Recharge iVO Sound M850 MP4 Player
New product.
Right out of the box the player was left on.
CD program was loaded and the USB cable was used to connect player with the on position to recharge.
Player has been connected to computer for 2 hours without results.
When the player is connected to the computer the required screen does not come up for charging.
  • Anonymous Jan 24, 2009
    Mine states it is charging but does not charge.
Same thing happened to mine, I was told by a tech, to return it because it was a falulty product.
Posted on May 19, 2009
I have mitone mp4 player (MITMP26) 4 GB . I have a problem. USB device don't see my computer. Windows 7 64 bit. Please help me.
Hi, player not recognized by the computer
This may be caused by one of the following:
1. Minimum system requirements were not met.
2. Corrupted drivers.
3. Computer restrictions.
4. Power issue.
To resolve this issue, try the following solutions:
SOLUTION 1 - For brand new player or first time connecting to this computer.
For Windows XP users: verify the following operating system requirements are met.
- Windows XP SP2 or higher
- Windows Media Player 10 or higher
Download and install the latest Windows Media Player if it's not installed.
For Windows Vista users: If the player is seen in My Computer when using MTP mode, but not showing in Windows Media Player.
- Download the hotfix from http://support.microsoft.com/kb/939211.
- Run the hotfix.
For MAC users, see Sansa player not recognized by a MAC OS
NOTE: If you are trying to connect to a Computer at work that is part of a network, there may be user right restrictions that are set to disable access to new hardware or stop any program installations. You may need to check with your IT administrator to see if this is causing the problem.
SOLUTION 2 - Refresh the driver
STEP 1 - Connect the Sansa player to the PC
The screen on your player should turn on, show 'Connected' and indicate the battery charging or full.
- If the player does not turn on try other USB ports or on another computer if one is readily available. Ensure you are connecting directly to the computer USB port and not to a USB hub.
- If there is nothing showing on the screen and the player does show up in as a storage device in an explorer window, then the screen is just not working.
If you receive the error "USB Device Not Recognized" on the computer, the player is most likely failed. Additional troubleshooting is unlikely to correct the problem.
STEP 2 - Check under Device Manager
1. Right-click My Computer, and select Manage.
2. Click Device Manager on the left pane.
NOTE: Sansa MP3 Players can connect to your computer in MSC or MTP mode. Exceptions are mitone mp4 player Connect and mitone mp4 player Express which only use MTP mode. MTP mode is the recommended and default method for mitone mp4 player Players when used with Windows OS.
The mitone mp4 player player will show up on Device Manager's right pane as:
1. USB Mass Storage device (if the player is set to MSC)
2. Portable Device (if the player is set to MTP mode)
If there is a yellow exclamation point (!) or question mark (?) beside the device, try to refresh the drivers.
STEP 3 - Refresh the drivers
1. Right-click the entry with the error mark, select Uninstall.
2. On the top menu, click Action then select Scan for hardware changes.
NOTE: If a device with yellow exclamation point (!) continually appears and disappears, then the player is most likely failed. Additional troubleshooting is unlikely to correct the problem.
SOLUTION 3 - Connect using MSC mode
Connecting in MSC mode will help determine if there is a problem with MTP mode or with the Auto Detect mode feature of the player. You can use Forced MSC mode or switch the player settings to MSC.
If the player is detected in MSC mode but not when set to MTP mode, try to update or reinstall the mitone mp4 player firmware
NOTE: mitone mp4 player Express and mitone mp4 player Connect do not have MSC mode. For mitone mp4 player Connect you can try reinstalling the firmware using the Connect Recovery Mode.
Additional troubleshooting notes:
If you have replaced the mitone mp4 player Player and you still have problems getting it to recognize in the computer, then you may need to try some additional troubleshooting.
- Try connecting on another computer.
- Try using a different USB cable
- Try connecting to the back USB ports which may supply better power.
- If only MTP mode is not working, try reinstalling Windows Media Player
For Windows XP try also download and install the MTP Porting Kit.
Hope that helped And please don't forget to rate me..
Have a nice day....
Feb 19, 2011 | Audio Players & Recorders
Notebook compter not recognising my mp4 player
Maybe you need to install some driver, check if your product came with a CD driver or search for the web site of the product. You need to post more information about this mp4 player to help us to help you.
Feb 26, 2010 | Microsoft Windows XP Professional
Can't figure out how to use the mp4 touchscreen player
I found a manual that is readable:
http://www.curtisint.com/html/CustService/Manuals/SYL_SMPK8854B_EN.PDF
But it doesnt tell you how to copy music from pc to player1
But lets try anyway;
Turn on the player and pc and insert the usb cable!
Now wait for abt a min. and on pc in Windows explorer therer should be another driver which is associated with the your player!
Now you can copy song from your song folder and drop them in the new drive which apperead when you plug in the usb cable!
Hope this helps!
lemme know how it works out!
Dec 27, 2008 | Audio Players & Recorders
I wanna update and add games and things to my ivo sound m850 mp4
I don't know if you can add games to it. This link has some Q&A on the device: http://www.bayconsumer.com/m850_QA.htm , it also has links to the user manual etc. Files can be downloaded from http://www.bayconsumer.com/Download/m850/
Dec 26, 2008 | RCA Lyra RD1072 MP3 Player
Istage mp4 player
buy one that actualy works
Jun 15, 2008 | Acer MF35 MP3 Player
MP4 won't download
Install the Philips Device Manager software and drivers from the product CD.
You then need to use the Windows Media Player, Sync function to transfer music tracks.
Apr 11, 2008 | Philips GOGEAR SA6045 MP3 Player
Charger will not fit anymore
If you got a USB cable with the unit, you can connect to your PC and recharge the battery that way. Just be sure to have the power switch turned ON. The screen on the player will indicate its connected and you should see the battery indicator in the lower right corner showing a charging condition (bar moving)
Feb 12, 2008 | Audio Players & Recorders
310 people viewed this question
 Grubhead
Grubhead
