Question about GE 29875GE Digital Answering Machine
Light stays on eight
I ve done all from unplugging ect and the number is still 8 on the machine nothing works
  • Anonymous Jan 17, 2009
    I have the same problem and tried the same solution as you did - I can't find a manual on-line or at my house...anyone have any ideas?
I TRIED ALL THAT WAS SUGGESTED TO NO AVAIL. THEN I REMOVED THE UNIT FROM THE CORNER OF THE COUNTER WHERE IT IS VERY COLD TO A WARMER AREA. WAITED A HALF HOUR AND PLUGGED IT IN AND IN THREE SECONDS IT RESET. I GUESS THE VERY COLD AREA EFFECTED THE UNIT. THANKS TO ALL!! - I WAS ON MY WAY TO BUY A NEW ONE. HPEDY
Posted on Jan 17, 2009
I tried all recommended proceedures and none worked. thanks to all . I will buy a new machine today. hpedy
  • 3 Answers
I had this happen recently due to a power outage. I found my manual and to reset you need to unplug the unit from the socket it self AND the back of the machine. I tried just unplugging it from the back of the machine and this did not work. When I did BOTH things, the machine reset. At least give it a try...
Okay I have been using my HP G61, for a while now. I bought it 3 months ago. And I used it for college everyday. I used it last night before I went to sleep. I've closed it and left it charging all...
Restart your computer repeatedly tapping the f8 key to enter safe mode while the screen is black once in safe mode where the only things working will be your keyboard and mouse allowing you to attempt to repair your computer You could select the option start at last known configuration that worked this will tell you if and what file has been corrupted or missing then you will know if its a hardware issue You might use the system restore to restore your system to an earlier time click start all programs If it is a hardware issue the system restore might not work Restart your computer repeatedly tapping the f8 key to enter safe mode while the screen is black once in safe mode where the only things working will be your keyboard and mouse allowing you to attempt to repair your computer. Use the system restore to restore your system to an earlier time click start all programs accessories system tools you should see your system restore option if it is a hardware issue the system restore might not work Manual restore points that you specify with the System. Configuration utility Installation restore points that occur before you install a program or a service you can use the system checkpoints or the installation restore points to restore your computer's settings to a date when it operated correctly. This may also help determine the cause of the configuration error.
To perform a system restore, follow these steps:
1.Click Start, click Run, type msconfig, and then click OK. 2.On the General tab, click Launch System Restore. 3.Select Restore my computer to an earlier time, and then click Next. 4.Calendar dates in bold are possible restore points. Click the most recent one to view system restore information. 5.Select a system checkpoint or an installation restore point, and then click Next. 6.Close all other programs. 7.To start the system restore, click Next. 8.Your computer restarts. Repeat steps 1 through 8 until you fix your configuration issue.
Feb 28, 2013 | Computers & Internet
Tip
The Fisher & Paykel Smart Drive and EcoSmart electronic washing machines are...
The Fisher & Paykel Smart Drive and EcoSmart electronic washing machines are equipped with fault detecting software to help easily determine the cause whenever a problem occurs. Not like other electronic washing machines, these ones do not have displays to flash the code, but rather use the eight (8) light-emitting diodes (LED) of the Wash Progress indicators to indicate the fault code. The eight (8) LEDs stands as an 8-bit binary number (zeroes and ones) that must be decoded and then converted to the decimal number system to get the fault code.
The fault code can be decoded by determining which Wash Progress LEDs are lit. Once determined which of the LEDs are lit, write down the 8-bit binary code; 1 for lit LEDs and 0 for the off ones. For example; the final wash, rinse, and spin LEDs are lit; the binary code is 00001101. This in turn can be converted to the decimal number system by multiplying each digit with its corresponding place value then adding up the result. From left to right, the place values are 128, 64, 32, 16, 8, 4 , 2, and 1 respectively. Therefore, the decimal equivalent of 00001101 is 128(0) + 64(0) + 32(0) + 16(0) + 8(1) + 4(1) + 2(0) + 1(1) = 8 + 4 + 1 = 13; the fault code is 13.
on Apr 17, 2010 | Electrical Supplies
Tip
Decoding Fisher & Paykel Electronic Washing Machine Fault Codes
The Fisher & Paykel Smart Drive and EcoSmart electronic washing machines are equipped with fault detecting software to help easily determine the cause whenever a problem occurs. Not like other electronic washing machines, these ones do not have displays to flash the code, but rather use the eight (8) light-emitting diodes (LED) of the Wash Progress indicators to indicate the fault code. The eight (8) LEDs stand as an 8-bit binary number (zeroes and ones) that must be decoded and then converted to the decimal number system to get the fault code.
The fault code can be decoded by determining which Wash Progress LEDs are lit. Once determined which of the LEDs are lit, write down the 8-bit binary code; 1 for lit LEDs and 0 for the off ones. For example; the final wash, rinse, and spin LEDs are lit; the binary code is 00001101. This in turn can be converted to the decimal number system by multiplying each digit with its corresponding place value then adding up the result. From left to right, the place values are 128, 64, 32, 16, 8, 4, 2, and 1 respectively. Therefore, the decimal equivalent of 00001101 is 128(0) + 64(0) + 32(0) + 16(0) + 8(1) + 4(1) + 2(0) + 1(1) = 8 + 4 + 1 = 13; the fault code is 13 which is a pump fault.
Once the code is determined, search the web for the meaning and indicate it when requesting for an online assistance to facilitate a quick and precise response.
on Apr 14, 2010 | Fisher and Paykel GWL11 Top Load Washer
Maha MH-C800S Flashing "Done" on all 8 lcd indicators
Mine is doing this too. Despite making several attempts to get a reply about this on this site, only other references to this selfsame question are forthcoming. My guess is the charger is gubbed and you need to go back to the seller if still inside warranty. In this case mine is Tantronics in the UK - the importer is Nevada radio, also UK.
Feb 03, 2013 | Maha Group Maha PowerEx MH-C800S 2-Hour...
2006 ford escape.. #1. abs light on & stays on. #2. 4wd light comes on,flashes 8 times then gos off
Changing the sensors &/or tone ring may work temporarily but it won't last. I have a 2005 and have had it done and it kept happening. Had it serviced at dealer, asked dealer how to fix it or make light go out and on and on....after I think 5 yrs. it is still on. It hasn't affected my vehicle as far as I can tell. Comes on blinks 8 times, goes off....drive another 8/10ths of a mile and it comes back on, flashes eight times...and so it goes tidily bomMust be an Escape kinda thing.
Jan 30, 2011 | 2006 Ford Escape
The washer is not getting water, I checked hoses and conections, and valves, it did this before when i unplugged and plugged it back in it worked not anymore
1 check water filters, on the taps and machine
2 check to safety lock switch is still working, nothing will work untill safety lock switch working.
3 replace electronics board with second hand board
4 if lights up, on the eight lights you should have a fault condition
Sep 21, 2010 | Fisher and Paykel GWL11 Top Load Washer
Constant number 8
I called GE. They said unplug phone lines, then unplug power source, wait 10 to 15 minutes, then reconnect in the same order. If that does not reboot the answering machine, then buy a new one.
Dec 11, 2008 | GE 29875GE Digital Answering Machine
Message shows full
I had the F problem, I have the 29868 Digital Messaging System ( GE) In desperation today I unplugged it and unhooked the battery. When I plugged it back in the F was gone, when I hooked the battery back up the F stayed gone. Go figure !!!
Sep 08, 2007 | GE 29868GE1 Digital Answering Machine
Phone lock code is on,forgot 4-8 digit answer
try 123456.or you make new format,but remember to save u data or it will lose.if you not sure i think u sent it to shop..
Jun 13, 2007 | Sony Ericsson K700i Cellular Phone
GE 29875GE Digital Answering Machine Logo
244 people viewed this question
Top GE Lands Phones Experts
Computer Repairing
Computer Repairing
Are you a GE Lands Phone Expert? Answer questions, earn points and help others
