Question about Xerox FaxCentre F116 Plain Paper Laser
Fax Machine not picking up incoming faxes...
Sends No Problem - Does not pick up on incoming faxes.
The fax machine is on a company phone network. I am using a master mod tap. I plugged a analoge phone into the adapter from the data socket and if I ring the number the phone rings.. ?
The machine, however, does not pick up the fax.
I was looking thought the menus/manual for an auto answer type of setting but i have had no joy?
Any Ideas?
  • 239 Answers
If this is on a network your network tech needs to set up your machine through one of the routers.
If the machine was pluged into the phone socet direct, there would be no problem. The phone will ring constantly, until you plug the phone to the machine.
If the machine does not answer the phone, then the problem maybe in the machines confguration for auto answer, or a modem board not working.
But on a network, the computer is trying to find the signal, but can't because it cannot find the machines signal.
This problem is in the network side. Check with your network specialist.
Posted on Oct 17, 2009
I have a xerox f116 faxcenter machine that I bought from an online auction. When I set it up and put a document in to fax, it came up with a message that said 'REMOVE DOCUMENT STOP TO CONFIRM'. The...
Go to the link below and see page 116 for your solution. The link below takes you to the users manual for your model unit:
ttp://download.support.xerox.com/pub/docs/FaxCentre_F116/userdocs/any-os/en/userguide.pdf
May 25, 2011 | Xerox FaxCentre F116 Plain Paper Laser Fax
I would like to block all incoming faxes on the faxcentre f110 so that it is an outgoing fax only, how do i do this?
You don't really need to block incoming faxes, but just set the machine not to automatically answer them. This figure is from the manual:
Press the MODE button until you see MANUAL displayed. In manual mode you need to answer and start receiving a fax yourself from the machine.
You can download a copy of the user manual from Xerox if you need it.
Dec 17, 2010 | Xerox FaxCentre F110 Plain Paper Laser
Trying to clear the memory of a Xerox Faxcentre F116. Do you know the steps to accomplish this?
One needs to know what they are doing when resetting memory to the machine.
When resetting the machine, one needs to consider, the loss of memory data on the copy cartridge counter in the machine.
When resetting memory a copy toner cartridge needs to be in stock with a counter reset card.
Erasing memory will wipe out the old copy/toner cartridge odometer setting, resuling in "Replace toner/cartridge" error.
Please clarify which memory area is being erased.
Aug 05, 2010 | Xerox FaxCentre F116 Plain Paper Laser
How do I get the confirmation page to print>
On the machine there should be a menu key to check the settings on the fax answer/send mode.
Scroll to the different menus and check for confirmation page, on/off = on.
Jun 21, 2010 | Xerox FaxCentre F116 Plain Paper Laser
I forgot the code on my xerox fax confirm f116
Check menu,8,2. You may be able to print out the road map on the different menue configuration.
You should be able to print out by
selecting menu ,*, 8 and printed with Menu, "*", 1.
Not seeing the machine is difficult to see the different ways the menus are going to.
Technical parameters are different and has a different enter mode. This needs to be researched further for explination.
Good luck, this may take a lead in the right direction.
Nov 12, 2009 | Xerox FaxCentre F116 Plain Paper Laser
We want to be able to fax out on our Xerox copy/fax machine but
First of all, I beleive the machine came with software on the disc. If you have not installed the software, install it. There might be some menus in the computer and the Fax machine, so you can change these settings to manual and automatic.
The machine should have a operators manual also, check the manual for manual fax recieving.
Also we do not know if you are using XP or Vista.
Check with Xerox.com for latest drivers and software updates.
Even though the fax is connected to the computer, there has to be a bridge that communicates these fax procesess.
This might be a service call you would need with Xerox.
Jul 28, 2009 | Xerox FaxCentre F116 Plain Paper Laser
Don't want a transmission report after each sent fax
On the machine there is a menu button.
the menu can be printed out so you can see all the areas to select.
If you scroll to through the menu, you will find a set up or incoming fax menu.
You need to set confirmation to off.
This will take some time to find the right menu, so be patient with the machine.
Good luck.
Feb 23, 2009 | Xerox FaxCentre F116 Plain Paper Laser
Incoming faxes from multiple locations jamming our machine
I believe there should be a "Clear memory", or "dump fax Memory", in the menu selection.
Press reports and scroll to machine print out. You should get a print out on the machines configuration and help menu to better assist you.
This should dump the memory so you can prepare yourself for new incoming faxex.
Dec 08, 2008 | Xerox FaxCentre F116 Plain Paper Laser
How to add the fax from the xerox fax-center f116 into my network?
here is the driver, try installing it.
it picked up the machine as a plug and play, but Vista does have some problems so..... try it
http://www.support.xerox.com/go/results.asp?Xtype=download&prodID=F116_F116L&Xlang=en_US&Xcntry=USA
good luck
Dec 14, 2007 | Office Equipment & Supplies
Xerox FaxCentre F116 Plain Paper Laser Logo
1,483 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
