Question about Durabrand DUR7 Portable DVD Player
Skips and freezes, then continues
After playing a movie for a little while..maybe 1/4 through, it starts to skip, then it freezes for a moment and then continues on like there was no problems. It will play the dvd fine for a little while then do it again...this continues on through the movie. I've cleaned with a laser disc cleaner, I've done the little black button trick (which solved the loading but not really loading problem) But I still can't figure out why this problem still exists. My kids use this player more than I do as we travel between states alot. I through one out and bought this one because the first one I was watching was doing the same thing...now this one...I'm not sure why, what is causing it or how to fix it...please help...
The disk is probably dirty
Posted on Jun 30, 2007
SOURCE:
It freezes while playing dvd's about every ten minutes. It does allow you to skip forward and continue playing but makes you skip an entire chapter. What causes it to freeze?
Mt SD-1800 does the same thing, plays for awhile and then gets stuck. I took it apart and cleaned the rails and the optical lens but no help. I noticed that the head did not slide back and forth without cogging. It turns out that the little pinion gear on the motor was cracked. Every revolution it would catch on the tooth by the crack. I doubt that there are replacement parts available.
Sep 10, 2011 | Toshiba SD-1800 DVD Player
Lg dvd player stops or skips plaing dvd movies
These unit have a problem with the complete assy.mech needs to be replaced if cleaning does not take care of the problem
Apr 10, 2010 | Televison & Video
My ps3 does not load games or movies, screen stays still with the circular load symbol at the the top right corner, anything i can do at home to fix this?
Try this:
  1. Back Up your PS3. You will need a compatible external hard disk drive for this step.
  2. Enter Recovery Mode.
  3. Choose "System Update".
    Try to load a game or movie. If it works, skip the rest of the steps listed below; otherwise, continue.
  4. Re-enter Recovery mode, and choose "Restore Default Settings".
  5. Re-enter Recovery mode, and choose "Restore File System".
  6. Re-enter Recovery mode, and choose "Rebuild Database".
  7. Re-enter Recovery mode, and choose "Restore PS3 System". WARNING!: This option will delete everything on your PS3 hard disk drive!
  8. Return the unit to Sony. If your PS3 is still under warranty the fix will be free; otherwise it will cost $150.
Mar 25, 2010 | Video Game Consoles & Games
Freezes during playback
Hi. What I am trying to establish from my last question is whether the laser has become heat sensitive or whether there is a bit of dust buildup on the spindle table that might be causing the disc to have excessive wobble.
If the disc has excessive wobble, then the machine will have trouble tracking the outer tracks and will constantly skip as you have described after say 30 to 45 minutes.
If the laser has become heat sensitive then the same problem could potentially occur - The only difference being that if you were to restart the movie at that point, then the skipping would continue even at the beginning of the movie.
The first problem (wobble) is easy to fix - Clean the spindle table, the second problem may render the unit uneconomical to repair.
Mar 16, 2010 | Samsung DVD-V5500 DVD Player/VCR
CH-DVD 300 Freezes Then Skips Ahead
Chech the laser lens rails maybe got dirt clean it take off the grease they got.
Jun 26, 2008 | Cyberhome CH-DVD 300 DVD Player
Has stopped playing
Skipping
Remove and replace the graphite grease from the laser transport worm gear assembly (use the correct Technics stuff), replace the worm gear drive belt, and ensure that the tension spring on the C-shaped plastic piece that rides the gear is OK
Nov 24, 2007 | RCA RC5220P DVD Player
Sips freezes then continues
Are you buying the same dvd player???if so it might be a recall and they haven't got around to it yet....other than that it maybe getting too hot is the dvd player vented at all....
Jun 19, 2007 | Durabrand DUR7 Portable DVD Player
Freezing
Probably needs either a cleaning or a new laser picup assembly
Dec 19, 2006 | RCA ® 700 Watt Home Theatre In A Box...
Durabrand DUR7 Portable DVD Player Logo
123 people viewed this question
Top Durabrand Televison & Video Experts
Steve Allison
Steve Allison
matt martin
matt martin
Are you a Durabrand Televison and Video Expert? Answer questions, earn points and help others
