Question about Hotpoint Aquarius WMA42 Front Load Washer
Hotpoint aquarius mwa42 will not empty
Took the pump out of the washing machine it feels very hot, there wasnt much dirt in it, does this mean the pump has gone and needs replacing
  • Hotpoint Master
  • 3,463 Answers
The pump itself should not be hot to touch, only warm, I would suggest a new one needs to be fitted.
Plz rate my solution.
Thanks.
Posted on Jan 16, 2009
WMA54 won't empty water? We've emptied filter but
Could be the pump, but they do not often fail.
I would check the main hose or the pump itself for a blockage.
Try blowing down the hose to see if it is clear.
Mar 03, 2010 | Hotpoint Aquarius WMA42 Front Load Washer
Hotpoint Aquarius WF740 My washing is coming out with dirty marks and bits of slimy dirt. I wonder if it is from the door seal as this is dirty or could it be something else? I used the persil gel filled...
Your pipe to the water pump exit is probably blocked with bits of old fluff or missing sock, i found that the clothes had slimy bits on mine, i tilted it up and removed the rubber water exit pipe from under neath, cleaned out all the rubbish and works a treat now.
Oct 19, 2009 | Hotpoint Aquarius WMA42 Front Load Washer
Unscrew and remove lower rear cover of washer.
On the bottom right hand side, you will see the pump located, it has 2 hoses going to it.
Remove both hoses, unplug wires going to it, and slide the pump to the left, it may or may not have a fixing screw at bottom,remove pump and check.
If you need to check the filter, then remove large black hose going to bottom of tub, remove plastic filter ,and clean
Refit filter and hose, and test.
Thanks.
Jan 16, 2009 | Hotpoint Aquarius WMA42 Front Load Washer
Hi, my hotpoint aquarius wma42 washing machine washes ok but will not empty, i have took the filter out of the back and cleaned it, but its still doing it. can you advice
Make sure there is nothing stuck in the pump, and that the outlet hose is not blocked or kinked.
If o/k , then you need to confirm that the pump itself is working
Select drain only. or drain and spin, and you should be able to hear the pump running, if you are satisfied that there is no blockage any where and the pump is running, but no water comes out,
Then fit new pump
Thanks.
Fault code on washer/dryer
Hi.
F05 means pressure jammed on full or pump not draining.If pump o/k, then you will neeed to call an engineer.
Nov 23, 2008 | Hotpoint Aquarius WD640 Front Load...
Hotpoint wf740 washing machine
An F-05 error message means that the pressure switch is jammed on empty or a problem with pump.
The fault is associated with drain out (pump blocked or restricted in some way).
Small panel at rear of machine reveals the pump, pull of the two pipes (Plastic clips hard to get off, slide them sideways), remove wire and unclip pump from base of machine by lifting locking tab and sliding to the left, pump can then easily be cleaned.
Oct 01, 2008 | Hotpoint Aquarius WF000 Front Load Washer
Wf540 hotpoint washing machine making a banging noise
remove lower front panel pump right of center turn small plastic handle counter clockwise pull out
May 31, 2008 | Hotpoint Aquarius WF000 Front Load Washer
HOTPOINT AQUARIUS WF250 1500 SPIN
check the cold water supply, either from the mains pipe, there is no water getting into the machine, if water is there up to the machine check the solenoid for circuit, to do this unplug from electric, remove lid, and test the two wires on relevant solenoid, no circuit means faulty solenoid, (test with the 2 wires removed from solenoid) take care note position of wires to put back properly answer above based on info given
Sep 24, 2007 | Hotpoint Aquarius WF000 Front Load Washer
Hotpoint Aquarius WMA42 Front Load Washer Logo
37 people viewed this question
Top Hotpoint Washing Machines Experts
hungoverrr
Level 1 Expert
puggy666
Level 1 Expert
gbob59
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
