Question about Gestetner DSm620d All-In-One Laser Printer
Paper Jam - NOT
My Gestetner keeps saying it is jammed and itis not. Can I disconnect the sensor and continue to print?? It says jam at B
    Sniper:
  • 86 Answers
No you can't disconnect the sensor to continue printing.
Try opening the front and right doors and then close them.
Switch off and on again after 5 seconds.
If jam B still there, possible causes may be:
Exit sensor defective;
Exit sensor lever stucked;
Check the registration sensor/lever;
Rotate the registration roller with your hand slowly - there may be a piece of paper keeping the registartion sensor On.
Good luck and please rate me, thanks.
Posted on Jan 30, 2009
My kyocera KM 1815 keeps saying "paper jam 00 open left cover and remove paper jam but there is no jam
Hi
Check all the paper movement from the tray, left or right cover, front cover, if so then remove jammed paper. Otherwise the paper sensor spring guide missing or fell off from its original position. Check carefully where the sensor locate. paper sensors detect all the paper movement in the machine during copying or printing, so locate the place in the machine which the paper usually jammed, see the screen of the machine, it will locate the place where the paper jammed mostly. Sensor not return to it original position that is why ( remove paper jam keeps blinking)
Aug 11, 2014 | Kyocera Mita Office Equipment & Supplies
Paper continues to jam
check the paper actuate of the sensor if it o.k check the sensor if its clean
Jun 24, 2014 | Gestetner C7425DN Paper Feed Roller...
My ricoh aficio 1035 shows a paper jam and it is cleared. There is nothing in the pathway. It continues to say there is a paper jam. What can I do? I've taken it apart in the area of the jam and...
There is an actuator type sensor between 1st paper tray and reg sensor.sometimes a piece of paper gets stuck there. Open the door on right dude and shine s torch down u may c a piece there. If not go into service mode and do an smc print and identify sensor with jam and test it in input mode.
Sep 13, 2011 | Ricoh Aficio 1035 Copier
4TH LIGHT FROM THE TOP KEEPS COMING ON LEXMARK E232
What this light sequence means that the printer has a paper jam.
When a paper jam occurs, the printer stops and the operator panel's Paper Jam light and Continue button lights come on. Press and release Continue twice quickly to display the specific secondary error paper jam light sequence.
How to clear Paper Jam
Press Continue button twice quickly to see the secondary error code.
To get the secondary error codes
When the Error light (!) and Continue button lights are both on, a secondary error has occurred.
When the Paper Jam light (4th light) and Continue button lights are both on, a paper jam secondary error has occurred.
Press and release Continue button twice quickly to display the secondary error code light sequence.
Press Continue button to resume printing once all the jammed pages are cleared from the paper path.
We recommend that you clear the entire paper path when a paper jam occurs.
To clear a paper jam:
1 If you are feeding paper from a tray, remove the tray, and then remove any jams.
2 Open the front cover and remove the print cartridge assembly.
NOTE: Do not leave the print cartridge assembly exposed to direct light for an Extended period of time. Extended light exposure can cause print quality problems.
3 Remove any jams in the area behind the print cartridge assembly.
4 Lift the flap at the front of the printer and remove any jams beneath the flap.
5 Open the rear exit and remove any jams.
6 After you have cleared the jams, reinstall the print cartridge assembly, make sure all printer covers and trays are closed, and then press Continue button to resume printing.
NOTE: The printer reprints the pages that caused the paper jam.
Jun 30, 2011 | Lexmark E232 Laser Printer
My cannon MP160 pixma keeps telling me there is a paper jam when there is no paper in it, it will copy and give me color tests printed out but if i try to print a doc. It says E# paper jam
Hello thanks for using fixya
Actually you are facing E3 error, E3 error is mostly because of paper jam. their may be small bit paper jam in side
There are some "micro-sensors" that detect a paper jam. There will be tiny piece of paper, or a lump of dust, inside those sensors, thus "tripping" the sensor and saying you paper jam.
To solve it
Open printer cover and check to make sure no paper or foreign objects obstructing the printer feeder
If you become sure that now really there is no paper, dust or foreign objects then
Turn the printer off, and disconnect the AC power-cable. Open the printer cover & now give the printer a "blow-job" by compressed air.
If still problem exist then best & final option is to just contact to any Canon service provider.
I hope this solution will helpful 4 u
Please don't forget to click on Four thumbs which are given below & then write testimonial for my appreciation if it is helpful
THANKS & Keep Using fixya
Feb 07, 2011 | Canon PIXMA MP160 All-In-One InkJet...
Message is paper jam. open door and press ok.. but there is no paper jammed. print cartriges do move but making a nasty snapping type noise. did what message says about10 times and still will not print.....
To solve it
Jan 30, 2011 | HP Officejet 5510 All-In-One Thermal...
Can't find paper jam. Looked and looked. Its a
hi if u cant find any bit of paper in paper path may be any path sensor out of order or may be dusty sensor just clean the all paper path sensors
thanks
May 13, 2010 | Gestetner DSm618d Copier
On my Gestetner DSc516pf copier the message keeps reading "paper jam". I have cleared out all paper and checked every place I know, but the message continues to appear. Can you be of assistance?
Do you see Any Error Message on the Display?
Unplug the Unit for Few Minutes, say 30 minutes and then Turn it ON. If the Problem Persists, more often it is a Hardware Failure.
In these Models, there is an Electronic Sensor that senses the Paper Jam. It seems that it might be at Fault. The Sensor is not Serviceable and it has to be replaced. These Sensors are not easily Available in the Market.If you could find the Sensor, i would be able to Guide you to Fix this. You need to have Schematics which we might find later on, once you would get the Sensor.
Note - I am taking into consideration that you have already checked and made sure that there is no Paper Jam.Sometimes, you might find small clips of Paper in and around the Rollers.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Mar 29, 2010 | Gestetner DSm516pf Digital Copier
Says Paper Jam but ther is no paper jam
It appear from here that the exit sensor may be dirty and you can use canned air and blow it out.
You may also be missing the paper out sensor that is located at the bottom of the printer oposite of the paper tray when you pull it out. When the flag arm has fallin out, it will give a false paper jam error when the last sheet has printed from the tray, not knowing or detecting that the tray is now empty.
Jul 02, 2009 | HP LaserJet 4 plus Printer
Gestetner DSm620d All-In-One Laser Printer Logo
215 people viewed this question
Top Gestetner Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
Norman  J Weimar Jr
Norman J Weimar Jr
Are you a Gestetner Office Equipment and Supply Expert? Answer questions, earn points and help others
