Question about Motorola Mobility RAZR V3
Keypad frozen, still receives calls
I have the same problem as some others on this site. No trauma or abuse to phone, but suddenly frozen and only occasional action from the keypad, but not reproducible, and always the wrong action, followed by error message "voice record memory full". Will answer a call if closed, but unable to answer a call if open when it comes in. Someone suggested a flash file solution but no instructions. Would really appreciate more info. Thanks.
  • 63 Answers
Hi, You don't need 2 flash your razr for this problem. What u need is a screen flex cable. The three buttons around the screen are controlled by a flex cable and the voice recorder is connected on this flex cable.This needs replacing but it's very tricky to deal with. I suggest a really good tech that deals with razr's to handle this problem to possibly replace the flex cable. This would solve yor frozen keypad problem. SAM !
Posted on Jul 13, 2007
SOURCE:
Screen all of a sudden is saying "Check SIM" or "Insert SIM" though no trauma has happened to the phone.
This "Insert Sim"(even though already Sim inserted means) or "Sim Error","Invalid Sim",are all problem arises means that Mobile Locked to Some Network,You need to Unlock it to use other GSM Sim Card,You can Unlock the Motorola KARMA QA1 model using the Unlock code at reliable price at this site
http://www.wickedunlock.com/motorola-karma-qa1/rs11wp9/
Jan 19, 2011 | Motorola Mobility Karma QA1 Cell Phone
Keys are not responding
Hello, what makes a phones keypad not to respond is when the IC that controls the keypad inside the phone is bad, it makes the keypad to freeze.
Also if there is dirt in the keypad, it can also cause the phone keypad to freeze.
To rectify problem you will assistance from a phone technician.
Jul 03, 2010 | Nokia 6120
My keypad on my Katana stopped working. Can only
Friend, Check the flex connection from the keypad interface then clean the board or the doom with pencil eraser
Jul 25, 2009 | Sanyo Katana SCP-6600 Cellular Phone
The keypad do not work
Either a software re flash may help or a keypad replacement. Usually facial moisture could be a cause of this. i would recommend trying a blow dryer on the keypad for 40 seconds with out the battery to see if that fixes the problem
Apr 06, 2009 | Motorola Mobility W490 Cellular Phone
Keypads frozen
try *2767*3855#........if that does not work then take the phone to your mobile service center and have it fix
Nov 17, 2008 | Motorola Mobility W510 Mobile Phone
Motorola razr freezing
your phone problem is the keypad flex of your phone'
you can fix it by replacing the keypad flex'
motorola dealer has the keypad flex'
ask for a skilled cellular technician to re-place your keypad fle..
i hope it will helf to your prob...
Jan 07, 2008 | Motorola Mobility RAZR V3
Frozen buttons except red end call button
it seems you have the common v3 keypad flex problem - normal issue - it costs $25-40 to replace depending where you do it.
we charge $25 + shipping
http://horizonwirelessonline.com
Dec 25, 2007 | Motorola Mobility Razor Behind-the-Head...
Keypad is frozen, cant dial out or recieve any calls
PSYCHMAJOR - take the phone back
guest - replace the flexcable
Sep 21, 2007 | Motorola Mobility RAZR V3c Cellular Phone
Key pad is frozen
is your phone been dropped or wet? check local service center near our place.
Sep 20, 2007 | Motorola Mobility RAZR V3c Cellular Phone
Keypad frozen
I'm not sure if flashing the firmware will solve your problem or not, but it seems to be a likely solution. Here is a link to a very good site on how to do that with a V3 http://www.themotoguide.com/flashingflexing.php
Jun 19, 2007 | Motorola Mobility RAZR V3
Motorola Mobility RAZR V3 Logo
222 people viewed this question
Top Motorola Mobility Cell Phones Experts
vince
D. E. Hev
Mark Magill
Mark Magill
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
