Question about Hotpoint Dryers
Post on start switch broke off in panel
Is there a way to bypass switch in order to use?
  • 334 Answers
Sure there is, but in all honesty its just as easy to replace the switch.
However, you can locate the wires coming out of the switch. run a jumper from one to the other long enough for it to start, then remove the jumper. If your unit requires the switch to be energised the entire run cycle, you will have to leave the jumper on.
You can buy alligator clip jumper wires at radioshack.
But then, you can buy a switch at your local appliance parts house too.
Posted on Jan 16, 2009
    Sergeant:
    Champion:
  • 318 Answers
Without taking off the cover to replace the switch,,you may want to try a little dab of epoxy resin glue,,put it onto the broken part of the switch,,then gently push the broken halves of the switch to-gether and wait about 10 minutes,,if the glue sets up properly,,(and if you are gentle with it from now on) it may work.
I have a 00 dodge stratus 2.5 how will bypass the antitheft circuit in order to start
Bypassing Neutral Safety Switch, Chrysler sebring 2000 ...
? 2:21
https://www.youtube.com/watch?v=uBszX3CnXeo
Apr 27, 2012 - Uploaded by Brianna Kufa
Bypassing Neutral Safety Switch, Chrysler sebring 2000. Brianna Kufa ... 1) Remove wiring harness attached to tranny. (there's 4 connections: ...
Part 1 -How to Troubleshoot a No Start (Chrysler 2.0L, 2.4L)
troubleshootmyvehicle.com > Chrysler > 2.0L, 2.4L
Dec 29, 2012 - Failed starter motor. Failed neutral safety switch. ... Dodge Vehicles: Avenger. 1995 ... Stratus. 1995, 1996, 1997, 1998, 1999, 2000, 2001, 2002.
Automatic Shutdown Relay - Allpar
Nov 13, 2015 | Dodge Cars & Trucks
How do i bypass the antitheft on my 2007 galiant .someone broke my ignition switch can i bypass it without replacing the ignition. the car tries to turn over but will not start.
no, you cannot bypass it. If it were easy any theif would have access to steal any car. Only way to clear the lockout condition is to repair the problem
Aug 14, 2010 | 2007 Mitsubishi Galant SE Sedan
Will not start. Can jump accross the selinoid and
I assume that you are jumping the solenoid in order to bypass an ignition switch that is no longer operating?
If so, did you have the key turned to the run position?
You should not need to bypass any safety switches, just be sure that everything is in the normal starting position. (deck disengaged, in neutral, etc.)
Either way, it sounds like you have a bad ignition switch, or faulty wiring between the ignition switch and the solenoid.
Jul 30, 2009 | Garden
Kenmore Elite Oasis 27062, the lid lock broke
Simply attach both wires from the switch to jumper.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
May 11, 2009 | Kenmore 24032\24036 Top Load Washer
How do I bypass a door switch for my Whirlpool dryer-
take the top loose on the dryer to acces the door switch. If it is the old style it should have a metal suround over the black switch. If the metal arm piece has broke, Ttake it off and tape the white button down to make it run.
Nov 21, 2008 | Fisher and Paykel DEGX1 Electric Dryer
Sharp carosel R310FK-keeps going
control panel is hung up - replace panel and keypad.
Dec 28, 2007 | Sharp R-510HW Microwave Oven
Dryers Logo
77 people viewed this question
Top Hotpoint Dryers Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Hotpoint Dryer Expert? Answer questions, earn points and help others
