Question about Panasonic NN-S952 Microwave Oven
Panasonic Microwave oven - cooking operation stops afer 2 seconds
My Panasonic countertop microwave oven (NN-S952-WF) of about 5 years of age went completely dead when my wife simply opened the door (a couple minutes earlier it had just completed cooking some food for 5 minutes with no problems).
I suspected some blown fuse inside the unit when I proved that it was not the breaker or wall socket or any external problem. After some GOOGLE investigation I confirmed that there is an 18Amp Ceramic fuse inside the unit. So I bought a 20AMP ceramic fuse (and a security torque socket to remove the back screws) and removed the cover and found the blown fuse and replaced it with the 20AMP fuse.
Upon plugging it in, the lights all came on and the keypad / instrumentation all looked normal and even opening the door - the oven light turned on. BUT, when I tried to cook something, the instrumentation showed that the cooking operation was active yet there was no fan noise and no magnetron power hum. After about 2-3 seconds, there was a slight click and the oven turned its cooking operation back off.
I tried it a few times, and the same thing happened.
I suspect there could be some kind of Case Opening Tamper Switch but when GOOGLING, I havent heard anyone mention this.
So does anyone have any idea why my microwave cooking operation has failed? Is this something that is fixable? or is it already time to replace my pretty young oven?
Perry
  • PerryF Jan 16, 2009
    Thanks muchly for the input. Great input. I am assuming it was this short in one of those 4 components was likely the intial reason for the Fuse going in the first place.
    Although I am not that bad at general break/fix, its not one I would take on by myself. My brother is an electrical engineer but I dont like bothering him (I already have been wokring with him to try to fix my Hyperboard on my Toshiba Projection TV).
    Soooo - it seems its time to replace the oven and - well - help our economy with my wee bit of economic stimulas. :(
    Problem Solver:
  • 7 Answers
It is your short switch which is a microswitch located in your door latch assembly
Posted on Aug 03, 2010
    Problem Solver:
  • 9 Answers
If you haven't figured out this problem yet, had you considered the door switches. These are the most common part that fail, besides the fuse. The door switches are just to the left of the control board and there is usually 3 to 4 of them. Best to change all 4, as without a proper meter to test them with, just as easy to replace all of them. Definitely search around and check with any local microwave parts stores. Global Microparts is a local company out of Dallas, and they are extremely reasonable on their prices. They will ship anywhere. Hope this helps some. Good luck.
Posted on Jul 30, 2010
    President:
  • 1,214 Answers
Sounds like a short in the microwave circuit. One or more of the following four components has failed -
Transformer
Magnetron
Diode
Capacitor
Repair is not for the amateur, unless you know how to take things apart, and put them back together EXACTLY as the were found.
Parts are available on the Net, and you can get the P/N's off the old components to identify suppliers of the new ones.
Don't try and measure resistance of the diode. It's impedance is far too high to get a good reading. They're cheap anyway. Always replace the capacitor, they're cheap too. No way to test the magnetron, and the transformer is not easy to test either.
Posted on Jan 16, 2009
  • Mark Egan Jan 16, 2009
    It may be cheaper to buy the components and replace them. I bet you can find them on the internet for no more than $200, probably less. I went through this same thing with the In-laws MW a couple of years ago. Just be sure and put the right 18 Amp fuse in, and, reassemble the unit exactly the same way you took it apart. If you have ANY screws leftover, find out where they go. Your dealing with microwave radiation here, which is quite dangerous to the human body.
    And nothing against your brother, but unless he is mechanically competent, they sometimes try to analyze too much, or they are more "electrically" trained, than "electronics", and those trained in electronics and don't have high voltage experience will not quite understand the high impedences of the magnetron circuit.
NN-T563 shuts off after 5 seconds
We recommend you use the below link to locate an authorized service center. Panasonic microwaves have a 5 year warranty on the microwave.
www.panasonic.com/repair
Apr 12, 2014 | Panasonic NN-S563 Microwave Oven
Panasonic microwave oven nn h965wfx
either your magnatron is bad or hopely it could be your high or low heat sensor
Oct 13, 2013 | Microwave Ovens
PANASONIC NN-S952WF FAN AND CAROSEL STILL CONTINUES WHEN DOOR IS OPENED. NOT SURE IF THE MICROWAVE CONTINUING AS WELL WHEN DOOR IS OPEN.
The door interlock system has beem compromised , meaning it shifted out of position or the interlock has broken. Dont continue using it like that it will eventually blow the fuse.
May 13, 2009 | Panasonic NN-S952 Microwave Oven
PANASONIC MICROWAVE-NN-S615BFX
These H codes usually indicate a problem with your inverter, magnetron, or digital programming circuit.
Due to the lethal voltages used and produced, I do not recommend that an inexperienced person work on these.
You can find an authorized Panasonic servicer here.
Sep 25, 2008 | Panasonic NN-MX26 Microwave Oven
Operates for 3 seconds on microwave then stops
If the digital programmer circuit / controller does not get a feedback signal from the inverter for a period of 3 seconds, the controller will stop the cook cycle.
It could possibly be as simple as a loose connection in that area. The repair shop your friend used may not have been Panasonic-authorized.
I would recommend that you contact your nearest Panasonic-authorized servicer.
Sep 15, 2008 | Panasonic NN-C980 Convection/Microwave...
Runs for three seconds then shuts down. Model NN-S952
In most cases, this is a problem with the inverter or a bad magnetron.
We're happy to help you and we'd appreciate your thoughtful rating of our answer.
Jul 28, 2008 | Panasonic Microwave Ovens
Panasonic NN-T994SF 1250 watt countertop microwave stopping
From my research, this sounds like a fairly new model. Consult your user's manual to see if this is a user, or common issue. If nothing is descibed then I would seek possible warranty service, or dealer replacement
Jun 03, 2008 | Panasonic NN-T994SF Microwave Oven
Panasonic NN-S952 Microwave Oven Logo
580 people viewed this question
Top Panasonic Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Panasonic Microwave Oven Expert? Answer questions, earn points and help others
