509612 Ceramic Mid-Size Heater
Pilots lites , holds ok for minutes,but once move
Hello KJGreen, It sounds, based on your description, as though the thermocouple is faulty and should be replaced. If the pilot light stays lit and you've left it on for several minutes before turning the knob on to light the log set, then that indicates that the thermocouple is bad.
The thermocouple is a safety device (heat sensor) designed to stop the flow of gas to the burner in the event the gas flame goes out and the pilot goes out. The sensor will only allow the gas valve to open once it has reached the preset temperature.
To confirm that the thermocouple is defective, I would light the pilot light and allow it to remain lit for up to 10 minutes before I attempted to turn on the log burner. If, after 10 minutes, the log burner still won't stay lit, then you know that the thermocouple needs to be replaced. Otherwise, the burner should light, since after 10 minutes, the sensor should be hot enough to signal the gas valve to open.
If you are going to have this replaced, please make sure you use only an approved supplier, since an incorrect replacement part could cause an unwelcome malfunction of the gas log burner. Safety should be primary when dealing with open flame burners.
Hope you find this Very Helpful and best regards!
Nov 23, 2009 | Vanguard International Infra Red - Large...
Pilot light won't take
If it goes out after being lit for 30 seconds, you need a new thermocouple. That's the tubelike piece that the flame touches. You can possibly just put in a universal thermocouple. They cost less than $5 at most hardware stores.
Jan 03, 2009 | Vanguard International Infra Red - Large...
Blue flame heater pilot wont stay lit
There is a therma-couple that the flame burns against. When it is working correctly it allows gas to travel to the flame. When it goes out you get no gas, as a safety feature. Replace the therma couple and it should work again.
Oct 06, 2008 | Dyna-Glo D-E36 Infra-Red Wall Mounted...
Wont stay lit
go to this site www dot desatech dot com. Here you'll find parts to repair your heater. a propane heater uses a millivolt generator to sense the flame. along it's cappilary are two push on spde connectors. these connect to the high limit temperature sensor which is mounted on the flame backplate of your heater. to see if it is the high limit shutting down your heater, jumper across the two spade connectors. if the heater stays on, this is your problem. if the flame still goes out, then the millivolt generator is shot.
Nov 09, 2007 | Coleman 5075751 Utility Heater
Reddy HD30 Heater Logo
205 people viewed this question
Top Reddy Heating & Cooling Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Mack Baxter
T bone 1963
Are you a Reddy Heating and Cooling Expert? Answer questions, earn points and help others
