Question about GE GSS25JFPCC / GSS25JFPWW Side by Side Refrigerator
GE ICEMAKER MAKES ICE, WATER RUNS ON TO FLOOR FROM FREEZER.
GE MODEL GSS25JFMC
MAKES ICE BUT IT SEEMS TO ME THAT THE DISPENSING SYSTEM DOESN'T KNOW THE TRAY HASN'T DUMPED YET AND ADDS MORE WATER ONTO THE FROZEN CUBES. THEM RUNS WATER OVER INTO THE TRAY AND OUT THE DOOR AND BEHIND THE ICE MAKER DOWN TO THE BOTTOM OF THE FREEZER. I CAN TURN IT ON WORKS GREAT FOR DAYS, A WEEK THEN WE FIND WATER ALL AROUND THE FRIDGE. CHECKED SOL. SHUTSOFF GOOD, DISPENSING TUBE APPEARS TO BE INTACT.
HVACRH20
  • 237 Answers
SOURCE: Ice cube dispenser not working
Not real familiar with that specific model but it sounds like the heating element isn't working to loosen the ice from the tray as it's dumped. A typical ice maker has a small heat element under it to melt the surface of the ice just slightly while it dumps.
Posted on Jan 04, 2007
  • 23 Answers
SOURCE: ice maker not working
check your owners manual for a water filter, make sure trip arm isn't stuck closed and not letting water in to freeze.
Posted on Dec 08, 2007
SOURCE: ice maker broken
Our is broken as well. Water dispenser works.....
Posted on Feb 24, 2008
SOURCE: Icemaker problem crushed only not cubes
I looked at the plastic piece the solenoid was moving (from Guest's comment 03/07/08). Pushed the plastic piece up (had to push pretty hard) and it reset the solenoid to its' start/beginning position(-?) Plastic piece came back to lower position - was free to move up and down. The solenoid is working now (hear the loud clicking and see it pulling the plastic piece up) to get cubed ice, instead of putting it thru the crusher.
Posted on Mar 15, 2008
SOURCE: icemaker only dispenses crushed ice, not cubes
yea! I have been without cubes for 2 years. I slid out the tray, found the lever in the back where the rod went in, pulled it down, reinserted the ice tray, and IT WORKED! At first I thought I broke the lever, because I had to hold it down with a knife while I was inserting the tray, but it just must have been stuck. I am soooo happy!
Posted on Aug 10, 2008
GE GSH25JFRF BB ice maker doesn't dispense. Water dispenses and ice maker makes ice but won't come out.
There should be a plastice hinge cover on the left top hinge on freezer door. Take it off and press the plug together firmly. Try that and let me know, Sea Breeze
Aug 19, 2012 | GE Refrigerators
I have a GE Profile refrigerator, Model PFSS6PKWBSS, with icemaker on door. Water is collecting under Deli-draw and leaking down freezer door onto floor. How do I fix leak?
Hi
Try and access the ice dispenser assembly and check from where the water is leaking. You would need to disassemble the ice dispenser and ice maker to check this. The ice dispenser is located in the upper portion of the freezer compartment. This assembly stores ice made by the icemaker and dispenses ice on demand from the door dispenser target switch.
1. Remove the upper ice bucket tray.
2. Slide out the ice dispenser assembly.
3. Remove the ice cube solenoid linkage Phillips head screw and slide the linkage back.
4. Remove the ice crusher cover Phillips head screws (2) and remove the cover.
5. With a pair of pliers, twist off the backing plate tabs located on either side of the crusher.
6. With 2 small flat-blade screwdrivers, unlock the ice crusher locking tabs located at either side of the ice crusher.
7. Lift the ice crusher out of the bucket.
8. Remove the ice crusher back cover.
9. Remove the locking ring from the ice crusher auger.
10. Remove the plastic nut with a pair of pliers by turning it clockwise.
11. Remove the spacers and blades. The blades are numbered for reassembly.
Icemaker--
The icemaker is located in the upper rear of the freezer compartment and supplies ice to the dispenser tub.
1. Disconnect the icemaker cable connector.
2. Remove 1/4-in. icemaker mounting screws and slide out the icemaker.
This refrigerator is equipped with an Electronic Icemaker.
Hope this helps... Please post back if you need more information.
Daniel
May 01, 2011 | Refrigerators
Ice Maker leaks water inside the freezer
I see you said you looked and the water valve is off but the only that I know of this happening is a defective water control valve. Like a dripping faucet that when off slowly drips until the ice forms and then one the ice maker dumps ice and tries to refill the water goes in every direction. Unplug water valve to confirm what I am saying, Tell me if it continues to leak. Sea Breeze
Apr 19, 2010 | GE 21.7 Cu. Ft. Top-Mount Refrigerator...
Icemaker water overflows into freezer
the condensate tube is run incorrectly on this model and goes uphill into the area above the refrigerator where there is a condensate pan. This will plug and back up and cause this problem. I have fixed ours several times but it always came back. The last time I bought a new clear plastic tube and reran the condensate out the back of the refrigerator and down through my floor. It's all downhill now and seems to have fixed the problem.
Nov 28, 2009 | GE Monogram ZISx420DR 42-inch Side by Side...
GE PSS26GRE SS not dispensing ice
The first step you need to do is to turn the water off to the refrigerator so it quits making until you get it fixed.
If your fridge has the control boards in each side of the freezer cabinet that controls the icemaker, then you have a failed board. If you have a standard icemaker with the metal shutoff arm then you have a failed motor module in the icemaker. You can remove the icemaker and unplug the wiring connector from it so you can leave the water on to the dispenser.
Thank you for contacting Fixya.com
Aug 11, 2009 | GE Profile PSW26P Stainless Steel Side by...
Water leaking from icemaker on outside
If this is your water dispenser leaking
Your water inlet valve on the back where the water supply comes in is probably leaking. disconnect the water line coming out of it and see if you have a slow drip. Try the dispenser to see if it's just drips after use.
Jul 08, 2009 | Whirlpool 21.0 cu. ft. Top Freezer...
Water line to water dispenser is freezing up inside the freezer
Try using an hairdryer or defrosting the unit completely , this often get rid of blockage caused by frozen lines fixing the problem.
The water lines can also be unblocked from dirt using a thin flexible shaft. This after defrosting.
If all that does not fix the problem, then you may need to replace the water valve, the icemaker solenoid, or the whole icemaker assembly.
Enter the model number on one of two websites below to get parts and diagrams for your appliance:
Appliance Parts From PartSelect
Appliance Parts Pros
Dec 27, 2008 | GE GSL25JFPBS Side by Side Refrigerator
GE frig just starting leaking water at the bottom of the freezer side door
more than likely you have a frozen defrost drain look in the bottom of your freezer section there should be a depression there see if its just a big block of ice let me know if this is the case or not and ill tell you how to clear the drain if not then we will look at something else please dont rate me till were done
Jan 11, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
New Kenmore Elite ice dispenser not working but water is
Should be no longer than 24hrs. Is the freezer good and cold.. has to reach a certain temp before icemaker activates. Might take little longer if you put a lot of warm things in freezer or refrig. when you made the change. Is there any water or ice in the icemaker itself? Water may not be getting to icemaker call them back out if it dont work soon thats what warrantys for :0)
Sep 02, 2007 | Whirlpool ED2FHEXN Side by Side...
GE GSS25JFPCC / GSS25JFPWW Side by Side Refrigerator Logo
69 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
RepairNinja
RepairNinja
