Question about GE Profile Spectra JGBP90 Gas Kitchen Range
Pre heat problem
When i turn on the oven it takes an extremely long time for it to heat up. Usually about a half hour to 45 minutes.
  • GE Master
  • 8,220 Answers
The good news is it does heat up. So that means the controls are ok and the safety valve is ok. So what could be causing the problem? A weak ignitor! The ignitor must draw 3 amps or better to properly open the safety valve. One way for the layman to tell for sure is to look at the ignitor. It should be very bright. If it is dim it is bad. Replace it.
Posted on Jan 17, 2009
How long will it take to cook a 6.6Kg leg of pork, it has beeen bones and rolled
35 minutes per kg in 180 Celsius oven so 3 and a half hours .
I would add 30 minutes to make sure and pre heat oven before putting in oven .
Nov 01, 2016 | Grilling
Does it matter at what time I take a pre-workout supplement?
Yes, Time matters a lot.
As your body needs some time to absorb all the nutrients and direct them to your bloodstream.
The best time to take pre workout supplements is 15-30 minutes before you start your workout.
If you want to get all detailed information about pre workout supplements and the guidelines to buy them then you can refer Weighted Training clothes.
Feb 04, 2013 | Health & Beauty
Pre heating oven takes 45 minutes to an hour what part would be needed
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
Jun 01, 2011 | Maytag CWG3100A Gas Single Oven
My oven is taking over 45 minutes to pre heat
If your electric oven is taking too long to heat or just not heating up right,then check out this tip that will give more detail about your problem.
Oven Problems Electric Oven is Heating Slowly or Poorly
heatman101
Jan 06, 2011 | Maytag Kitchen Ranges
Have a viking professional oven and it takes too
A weak oven ignitor will cause this problem. even though it eventually lights the temp has dropped considerably so you don't get consistent temp. turn the oven on and listen for the burner to light. should light within about 2 minutes. if not replace oven ignitor(s)
May 20, 2010 | Viking 27" Professional Select Built-in...
My new oven doesnot cook lasagna through evenly.
Hi Angela,
There are many different possibilities that can cause this issue. From a faulty thermostat, to placement of the food in the oven, or not giving the oven enough time to pre-heat before placing your food item in the oven to be cooked. I have found that on many ovens they can reach well over 450 degrees during the pre-heating cycle. I had a customer who called because her new oven was burning her brownies on the outside and they were not done on the inside. The customer told me that she would wait for the pre-heat signal beep(oven is ready) before putting the tray of brownies in the oven. When I initially checked the oven tempature using a fluke meter and a thermocouple at the center of the oven I found that the oven was close to 460 degrees when the beep went on to indicate the oven is ready! So that is why she was burning her brownies. It took another 10 minutes after that for the oven to stabalize and keep the tempature at 350. So you might want to give your oven 20 or 30 minutes of pre-heating time before you put your tray of Lasagna in the oven. Always make sure to place the food item at the center most part of the oven. And if you are cooking several trays make sure to stagger their position on each rack so they are not right above/below each other. The positioning is important because it can interrupt the natural flow of heat in the oven. So if you let it pre-heat for a half hour and are still having the burning issue then you should have the oven tested for proper calibration to make sure the thermostat is working properly.
Mar 10, 2010 | Garland H283 Gas Kitchen Range
Oven taking forever to heat up
The Oven heating Element is open circuit. Change the element.
Aug 01, 2017 | Kitchen Ranges
Taking a long time to heat up
sound like you may have a burnt fuse causing to run on half voltage check your fuses thanks from gilles
Mar 14, 2009 | Thermador RDDS30 Dual Fuel (Electric and...
Dishwasher runs for a long time
If your dishwasher's cycle times are too long, check these:
Water pre-heating
Cycle not completing
Water pre-heating Yourdishwasher may pre-heat the water. If so, and if the water entering thedishwasher is cool, the heater may take up to half an hour to heat thewater.
To avoid the wait, increase the incoming watertemperature before turning on the dishwasher. Do that by running thekitchen sink faucet until the water runs hot. Or increase thetemperature of the hot water to the entire house at the hot waterheater.
Warning! To lessen the risk of scalding, don't set the hot water heater temperature higher than 120 degrees Fahrenheit.
Nov 12, 2008 | Kenmore 24 in. 17362 / 17364 / 17369...
GE Profile Spectra JGBP90 Gas Kitchen Range Logo
266 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Craig Butler
Craig Butler
Are you a Kitchen Range Expert? Answer questions, earn points and help others
