Question about Toshiba Satellite A135-S2276 Notebook
R15s829 tablet fails to fully boot
Systrem will operate when running the recovery disk but after recovery still will not fully boot.  Does get to safe boot option and if safe is chosen the system stops after about one full page or messages-always in the same place.  On initial boot, the screen shows the toshiba logo and 2 shadow copies
  • Gyanendra Kumar May 11, 2010
    did you try the recovery after breaking and repartitioning the HDD??
    Problem Solver:
  • 4 Answers
Try reinstalling windows vista. back up your data and reinstall using the recovery disc
Posted on Jan 29, 2009
My alienware with windows7 will turn on but has a missing operating sys message. I can't start it in safe mode.
In the bios see if you can run a HDD check/scan.
Do you have a Windows 7 recovery disk (DVD)
If you do boot from the recovery disk. you should be able to recover the OS.
Or even use some tools to check the HDD (Hard Drive)
Normally this can either be a corruption, or a failed HDD.
Apr 03, 2014 | Alienware PC Systems Alienware Area-51®...
"drive 1 wdc wd10eads 00m2B0 fail return" Add more to question pc powers up goes into widows 7 then the arrow stays on screen , for ever . And I can not boot from cd reports it can not find device ?
sounds like the Hard Disk is failing. try booting into safe mode by Pressing F8 Before the Windows 7 Splash Screen. The run diagnostics on the C Drive. Open Recovery by clicking the Start button 4f6cbd09-148c-4dd8-b1f2-48f232a2fd33_818.jpg, and then clicking Control Panel. In the search box, type recovery, and then click Recovery.
You can use Recovery to restore the state of your computer's system to a previous point in time, or restore the contents of your hard disk from a backup. You can also reinstall Windows from a recovery image installed on your hard disk.
Oct 10, 2013 | Dell Computers & Internet
Won't boot disk light steady on
unplug and wait a min. or so, plug in, try again. if that fails, reboot, try a system restore/recovery. If that fails, boot to safe mode with networking, download MALWAREBYTES freeware at : http://www.filehippo.com/download_malwarebytes_anti_malware/ Run a FULL SCAN, DELETE ALL RESULTS, REBOOT. For further assistance respond to this post.
Dec 23, 2012 | HP Pavilion a450n PC Desktop
Can't get computer to open in safe mode
Run the Check Disk Utility, you've got some missing or corrupted boot or system files.
To run the check disk utility you will need a repair disc or a operating system disc. Put the disc in the cd drive and boot from it. You want to get to the Dos Command Prompt (Black screen with white letters) and type the following command: chkdsk /r
Check disk will run well over an hour or two and you will notice the percentages going from high to low, this is normal. Let it run to completion. Then reboot machine.
If check disk fails to solve your problem you might have to reinstall windows. Try doing a Repair Install that way you don't loose your data, documents, music, pictures, videos or programs.
In windows xp you get to the dos command prompt by selecting R for repair when the options appear.
In Vista and Windows 7 you want to get to the recovery console and look down at the bottom of the window for the Dos Command.
May 12, 2012 | Computers & Internet
My asus u52f-bbl9 doesn't want to move past the boot screen
Have you tried booting into Safe Mode?
To run the check disk utility you will need a repair disc ora operating system disc. Put the disc in the cd drive and boot fromit. You want to get to the Dos Command Prompt (Black screen with whiteletters) and type the following command: chkdsk /r
Check disk will run well over an hour or two and you will notice thepercentages going from high to low, this is normal. Let it run tocompletion. Then reboot machine.
If check disk fails to solve your problem you might have to reinstall windows.Try doing a Repair Install that way you don't loose your data, documents,music, pictures, videos or programs.
In windows xp you get to the dos command prompt by selecting R for repair whenthe options appear.
In Vista and Windows 7 you want to get to the recoveryconsole and look down at the bottom of the window for the Dos Command.
If all fails Sounds like your operating system needs to be reinstalled or you can do a system recovery to set it back to when you first bought it.
Apr 09, 2012 | ASUS U52F-BBL9 Laptop
I have an Acer TravelMate 4500 512Mb Ram an 80GB HDD, which doesn't run the operating system boot after bios boot. when I swich on it comes up a bios boot and after that the laptop screen's becomes...
1. Remove or Unplug any recently added hardware.
2. Remove and replace the battery.
3. Press and hold the power button for 7-10 secs to power ON the computer.
4. Try booting to windows Operating System in Safe Mode. (Press F8 key as soon as you restart).
5. Check if the Hard Disk is detected and listed with its capacity of 80GB in BIOS. (Press F2 as soon as you restart).
6. Reset BIOS to default values.
7. If computer boots to windows in Safe Mode, then perform a system restore to an earlier date.
8. Install any updates available for BIOS.
9. If Hard disk is listed in BIOS, perform system recovery using the recovery partition or the recovery discs.
10. If Hard disk is not listed in BIOS, contact any nearest service center to get the computer serviced.
Jul 23, 2011 | Computers & Internet
My computer won't open windows i can only open it in safe mode.
In safe mode try run your AntiVirus app.If you can,t you problably had a bad infection the i think you will nned a BOOT Disk to restore the OS.
Oct 03, 2010 | Computers & Internet
Failed to read instructions at 0x00dd1b39 at 0x00000000 when booting up
This is not (directly at least) an hard disk problem but an error in some software. It could be that a damaged hard disk is making the wrong code execute, but I think likelier that you have a damaged operating system.
If it's a Windows OS, as the message suggests, try booting from the recovery CD and performing a repair (or a System Restore from a recovery point when the system was working), or try booting in Safe Mode by pressing F8 key at startup.
Feb 24, 2010 | Computers & Internet
Recovery CD not loading onto Hard Drive.
Your optical drive is not reading the disk properly - a common issue as time goes by. Replace drive with a good known working unit and your recovery operation will take place.
Mar 27, 2017 | Itronix GoBook XR-1 Tablet PC
Trouble booting!
You could attempt to boot to safe mode, and run the Start> System Recovery > PC Recovery Application.
Otherwise, I'd boot to safe mode, select start, run, type: msconfig, select the startup tab, remove any unwanted startup items that may be causing the system crash.
Hope this helps.
Jan 08, 2009 | Panasonic TOUGHBOOK CF-18 Tablet PC
Toshiba Satellite A135-S2276 Notebook Logo
78 people viewed this question
Top Toshiba Computers & Internet Experts
Brian Sullivan
Brian Sullivan
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
