Question about Fantech Electrical Supplies
Cant find a light kit to replace one in inline light fan kit halo
I cant seem to find a light kit to replace the one in a inline fan halogen light kit in my shower.
  • 565 Answers
Here's all you need to know:
Posted on Jan 27, 2009
Cant find a light bulb to fit my Monte Carlo model #227880
You can buy a replacement bulbs at Home Depot its a Phillips T4 mini candelabra 75 watt halogen bulbs It's a small cylinder shaped bulbs
Feb 26, 2013 | Monte Carlo Dryers
How do i remove the fan and pulley on a 1987 ford ranger 2.9 v-6?
The question is: How remove clutch in order to remove fan mounted on its engine-side face.
  • Generally, the clutch drive half shaft must be uncoupled from coolant pump (impeller drive) half shaft using special wrench kit available as loaner from AutoZone (free with $79 approx deposit).
  • Best done after shroud & radiator remove after coolant drained.
  1. Uncouple coolant pump and fan clutch drive shaft(s) as follows:
    1. span across combo-pulley-sheaves-unit mounting bolt heads with large tool kit wrench, and
    2. span inline clutch coupling nut with small tool kit wrench. Then,
    3. turn small wrench (and coupling nut) CW while resisting with large wrench (CCW) to turn coupling nut until disengaged from coolant pump drive shaft.
  2. Remove fan/clutch assembly.
  3. Note direction of mounted fan hub and fan blades orientation to ensure proper re-assembly.
  4. On rear of clutch assy, remove 4 bolts to disengage and remove fan.
  5. Assemble new fan to clutch (or, preferably, new clutch and new fan) using new bolts and washers provided with fan.
  6. Couple fan-clutch assy to coolant pump drive shaft as per opposite of uncoupling step 1, above. (Turn inline nut CCW to tighten...30 ft-lb.
  7. Check that fan can be hand turned...CW.)
  8. Rest shroud over and onto fan.
  9. Replace radiator; remount shroud; reclamp hoses, and refill and air purge cooling system.
Aug 12, 2012 | 1987 Ford Ranger
I installed a High beam hid kit and read online that they needed a resistor in that year to trick the computer. after installing the kit and the resistors to the high beams pos and neg it still flashes...
I don't know why you would install resistors inline for an HID kit, they should be 'plug and play'-you plug the connector for your halogen lights into the ballast input for the HID kit, then plug in the HID bulb harness/ bulb to the ballast output, install the bulb into the housing-done. Some people have installed relays to the lights because when the HID's 'light off' the use a lot of power until the bulbs warm up, then they actually consume less than a halogen bulb (usually 35 watts HID to 55 or more halogen). I have HID's in a number of cars and don't have relays hooked up on any, just 'plug and play' and I have no issues whatsoever.
Apr 03, 2011 | Dodge Ram Pickup 1500 Cars & Trucks
Need to replace my headlight on my 2003 toyota celica can get to two of the bolts but cant seem to find the third. any ideas...
Hello !!
well most of the Halogen light bulbs of the headlights are "turn-lock" and have a "o"ring to seal them..
Try to turn the back connector on the back of the headlight (a quarter of a turn) and pull it gently (be sure no to touch the new halogen light bulb with your fingers because it can get contaminated and burn faster)
Good Luck!
Sep 20, 2009 | 2000 Toyota Celica
Can i buy a light to replace the light in an inline fan light combo kit?
Remove the "light" and take it to an electrical supply store. They will match it for you. good luck.
Jan 16, 2009 | Electrical Supplies
Palm beach 48"
Me too. I went back to Home Depot. They gave to me the phone number for Hampton Bay - 1-877-527-0313. I will call them tomorrow after they open to see what the deal is. it looks to me like the JDE11 is a mini-candelabra base. The lady in the fans at Home Depot said that all of the light kits were changing to the smaller based halogen lights. BUT, you'd think that they'd carry the light bulbs that have to go in the light kits they sell!!!
May 12, 2008 | Hampton Bay 48 In. Palm Beach in Textured...
Glass Surface Light Lens Cracks from Halogen lights use
The lights do get very hot, so they must be a sufficient distance from the lens. Was there an instruction sheet with the new lens? You may need to adjust the sockets upward. You might call a local GE-authorized servicer to see. Concerning the vent fan, this is a problem with the control panel assembly, which we repair nationwide for $39.95. Details are at our site, which is linked at our listing here on FixYa:
Aug 06, 2007 | GE XL1800 1100 Watts Microwave Oven
Electrical Supplies Logo
208 people viewed this question
Top Fantech Electrical Supplies Experts
Craig Butler
Craig Butler
Gene Haynes
Are you a Fantech Electrical Supply Expert? Answer questions, earn points and help others
