Question about Whirlpool Gold White-on-White 21.9 cu. ft. Conquest Side-By-Side Refrigerator with Ice and Water GD2SHAXLQ Side by Side Refrigerator
Which is better pulse defrost or adaptive defrost?
Which is better and less problem prone in a side by side Whirlpool Refrigerator Pulse defrost or Adaptive Defrost?
  • 410 Answers
Pulse and adaptive def actuall work in tandem with one another. what happens is the computer will put the refrig into a short def cycle and test how long it takes the termination switch to open this determines when it is time for the unit to go into a full term def the next time. adaptive defrost looks for the number of door openings and how long it takes for the def termination switch to open during a regular defrost. most units will go into def every -12 hours with adaptive if the conditions are right it can go as long as 2 or 3 days between def cycles. both systems are very relaible and trouble free. the pulse defrost is available on higer end electronic control refrig and is also adaptive defrost system as well. whirlpool also has adaptive defrost only available on their midline units as well as some higher end manual control units.\\
sorry for the defrost class peyton..
Posted on Jan 22, 2009
Sys 154 dia 93 pulse 125
Your blood pressure rises with each heartbeat and falls when your heart relaxes between beats. While BP can change from minute to minute with changes in posture, exercise, stress or sleep, it should normally be less than 120/80 mm Hg (less than 120 systolic AND less than 80 diastolic) for an adult age 20 or over.
The normal pulse for healthy adults ranges from 60 to 100 beats per minute. The pulse rate may fluctuate and increase with exercise, illness, injury, and emotions. Females ages 12 and older, in general, tend to have faster heart rates than do males.
Mar 01, 2015 | Cars & Trucks
How do i get rid of lemon
Call the better business bureau, and Consumer affairs. I would try to talk to someone in customer relations at Whirlpool. Preferably a supervisor, tell them about all the problems you have had with the unit.
May 13, 2014 | Whirlpool ED5DHEXWQ 25.3 cu. ft. Side by...
The Whirlpool Gold refrigerator is not cooling and the bottom freezer has ice formed on the back of the freezer. I purchased the refrigerator in February 2009.
If you can hear the fan running in the freezer you have a defrost issue. Depending on the Model number it can be a timer, adaptive defrost board, a bi-metal themostat, or heater.
May 26, 2011 | Whirlpool 24.8 Cu. Ft. Side-by-Side...
Fridge side stays cold for about 3 weeks or less and loose temperature, turn off for 1 hour and its back to normal.
Some newer refrigerators have been using an electronic board instead of an mechanical defrost timer. The adaptive defrost control does the same job as the defrost timer ( shuts off the refrigerator cooling items and redirects the power to the defrost heater for the defrosting cycle, then redirects the power to the compressor and fans to come back on when the defrost cycle is over ). This adaptive defrost system is a bit different when testing, normally speaking if the defrost heater and defrost thermostat ohm ok, we replace the adaptive defrost board.
Dec 01, 2010 | Whirlpool 25.4 Cu. Ft. Side-by-Side...
Freezer works but frig not cold.
Probably a defrost problem. See if there is any frost inside the freezer. If yes, then it probably is the defrost timer. If the unit does not use a timer, it could be the adaptive defrost control. Might also be the defrost heater or defrost termination thermostat, but I would doubt that on a Whirlpool
Mar 03, 2010 | Whirlpool Gold White-on-White 21.9 cu. ft....
Side by side whirlpool refridgerator GD5SHA is no longer cooling
Your refrigerator has an Adaptive defrost board inside the fresh food compartment that is the number one reason I think your refrigerator is not cooling. Reading your post you mentioned this just suddenly began to happen. Can you hear the compressor running? Is your fans blowing inside the freezer and below the refrigerator? Can you feel warm air coming from back and under refrigerator or cold air blowing inside freezer? Click on link below and enter your model in search feature. You will see 36 similar choices, just make sure you choose one that has refrigerator beside the model number. When you get to the correct page choose photo 10 control parts click it and you will see the Adaptive defrost listed in photo as item 6. Let me know those other things I asked in this message so I will be able to help you better, Thanks Sea Breeze
click be low link enter model GD5SHAXLB01 in search feature
http://servicepartstec.blogspot.com/
May 20, 2009 | Whirlpool GD5SHAX Side by Side...
I have a Maytag refrigerator. Before leaving for holidays four months ago I emptied it. When I came back from holidays I found ice in the freezer. I thought that the ice was harmful and i unplugged the...
Defected DEFROST HEATER can cause frost build up on the panel at the back of the freezer,and freezer stop cooling and ice frozen on unit so air could not flow to refrigerator side.Water will coming out caused of unbalanced freezing,and causing the flooding of water in the floor. You must change this defroster heater assembly so it will works normal again..
Heavy Frost on the Coils
This is good! This indicates a defrosting system failure which is a simple control problem. It also means that the sealed system (compressor, evaporator coil, and all associated tubing) is fine as wine in summertime. Defrost system problems are easy fixes that anyone with a pulse can do with maybe just a little help from their friends. The problem will either be the defrost timer (or Adaptive Defrost Control board, if so equipped), the defrost thermostat, or the defrost heater. To locate these parts in your fridge, check out these cool, interactive parts diagrams.
Just click below for more information;
There are 44 'Do-It-Yourselfer' stories about installing this part
Hope this may help you; Regards, VOTIT
Sep 08, 2008 | Maytag Refrigerators
Ice Cube Tray Sticks
53282922_1db7fdbcf7_m.jpgHeavy Frost on the Coils
Jul 13, 2008 | Refrigerators
Refrigerator Defrost Troubleshooting
you cannot do this
just check the defrost heater and the bi metal, if they check good then the adaptive defrost control is bad
Apr 25, 2008 | Maytag MSD2656G Side by Side Refrigerator
Whirlpool Gold White-on-White 21.9 cu. ft. Conquest Side-By-Side Refrigerator with Ice and Water GD2SHAXLQ Side by Side Refrigerator Logo
977 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
