Question about Tissot PRS 516 T91142651 Wrist Watch
Tissot watch prs 516 automatic
Reset button sometimes does not reset the 60 sec. counter hand to zero; i think the levers slip. how do i fix this on my new watch?
  • Anonymous Dec 20, 2007
    I have the same problem with my pr50, the second hand resets to the 59 second mark..
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 73 Answers
I would recommend going to the following link and follow the instructions for resetting the counters and see if that corrects the issue.
http://www.tissot.ch/data/usersmanual/134-en.pdf
Posted on Feb 21, 2008
SOURCE:
Jorg Gray 6500 Chronograph's minute chronograph won't reset to 60 (the default it should be) when I reset it, and according to the manual. Is there a fix for this?
Similar to above answer - pull out crown (two stops) hold top button (firmly) you need to allow it rotate several times to move the minute hand (slow job) - and when the minute appears zero'd it seems to move slightly backwards when the crown is pushed back - it took several attempts to completely zero it - but it worked and is now perfectly in line (thank goodness)
Jul 16, 2012 | Watches
The seconds hand doesn't reset to zero when you activate the chronometer with the pusher A and stop it with the same one, you can reset with the pusher B, but it doesn't reset to zero y goes to...
CROWN SETTINGS:
1....... Running position/screwed
2 .......Date correction
3........Time correction
Procedure to set the mode using Push Buttons
Pusher A: Start/Stop Chronograph
Pusher B: Change to Chronograph mode/ Reset to zero
Note if by pressing button B and it doesn't reset to zero, you can adjust the time by following the procedure below
1. Set crown to position 3
2. Press pusher A to realign second hand
3. Press pusher B to realign counter hand at 6H
Note: For faster hand adjustment, hold pusher for 2 seconds or more
Hope this information will help you!
May 17, 2011 | Technomarine Us Navy NAUT05 Gents Watch
Please clarify use of the 3 smaller dials and how the hands to each are set and reset
The small bottom dial is seconds counter and there is no option to set or reset it as it is part of the main gear train - it just counts the seconds. Top right dial is 1/10 seconds counter and runs only when the chronograph function is engaged. One full circle indicates 1 second. Top left dial is 30 minutes counter and runs only when the chronograph function is engaged. One full circle indicates 30 minutes, two circles = 1 hour. The big centre seconds hand is actually Chronograph hand and runs only when the chrono function is engaged. So, the chronograph hand and two top dials works all together when chrono function is engaged. To start chrono: push upper button once. To stop chrono: push upper button again (once). To return all hands to zero: push lower button once. There is another option: if you already stopped chrono by pushing upper button, but want to continue counting without returning hands to zero, push the upper button once more and the counting will start from the point where it stopped. You can repeat this as many as you wish - it will count on and on, till you will stop it and reset to zero. Fine tuning of chrono hands can be made by pulling the crown half way out and while leaving in this position pushing and holding one of the push buttons (which one - depends on movement caliber). Watch has an tachymeter function as well (big inner ring). Learn how to use it by browsing through my Tips and Tricks- it is explained there. Rate me, please.
Feb 28, 2011 | Calvin Klein K7547107 Celerity Watch for...
Reset chronograph
Hi, I had the same problem and was able to fix it by reading the manual:
Basic Settings for the chronograph hand -
After changing the battery, or in exceptional circumstances, following incorrect operation, it is necessary to reset the Chrono indicator to zero (starting time).
- Leave the winder in Position 1 (pushed all the way in)
- Press button H (top) and button I (bottom) at the same time
- Now set the 30 minute (small hand) counter to zero by pressing/holding button I (bottom button)
- You can now set the 60 second counter to zero by pressing/holding button H (top button).
This worked for me... it took me a while to figure it out, but that
Jun 04, 2010 | Maurice Lacroix Masterpiece Flyback...
Reset chronograph minute and hour hands to zero
pul crown all they way out
press top right button to set the minute hand
& bottom right button to set the hour
if not work then puch back crown to 1st click and do it same function ,, if still not working then pull crown again and push and hold both button for 5 sec. its reset ,, and try to adjust it again by pressing top & bottom button
hope that will help if not and you are in chicago
bring it to us
at
Amfix Jewelry & Watch Repair
203 N. LaSalle St
Chicago, IL 60601
312 641 7000
Aug 27, 2009 | Pulsar 100 Meter Alarm Chronograph PF3277
The minute counter on my chrono won't reset to zero.
Do as follows:
1) pull out crown and set the hour and minute hands at 6 o'clock (they must be lined perfectly in opposite directions)
2) push the crown in half way back (not completely)
3) push and hold the button at 2 o'clock (set the big seconds hand to zero) and release it when done
4) when big seconds hand is zeroed push the crown back in
5) pull the crown out again and set desired time
6) push the crown back in.
If all actions described do not work, you will have to visit your nearest watch repair shop and ask to refit chronograph hand as in this case it is out of balance (not pointed at exact mark).
Rate me, please.
Jul 30, 2009 | Pulsar 100 Meter Alarm Chronograph PF3277
Won't reset to zero (60 sec.) after battery was replaced
You need to "Reset" the watch's computer, this is done by removing the case cap, (Same as battery replacement) Look for a imbosed "RESET" and using a paperclip, Push gently in the reset hole for five seconds, Remove the paperclip, You should then have all funtions restored to "Factory Settings"
May 20, 2009 | Casio Watches
Fossil Watch Chronograph Problem minute counter resets to 59 instead of 60
1. Pull out the time set mode button.
2. Press the upper right button repeatedly until the sweep hand makes it back to 00/60.
3. Press the time set button back into normal position.
Oct 01, 2008 | Watches
Reset Stopwatch Hands on CL1111 ?
Try setting the crown to position 2 - i.e. the position normally used to adjust the date.  Then use the top and bottom stopwatch buttons to adjust the minute hand and 1/10th hand respectively.
Oct 18, 2007 | Tag Heuer Aquaracer Quartz Chronograph...
Chronograph hand not resetting to 12 o'clock
for my victorinox, the crown out one position and the reset button (lower chronograph button) changes the minute hand and the top (start/stop button) does the 10th's of a second...crown all the way out and top (start/stop button) does 30 second intervals for the minute counter.
Feb 23, 2007 | Kenneth Cole KC1232 Wrist Watch
Tissot PRS 516 T91142651 Wrist Watch Logo
818 people viewed this question
Top Tissot Watches Experts
Arturs Kalnins
Arturs Kalnins
oilyphiluk
Level 1 Expert
Are you a Tissot Watch Expert? Answer questions, earn points and help others
