Question about Motorola Mobility L6 Cellular Phone
How to replace keypad on a Motorola SLVR L6 Cell Phone
I am trying to replace a keypad on my phone (model in subject). Could someone let me know how to replace it?
  • 1 more comment
  • lyric6161 Jul 18, 2008
    is there a way to take off the front face plate w/o damaging the device
  • Anonymous Apr 26, 2009
    how do i get the keypad and back off my motorola phone?
  • Anonymous Mar 13, 2014
    samsung r455c cell phone repalce keyboard slider
I just did this for Motorola L6. This was one of the candy bar phones, not a razor. It was a pain, but I finally figured out to do the following:
1. Take off the back.
2. Take out the battery.
3. Take out the 4 Torx Screws on top around the camera area. Mine were a T5. I've noticed others talking about a T6. I suggest taking the phone to Sears or somewhere that has these type of screwdrivers to match your size unless you have a set.
4. On the bottom back of the phone, there is a plastic piece with some vent holes that I assume are for the speakers. Gently pry this piece off, and you will find 2 additional torx screws under it.
5. Once you get all 6 screws out, you will be able to gently pry off the front outer framework, and this will allow you to replace your keypad.
6. Put it all back together in the reverse order. Hope it works!!
Posted on Oct 04, 2008
Hallo go to the http://www.repair4mobile.org/disassembly_motorolla.html. then many model of motorolla will be list out select ur model and click to the right place.so u will teached ho to disassembly ur l6 mobile phone.but at first u will need to buy a t5 screwdriver to unscrew ur phone. GOOD LUCK
Posted on Jul 13, 2007
Sir give me a Motorola l6 PC suit software
Posted on Feb 24, 2009
  • 67 Answers
You unscrew the phone at the back using torx head six srewdriverhead after that u take out back cover before u unclip the front face.advice by DOGY
Posted on Dec 21, 2007
My problem about my internet acces how to use and the pc sync in my motorola! pls answer my question.
Posted on Dec 20, 2007
SOURCE:
Jnm1731dm1bb
For model JNM1731DM1BB, there's no reset. Your membrane keypad is failing and has to be replaced.
On this model, the membrane keypad is not available as a separate part, so you would have to order the control panel frame assembly which comes with a new keypad.
In this case, you simply move your circuit board into the new frame. That is a simple do-it-yourself job.
It is part number WB07X11033 and you can order it from the Pros here for $148.66 (subject to change).
You can find helpful exploded view diagrams and order other parts at that link, too.
There is a video here showing how to remove a typical over the range control panel assembly in under 5 minutes.
Then you unplug the keypad (as per the photo below) and move your circuit board into the new frame.
Be careful, the display is made of glass.
Oct 26, 2013 | GE Spacemaker JVM1640SJ Microwave Oven
I have a SamSung microwave that keeps beeping SE on display
"SE" means you have a shorting membrane keypad.
On some models, the membrane keypad itself is replaced.
If you (or someone you know) might want to replace it yourself, I have uploaded a handy guide with pictures showing you what's typically involved.
On other models, the keypad is not available as a separate part, so you have to order either the control panel frame assembly (which has a new keypad on it) or a whole new controller assembly / control box.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
Here's a YouTube video showing how to remove a typical over the range control panel assembly in under 5 minutes.
Some connectors have a lock.
Jan 29, 2013 | Microwave Ovens
When i try to turn on my slvr the keypad will light up for a few seconds then turn off...I tried taking out the battery and replacing it wit a brand new 1 without any luck. I also tried just pluging it...
Hi, problem can be solved.
What causes the keypad will light up for a few seconds then turns off, is because the keypad has a separate function from the phone. (it has a removable keypad). And the keypad inside the cell phone is getting Bad and it needs to be replaced.
You can know how to disassemble the cell phone through the link below:
http://www.formymobile.co.uk/l7disassembly.php
When you replace the keypad,phone will be ok again.
Thanks for using fixya...
Feb 14, 2011 | Motorola Mobility SLVR L7 Cellular Phone
My Raynor Keypad does not work
There should be a small screw about 3 inches up from the bottom. Remove this screw and the cover should slide off.
Oct 18, 2009 | Sears Craftsman LiftMaster Chamberlain...
How do i replace the keypad of my slvr l7c phone?
Motorola phones doesn't hav available on-store housing/casing.... you can inquire for a Motorola or other cellphone technician to solve the problem for U!!!!
Oct 01, 2009 | Motorola Mobility L6 Cellular Phone
How do I replace the keypad in Nokia N79?
hi..you can replace the keypad by removing the
front panel.
try this out..
thank u..
rate me..
Apr 08, 2009 | Nokia N79 Cellular Phone
Motorola l6 was not reading sim
Try clean sim pin contact, if not replace keypad.
Feb 13, 2009 | Motorola Mobility SLVR L7 Cellular Phone
Subsidy code for motorola l6 slvr
You will need to contact the carrier or go to a third party company and pay a small fee to get it unlocked.
Feb 12, 2009 | Motorola Mobility SLVR L7 Cellular Phone
Motorola Mobility L6 Cellular Phone Logo
1,908 people viewed this question
Top Motorola Mobility Cell Phones Experts
vince
D. E. Hev
Mark Magill
Mark Magill
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
