Question about Leadtek WinFast PVR2000 Video Capture
Using TV card on PC video perfect no audio
Present settings run builtin DVD player and play audio files - However I cannot get sound on the TV any advise
WinFast PVR
Leadtek Research Inc.
Version 3,1,1,6
TV533 Series
  • 3 Answers
SOme PVR cards need a small cable from PVR card to the Sound card input to play sound via the sound card.
Posted on Jan 16, 2009
Audio out of sync
There could be a few different problems. You should first narrow down the possibilities. If you are playing the mp4 file directly from your laptop try changing the source. Put the mp4 on a usb drive or on a playstation/xbox or simply on a dvd. Try playing the file through one of these other sources. If the audio no longer lags behind the video than its likely an encoder setting that your Hisense doesn't handle well. If lagging is still present on all your sources then change the type of cable. If you are using HDMI try RCA or vice versa. You can also separate the audio from the video. Try using a VGA cable between your laptop and TV for the video and use a separate RCA to 3.5mm headphone jack for the audio, Most Flatscreen TVs have dedicated audio inputs for different video inputs. Try out these different set ups and you can determine if the problem is with the TV the Laptop or the cables in between. If it is the TV you may have a problem with the main board but this is unlikely especially if the audio video sync works fine with other file types.
Jan 27, 2014 | Hisense Televison & Video
No audio after recording from sat. Reciever
Double-check your input cables from the receiver to the LG 389. Do you have the sat. receiver AV out connected to the front AV In on the LG DRT389? Make sure that you haven't mixed up the L and R audio connections on either side. (I've done something similar with RCA cables myself.) Next, try a different set of cables.
If that doesn't work, there may be a problem with the audio jacks on either your receiver or the 389. To check, plug the AV cables from the Sat. Receiver directly into the TV. If you have sound and video, then the input jacks on the recorder may be damaged.
Try using another input. (It looks like some models have the SCART input; you may need to set the input source in the menu under AV2 Decoder.)
The fact that you have audio output on USB and DVD's means that cables/connections between the LG289 and the TV are fine.
I hope this helps. Please add a comment with the details of which AV port you are using on the LG389 for additional assistance.
Aug 31, 2012 | LG DR389 MULTISYSTEM DVD RECORDER FOR...
Surround sound not playing TV audio
you need to run red and white from your tv to the surround sound and the same from your dvd to surround sound
May 02, 2017 | Sony Audio Players & Recorders
Can't record audio
I have converted home videos on my PC this way. I have a Sony camcorder whose output connects
to my firewire card in the PC. I also use windows Movie maker. While it is recording, I don't hear the audio. After saving the file and playing it back, I hear the audio, along with seeing the movie. Windows movie maker allows me to stop, start, and record the movie. It has complete control over the
Sony camcorder by using the firewire port on the PC.
Dec 21, 2008 | HP Pavilion Media Center TV m7350n...
How to Hook up ATI 9600 to PC
Did you switch the TV input to S-Video on the TV control panel (usually accessible via the remote)? You will also likely need to fit a 1/8" (mini-headphone jack) connector from your PC to RCA (Red and White audio standard) connectors on the TV - this cable can be purchased in many places. The S-Video connector doesn't carry audio like an HDMI connector will.
Dec 16, 2008 | Abit AGP Video Cards: /ATI 9600XT 256M...
My system hp pavilion dv4000 cannot play out audio and picture from my dvd and window player files, no sound card foud
make sure you got the right drivers for your unit... specially if your using operating systems that exactly supports that drivers you 've loaded with...
Aug 13, 2008 | HP Pavilion dv4000 Notebook
Go to HP's website and search the model number of your PC. You will see options for downloading the drivers for it.
Aug 05, 2008 | Computers & Internet
Trensferring Files to PC
The codec needed to extract audio is not present in your computer. Maybe you need to install all the application program from the CD/DVD enclosed in your Camera. Or you can use other player other than windows media player.
I recommend you to download the player that content multi codecs, the link is here: http://www.free-codecs.com/download/Media_Player_Classic.htm
may this solve your problem.
best regards, melnavz
Feb 24, 2008 | JVC Everio GZ-MG130 Camcorder
Samsung DVD-SH853M HDD/DVD Recorder/Digital Receiver
Make sure you are not using DVD+R dics - the player won't play these. It is OK with DVD-R.
Jan 21, 2008 | Samsung DVD-HD950 DVD Player
Sony DVP-NS315 cant play only Video Disc
If you are using just a "yellow" ended cable for the video, maybe your custom settings are set to use "component"? I have been using this same dvd player for a while with the component video out and it works fine. I hope this helps.
Sep 30, 2007 | Sony DVP-NS315 DVD Player
Leadtek WinFast PVR2000 Video Capture Logo
458 people viewed this question
Top Leadtek Televison & Video Experts
Are you a Leadtek Televison and Video Expert? Answer questions, earn points and help others
