Question about Lexmark X4270 All-In-One InkJet Printer
Fax machine lexmark X6170 says error with cartrige 50c
  • Lexmark Master
  • 684 Answers
It insists there is a Cartridge problem on the Printer............  In this Case take out the Paper from the Paper Feed Tray........ Unplug the Power Supply from the Printer.......... Remove both the Cartridges from the Printer.......... Now take a size 10 Envelope fold it so that it should become like a thin long strip........ Now Insert that Envelope on the left side corner of the Printer and move it from right to left and left to right as fast as u can for about 10 times.......... Now Insert the Ordinary Papers onto the Printer and insert both the catridges and Turn on the Printer...... Blinking Stopped...........Issue Resolved....... Still Blinking: Remove both the Cartridges take a Paper Towel turn the catridges direction so that u can see a Copper plate with small boxes on it....... Just wipe it twice or thrice with the Paper Towel.......... Now insert it and Power on the Printer and see whether the Lights are still blinking if it is still blinking...... Contact Lexmark at 1-800-LEXMARK Good Luck.........
Posted on Jan 19, 2009
Lexmark X6170 shows cartrige error error 50C how do I correct the problem
Please follow the steps below to fix the issue:
1. Make sure the printer is on.
2. Open the printer cover. The print cartridge carrier moves and stops at the loading position, unless the All-in-One is busy.
Note: If the carrier does not automatically move to the center, turn off the printer/unplug the printer from the power source and then slide the carrier to the center.
3. Remove both cartridges from the carrier.
4. Close the printer cover.
5. Re-brick your printer. Pull out the power supply, black box where the power cord is plugged in at the back of the printer, and put it back after 30 seconds.
6. When the printer turns on, reinsert one cartridge first.
7. Close the printer cover and check for any errors.
8. If no error appears, reinsert the other cartridge. Close the printer cover.
9. Replace whichever cartridge is causing the error to appear with a new cartridge.
If problem continues, please contact Lexmark Technical Support Center for additional assistance.
Sep 15, 2011 | Lexmark X6170 All-In-One InkJet Printer
Cartridge error 50c
The Cartridge error 50c indicates that the printhead(s)/cartridge(s) has shorted. Follow troubleshooting steps available at http://bit.ly/8Zf7ef. If error continues even with brand new genuine Lexmark cartridges, contact Lexmark technical support for assistance. Thank you for choosing Lexmark.
Sep 20, 2010 | Lexmark X6170 All-In-One InkJet Printer
Equipment malfunction -cartrige error
Here's an article in the Lexmark website on "Cartridge Error 50C" and Other Errors on the Lexmark X5100/X6100 Series LCD Screen. Just click on this link: http://bit.ly/cOlN7n. Follow the instructions carefully. Hope this helps but if the problem persist after doing these steps, I strongly suggest you contact Lexmark Technical Support to further investigate the problem. I hope I can assist you more on this matter.
Jun 29, 2010 | Lexmark X6170 All-In-One InkJet Printer
6170 I HAVE A ERROR MESSAGE STATEING 50C CONSULT USER GUIDE AND I DO NOT HAVE A USER GUIDE
Hi. The error tells you that your print cartridge has shorted. Here's a link to the Lexmark website to give some instructions on how to remedy the problem. Just click on this link: http://bit.ly/aSWvpk . Good luck!
Mar 23, 2010 | Lexmark X6170 All-In-One InkJet Printer
Error message - cartridge error 50c will not print
I have a lexmark x6170 with a cartridge error 50c.
Please I need some help!!
Thank you.
May 09, 2008 | Lexmark X6170 All-In-One InkJet Printer
Error 50C message
K try
Resetting purge counter:
1) Enter machine maintenance mode (on MFC210C all four photo/copy/fax/scan lights flash in maintenance mode). Care is needed in maintenance mode, otherwise critical settings may be inadvertently corrupted.
FAX models with numerical keypads: Press the Menu/Set, *, 2, 8, 6 and 4 keys within two seconds. (if you fail to complete the correct key sequence within two seconds, press the Stop key to try again).
Other (non-FAX) models: Press the Menu/Set and Black Start keys. Next press the “up arrow” key four times to enter the maintenance mode).
2) Press the 8 then 0 keys in the initial stage of the maintenance mode to call up the machine's log information list (function code 80).
3) Press the Black Start key several times to scroll through the log information list to reach the purge counter. The purge counter is the 25th item in the list.
4) Press the 2, 7, 8, and 3 keys in this order to reset the purge count to zero.
5) Press the Stop/Exit key to return to the initial stage of the maintenance mode.
6) Press the 9 key twice to return to the standby state.
Lexmark x6170
Need to reset it and run auto allignment. This is usually how to fix error 50c
Dec 27, 2007 | Lexmark X6170 All-In-One InkJet Printer
Cartridge error error 50C consult user guide
Hello, error 50c is a cartridge issue. Try taking out, cleaning heads, returning and reprint. Cheers lilacgerry xxx
Dec 02, 2007 | Lexmark X6170 All-In-One InkJet Printer
Lexmark X4270 All-In-One InkJet Printer Logo
50 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
