Question about Electrical Supplies
Can i buy a light to replace the light in an inline fan light combo kit?
  • 10,865 Answers
Remove the "light" and take it to an electrical supply store. They will match it for you. good luck.
Posted on Jan 19, 2009
We want to take the light kit off of a 48" Concord ceiling fan. We need a cap or a cover for the bottom. How do we buy one?
I think you have to take the light kit off the bottom cup & put the cup back on the fan. Should just need a filler plug or screw for bottom of switchcup.
Aug 10, 2014 | Dynasty Concord | 52DY5RI | 52" Ceiling...
How do i remove the fan and pulley on a 1987 ford ranger 2.9 v-6?
The question is: How remove clutch in order to remove fan mounted on its engine-side face.
  • Generally, the clutch drive half shaft must be uncoupled from coolant pump (impeller drive) half shaft using special wrench kit available as loaner from AutoZone (free with $79 approx deposit).
  • Best done after shroud & radiator remove after coolant drained.
  1. Uncouple coolant pump and fan clutch drive shaft(s) as follows:
    1. span across combo-pulley-sheaves-unit mounting bolt heads with large tool kit wrench, and
    2. span inline clutch coupling nut with small tool kit wrench. Then,
    3. turn small wrench (and coupling nut) CW while resisting with large wrench (CCW) to turn coupling nut until disengaged from coolant pump drive shaft.
  2. Remove fan/clutch assembly.
  3. Note direction of mounted fan hub and fan blades orientation to ensure proper re-assembly.
  4. On rear of clutch assy, remove 4 bolts to disengage and remove fan.
  5. Assemble new fan to clutch (or, preferably, new clutch and new fan) using new bolts and washers provided with fan.
  6. Couple fan-clutch assy to coolant pump drive shaft as per opposite of uncoupling step 1, above. (Turn inline nut CCW to tighten...30 ft-lb.
  7. Check that fan can be hand turned...CW.)
  8. Rest shroud over and onto fan.
  9. Replace radiator; remount shroud; reclamp hoses, and refill and air purge cooling system.
Aug 12, 2012 | 1987 Ford Ranger
I need an exploded picturial view of the BROAN fan and light kit. Thanks
go to www.broan.com from there you can look up that fan/light combo and download the installation manual which will give you the exploded view.
Broan Bathroom Fan Care and Cleaning
heatman101
Jul 02, 2009 | Broan-NuTone N-8663RP Combination Light...
I have a hampton bay 48670 ceiling fan. I need to knwo if I have to buy a certain light kit for it. Th eoriginal one fell aprt.
The only issue with a light kit is will it mechanically adapt to the fan. Electrically it's compatible. There are many light kits which will fit multiple brand fans.
Apr 19, 2009 | Dryers
Marquesas II by hampton bay, won't work
Your best bet would be to take the fan back to the store buy a new one and try again if the problem is the same its the way you are connecting the wires sometimes you need to add 3 wire to black (hot) to get the light and the fan to work.
Nov 16, 2008 | Dryers
Electrical Supplies Logo
105 people viewed this question
Top Electrical Supplies Experts
Steve
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
