Question about Durabrand PDV-709
Ya my cord is showing copper wires where can i get a new charger
    Champion:
  • 303 Answers
Can I replace the plug *only* on this range with a 3-prong plug? I believe I need a copper strap to ground from the neutral wire on the back of the range to the frame, but I want to know if it's OK to
When you buy a new appliance that needs a cord, usually the screw that connects the neutral (white wire) is bridge with the cabinet or ground,with a piece of copper, that should be removed when you are going to install a 4 prong cord and the green from the cord goes to ground or chassis.
Neutral and ground have the same potential in normal condition.
Since 4 prong is safer than 3 prong, and is required to meet code,
I suggest replacing the female plug for a 4 prong instead.
Dec 07, 2014 | Dryers
How do I replace a power cord on hoover u6311?
Heat shrink wrap not electrical tape since it can peel away
New cord longer is better in my opinion
Wire cutters
Or Wire extension or splice adapter
If the wire is brown copper use a new copper wire if it is silver aluminum use a new aluminum wire.
Jun 28, 2014 | Bissell 6594 PowerForce Bagless Upright...
Fuji jx520 wont charge
Your battery probably is in the wrong way.So take it out and look on the bottom of it.You will see 3 copper cubes.Next look in to the slot where the battery goes and you will see 3 metal wires.Now take your battery and carefully line up the copper slots with the metal wires.Then push the battery in and close the battery slot.And your done go plug it into your USB slot and you will see a white battery symbol and you will know that it is charging.
Simple fix for a simple problem.
Aug 29, 2012 | Fuji film FinePix Z70 JX520 JV200 Z900EXR...
The power inpot is blinking and not connecting
The laptop is either in sleep mode or the battery is low. If the laptop doesn't want to wake up, try unplugging the charger cord, then removing the battery (usually by sliding something on the bottom of the laptop to unhook it). Wait for 30 seconds then put the battery back in, plug in the charger and press the power button.
Mar 05, 2011 | HP ProBook 4510s FM849UT Notebook
Iron cord twisted and my husband says dangerous. Can this be fixed as iron is otherwise OK?
If there are bare As in the copper is showing wires then it IS dangerous. If it is just the wires twisted then just straighten it out the best possible and you will be okay.If the wires are frayed to the point of the copper showing then you need to have the cord replaced. However, unless this is a fancy iron you will be better off throwing it out and then buying a new one rather then paying the bucks you will need to to have the cord replaced...
heatman101
Oct 04, 2010 | Sunbeam Microwave Ovens
Hi.i got a new dryer and its 3 prong but the house is 4 prong so i got a 4 prong and im not sure where the wires go. The diagram shows L1 N L2 than the green ground but the new 4 prong only has green red...
Ok. Let's simplify this for you. First and foremost you will want to remove the copper strip that goes from your center cord post the to case/cabinet of the dryer. This is to seperate your neutral and grounds within the machine. Some models used a green jumper wire instead of a copper strip but the idea is the same.
Now on the new cord the green (ground) wire is supposed to go to the connection point the copper strip used to go to on the cabinet. The white wire (neautral) is supposed to go to the center terminal connection on the terminal block and the red and black (L1 and L2) wires can go to either of the outside terminals.
The only difference in a four wire cord application is the segregation of the electrical neutral and the ground wires.
Good luck, hope this helps you!
Jun 26, 2010 | Frigidaire GLER341A Electric Dryer
When plugging in the dsi charger the orange lite comes on for anout 3 seconds then turns off
Maybe It's because it's chewed up (mine was chewed or something so I got a new one... I've been in the same situation, bud, but I couldn't do anything about the copper wire showing underneath.). Make sure to check the entire cord.
1) Try flicking on a power switch.
2) Unplug the actual charger from the wall, and plug it into a different outlet. The outlet you're using may be broken.
3) Make sure the charger is all of the way plugged into your DSi.
Really hope this helped!
Mar 27, 2010 | Nintendo DS Lite Console
Need to know how to convert the three prong cord to a four prong cord
You will find a black, a red, a white and a green or copper wire in your new cord. You will find a place for a red, a black and a white wire on the terminal block in your machine. The green/copper goes to the frame of your machine. If there is no place to fasten it, drill a hole in the body and fasten the green/copper ground to the body with a 10/24 or equal nut and bolt with washer. It should be about 1 inch long to facilitate your installation process.
I trust this will help you solve your trouble
Thanks for considering FixYa.com
please vote
tghanks
Dec 04, 2009 | KitchenAid KEYS700LQ Electric Dryer
Tdk mp100 headphone jack
Each of the rubber covered cords running to each ear piece has two fine strand wire bundles inside. The right ear piece has a red colored strand and a copper colored strand. The left ear piece has a green colored strand and a copper colored strand. The wires are coated with an insulation lacquer. The lacquer burns off when you heat the wire for soldering.
Repair item: 3.5 mm stereo headphone jack, shrink tubing
Plan for strain relief:. These headphone wires can't take any tension at all. You need to crimp the black cords to the headphone jack somehow.
Slide strain relief and headphone jack housing over the over the rubber covered headphone cord.
  • You need to plan a way to relieve the pulling stress on the solder joints where the two headphone cords enter your replacement headphone jack.
  • Try shrink tubing if you have it.
  • If you have some thermal shrink tubing, slide a piece over the headphone cord end before stripping the wires.
  • Slide the headphone jack casing over the headphone cord also.
Strip each headphone cord 5/8" using the 18 gage setting of your wire stripper..
Hold each headphone cord in a "third hand" soldering assist tool and tease the green, red and copper bundles apart..I wore a 10x Magnavisor and I used a sewing needle and a bright light.
Twist the copper colored strands from both headphone cords together. They are the common ground wires. The copper colored bundle will attach to the headphone jack ground.
Apply a dab of solder to the end of each of the three bundles of wire. You will see and smell the insulating lacquer as it burns off. Keep most of the wire bundle cool.
Position the two strand headphone cord and the 3.5 mm headphone jack in the third hand soldering stand.
  • Plan where you can crimp the headphone cord. Crimp it when ready.
  • The green == left channel wire goes to the tip of the 3.5mm jack.
  • The red==right channel wire goes to the middle of the 3.5 mm jack
  • The copper colored wires go to the ground of the jack..
  • Measure resistance, 31 ohms per earpiece.
  • Screw the jack cover on and finish the strain relief craftsmanship.
Nov 28, 2008 | TDK MP100 Professional Headphones
Phone wont turn on or charge
check the batteries on other phone....or check the cord of ur charger...see to it r the battery pins cleanly connted to phone....n check the copper pins on battery lik r they loose or firm or damaged...or go to nearest service center n show ur batteries n they may giv an replacement....
ne other prob's do tell me..N plz do rate me
cya
Apr 15, 2008 | Motorola Mobility RAZR V3m Cellular Phone
Durabrand PDV-709 Logo
Top Durabrand Televison & Video Experts
matt martin
matt martin
Are you a Durabrand Televison and Video Expert? Answer questions, earn points and help others
