Question about Burton P1 Snowboard Bindings 2008
How to fold down the back to a burton p1 binding
I want to adjust the strap, but can't lower the back to get to the other screw. Any tips?
  • 39 Answers
They lock into the bottom of the bindings but they should just snap forward.Look for a small lock on the back o the bindings(like a clip) if there isnt one but they wont fold with just pressure take a phillips screwdriver and loosen the two screws on either side that hold the backplate up. They should fold easier then.
Posted on Mar 27, 2009
Broken esp youth suprahero strap
Broken esp youth suprahero strap - Fixya
www.fixya.com/support/t15750244-broken_esp_youth_suprahero_strap
Jan 8, 2013 - broken esp youth suprahero strap - Emsco ESP Youth Suprahero Snowboard question.
Where to order replacement strap for Emsco ESP Youth ...
www.fixya.com/.../t22712551-order_replacement_strap_emsco_esp_you...
Jan 6, 2014 - Where to order replacement strap for Emsco ESP Youth Suprahero ... The red foot strap broke - Emsco ESP Youth Suprahero Snowboard ...
ESP Youth Suprahero Snowboard ' DICK'S Sporting Goods
www.dickssportinggoods.com/product/index.jsp?...
Dick's Sporting Goods
Rating: 3.1 - ‎31 reviews - ‎$24.99 - ‎In stock
Shop ESP Youth Suprahero Snowboard at DICK'S Sporting Goods. Find more ... It has adjustable plastic straps that easily fix over your child's snow boots. .... Nice board for a kid to use on sled hills but binding broke after minimal use. Value.
Burton 07 Custom S Bindings Snowboard Binding Small ...
Jan 08, 2013 | Emsco ESP Youth Suprahero Snowboard
Snowboard boots with reduced length
You may also want to look at how you are setting up your bindings. I have a US 11 foot (29 cm) and with my bindings set correctly have never had any issues with toe or heal drag.
The best way to set up your bindings it to take them off, remove the mounting screws, keep the base plates in and fit your boots into your bindings with the straps still undone. Then, with the board on the floor, position the binding at the angle you like (roughly) and look to see when the toe and heel over lap is even or if you are like me pull the bindings back slightly so that you have little or no toe drag and just little heel drag. It works a treat and I have done this for over a hundred customers over the years.
Mar 15, 2010 | Burton Boxer Snowboard Boots
Boy just got a burton hero board, put on his danny kass bindings. The EST system for binding attachment seems to stink. Only two screw attachment, they immediately loosen up. How to attach tighter?
The Hero is designed to work with Burton's special two bolt system. The base plate on the Burton bindings is much stiffer than standard (like the on the Kass's) so will flex and loosen quickly. The best solution if these were both bought together from a store is return them as they should not have been sold together. If this is not possible then sell the bindings and buy the correct Burton model. If this is not fixed the mounting screws will eventually damage the board and need costly repairs.
Mar 06, 2010 | Burton Winter Sports
Replacing plastic strap that hold the toe cap.
You just need to remove the binding form the board and look underneath the binding. If it doesn't drop out by itself just lever the broken piece out with a flat head screw driver. Once this is done you can insert the new part screw on the cap strap
Mar 04, 2010 | Burton 07 Custom S Bindings Snowboard...
Hi i need a replacement front toe strap for LQ 1500 LS3
Is this for the binding? you may be able to buy a toe-cap strap set from Burton or Ride (both sell sets for around 30.00) You will have to compare the mounting design of the toe ******** the burton/rides vs your binding
Feb 13, 2010 | Liquid Force Winter Sports
I just want to ask if the Burton P1.1 2009 LARGE bindings will fit to my 24cm width board Thanks in advance
Should do... Though to be safe I'd take a measurement of the board width to the shop with you and have a look at the bindings on a board of similar width..
Better still bring the board and your boots in with you and have them fit the binding and then try it for feel before you buy..
Sep 30, 2009 | Burton P1 SNOWBOARD BINDINGS SIZE LARGE...
Snowboard binding
No womens large bindings are rated womens size 8 or larger, and mens 7-9. If you have burton bindings you can shorten the adjustable strap. but make sure you strap in and when you crank down the straps you should not be able to move your boots or wiggle them around.
Feb 26, 2009 | Flow M9 Snowboard Binding
I cant change a ankle strap
get some flow bindings...lol. you might want to try to use a little lubricant like wd-40 where the release button is on the ankle strap, they do tend to stick and make it difficult to remove straps.
Dec 28, 2008 | Winter Sports
I don't know how to change the ankle strap
You have to losssen the screws on the sides with the 04 models i believe. otherwise you push down and the pull the strap to the sideand it should pop out when you pull it back up. But I think the 04 year was screwed ninto the base.
Dec 28, 2008 | Burton GRIP FIT CAP STRAPS FOR SNOWBOARD...
Snowbard bindings adjustment
"With everyday use, the screws, nuts and bolts that hold the highest stress areas together tend to loosen up. Consequently, they need to be tightened regularly to ensure that a strap doesn't fall off and get lost. However, not every Mountain Resort provides tool stations, so it's important to have a Snowboard Tool within reach (preferably in your pocket) at all times. Remember, a snowboard tool is a small investment that will definitely pay off over years of riding. Also, with the standardized insert pattern of snowboards, and with the built-in adjustment capacity in most Bindings, Mounting and Adjusting Bindings has become simple quite a simple task. To be able to do this, make sure you have a screwdriver and a wrench or two. Also, it would be a plus if you have some basic knowledge about the stance width, stance location and stance angle. The distance between your front and rear foot is the Stance Width. The basic stance width is roughly the length of your shoulder-width apart (about 30 per cent of your height). The location of the center point between your Bindings relative to the center of the snowboard is the Stance Location. Conversely, the angle of the Bindings across the snowboard's longitudinal axis, wherein zero degrees represents a line that is perpendicular to the snowboard's length, is the Stance Angle. * Forward Lean For starters, check your board's Forward Lean. The forward lean is the amount of forward angle on the highback support. For more leverage and more responsive heelside turning, add more forward lean. By adding forward lean, you also force your knees to bend, consequently ensuring a good riding stance. Still, too much forward lean makes your knee bend too much. Over bending your knees put pressure on your quadriceps muscles and reduces your ability to turn easily. So don't overdo it. You can usually adjust the forward lean in soft-boot Bindings by changing the position of a plastic stay behind the highback. * Rotating the Highbacks You can easily rotate your Bindings' Highbacks if your bindings have slots on the hinges where the highbacks are fastened to the binding's baseplate. To make your heelside turning more responsive than when it is angled along with the baseplate, adjust your Bindings in parallel with the Snowboard's Heel Side Edge. You can do this by loosening the bolts and rotating the highbacks. * Adjusting Strap Position Generally, this involves unscrewing the straps from the baseplate and moving them forward or backward on the Bindings. To improve control, move the straps higher up on the foot. Conversely, move them down lower to increase flexibility. Make sure that the toe strap is resting around the base of your toes and is securely holding down the tip of the boot. Shorten your straps if you find yourself pulling on them for a snug fit. You can do this by fastening the straps to the baseplate further along the length of the strap. Most straps already have extra holes for this adjustment."
Dec 01, 2008 | Flow M9 Snowboard Binding
Burton P1 Snowboard Bindings 2008 Logo
582 people viewed this question
Top Burton Winter Sports Experts
vtrktrmn
Todd Arndt
Todd Arndt
Are you a Burton Winter Sport Expert? Answer questions, earn points and help others
