Question about Durabrand DUR7 Portable DVD Player
Sips freezes then continues
After playing a movie for a little while..maybe 1/4 through, it starts to skip, then it freezes for a moment and then continues on like there was no problems. It will play the dvd fine for a little while then do it again...this continues on through the movie. I've cleaned with a laser disc cleaner, I've done the little black button trick (which solved the loading but not really loading problem) But I still can't figure out why this problem still exists. My kids use this player more than I do as we travel between states alot. I through one out and bought this one because the first one I was watching was doing the same thing...now this one...I'm not sure why, what is causing it or how to fix it...this problem occurs with new dvd's as well...please help...
    Problem Solver:
  • 10 Answers
Are you buying the same dvd player???if so it might be a recall and they haven't got around to it yet....other than that it maybe getting too hot is the dvd player vented at all....
Posted on Jul 24, 2007
SOURCE:
Philips hts3541 wont play new blu-ray movies
Sounds to me like a laser alignment issue, quickly get a support case going with the Manufacturer as most have a one year warranty whether or not you have a receipt.
Nov 02, 2013 | Televison & Video
Picture freeze,long tme to restart does it again
Unless you have good / fast access to the Internet (or wireless or 4G network), it may take a long time to download a movie to your device. If the speed of download is slower than the speed of the play, the picture freezes ... essentially, it is waiting for the completion of the download for the next few frames (of the movie). That is why the picture freeze .... and it will start again after sufficient data has been download to continue / start playing (the movie) again.
Apr 30, 2013 | Cricket Wireless Cricket Crosswave WiFi...
It freezes while playing dvd's about every ten minutes. It does allow you to skip forward and continue playing but makes you skip an entire chapter. What causes it to freeze?
Mt SD-1800 does the same thing, plays for awhile and then gets stuck. I took it apart and cleaned the rails and the optical lens but no help. I noticed that the head did not slide back and forth without cogging. It turns out that the little pinion gear on the motor was cracked. Every revolution it would catch on the tooth by the crack. I doubt that there are replacement parts available.
Sep 10, 2011 | Toshiba SD-1800 DVD Player
Dear Sirs, Recently, my Sharp dvd-video combi player has been encountering some problems regarding the playing of dvd's. When I watch a movie, in several occasions the movie will freeze up. And for...
the DVD unit in your sharp is a self contained unit. IT is only repaired by replacing the DVD as a assembly. the cost of replacing may exceed the cost of purchasing a new one.
The most likely cause of your problem is in the brass gear assy that runs the optical pick up in the traverse deck. IT is not an available part.
Feb 17, 2011 | Televison & Video
Freezes during playback
Hi. What I am trying to establish from my last question is whether the laser has become heat sensitive or whether there is a bit of dust buildup on the spindle table that might be causing the disc to have excessive wobble.
If the disc has excessive wobble, then the machine will have trouble tracking the outer tracks and will constantly skip as you have described after say 30 to 45 minutes.
If the laser has become heat sensitive then the same problem could potentially occur - The only difference being that if you were to restart the movie at that point, then the skipping would continue even at the beginning of the movie.
The first problem (wobble) is easy to fix - Clean the spindle table, the second problem may render the unit uneconomical to repair.
Mar 16, 2010 | Samsung DVD-V5500 DVD Player/VCR
CH-DVD 300 Freezes Then Skips Ahead
Chech the laser lens rails maybe got dirt clean it take off the grease they got.
Jun 26, 2008 | Cyberhome CH-DVD 300 DVD Player
DVD Freezes during playback
it might be that you are playing a dual layer dvd in the player. The player needs to focus on the second layer of the movie, and that might be why the dvd freezes. Leave it there for a while and the dvd should continue if it is this situation.
Dec 08, 2007 | Sony AVD-C70ES DVD Player
Freezing
Probably needs either a cleaning or a new laser picup assembly
Dec 19, 2006 | RCA ® 700 Watt Home Theatre In A Box...
Durabrand DUR7 Portable DVD Player Logo
73 people viewed this question
Top Durabrand Televison & Video Experts
Steve Allison
Steve Allison
matt martin
matt martin
Are you a Durabrand Televison and Video Expert? Answer questions, earn points and help others
