Question about McCulloch FH180A Electric Pressure Washer
FH180A arrived with the on/off switch in pcs in bottom of box
Can I get a spec on how to put the switch together, cannot tell just by looking at the various pcs. Where do the electric contacts go?
Although I purchased the McCulloch Power Wash FH180A through Fingerhut, my only option with them was to return it. I purchased it on clearance and there wouldn't be another to replace it. I called McCulloch direct and spoke with a representative who offered to send me a new on/off switch. He advised that since they have been purchased by Husqvarna and they are in a transition, it may take 2 to 3 weeks to receive. I thanked him very much for the generous offer and look forward to its arrival. I tried to find my post on your website and gave up after page 93. Thanks, Darlene
Posted on Jan 19, 2009
What are the latest arrived MXQ SERIES android TV boxes?
Some of the newly arrived MXQ Series Android TV boxes are:
a. MXQ-M9X Fully Loaded Kodi Box 2GB/16GB
b. MXQ-M9X Fully Loaded Kodi Box 3GB/32GB
a. Custom Launcher
b. Top Hardware Spec.
c. Comprehensive on Device User Guides.
d. Amazing Performance.
e. Android 5.1 Operating system.
f. Plays 4K with no problems.
g. Up gradable by adding HDD, etc.
You can see the whole details about these Android TV boxes from Kodi Box. Here, you can also order them on best interesting offers and discounts.
Jul 15, 2017 | Televison & Video
How can I put this together? I lost the instructions!!
you have a picture,lay the pieces out and you'll be able to pretty much tell what goes where by looking at the picture,You've put together a puzzle by looking at the lid of the box ? no diffrent.And don't forget to put a spot of glue on the stand and the screw, it will be much more sturdier.
Feb 19, 2015 | Miscellaneous
When i put a bat609 batt in unit it kills the battery happened 3 times whats wrong?
Looking on the site, the specs show there are different models of the PB360D and they use 4 different size and voltage batteries; 14.4v and 18v. SlimPack and FatPack. The BAT609 is 18V SlimPack. Perhaps you need the BAT607 which is 14.4V SlimPack. Best way to tell for sure is go to At the bottom of the page, go to "Spare Parts". On that page, enter the 10 digit model number of the radio and it will tell you the correct battery.
Oct 15, 2013 | Bosch PB360D Deluxe Power Box Jobsite...
Dorel #TB-722W
Here is a pdf for a Dorel toddler bed.
It should help you put your one together, even if it isn't exactly the model that you have.
Good Luck
Sep 05, 2012 | Baby Gear
I have used the McCulloch (FH180A) three times over the course of two years. On my fourth use the pressure washer just surged on and off and I would get a tiny spray from the gun each time it surged. In...
Sounds like the problem could be low input water flow or pressure. There could be crud on the intake where you hook up the garden hose, there could be some other sort of blockage. Try hooking it up to the hose and pull the trigger (with the power switched off) and wait to see if water comes out the tip. Also look at the tip(s) themselves. sometimes a piece of crud gets into the hose and then clogs the tip.
May 15, 2011 | McCulloch FH180A Electric Pressure Washer
I just put together and i have 3 metal pieces with screws and im not sure what do do with them?
Tell me more How long are these pcs.? There a Phone # to call on the box 24/7 There are three bracket that hold the tank in place. Ken's Repair
Jan 19, 2011 | Zubri Z1-12 Open Flame Patio Heater
Wiring bath fan with Fan/ light combo. Want to operate the features on seperate switches. Have power wire Black/ White/Green. Each switch has own wire Black/White/ Green. In the unit there is a Blue/white...
If I understand correctly you are installing two wall switches.
Your switches are switch1 and switch2
Each switch has 2 brass-colored screws
If you have a double switch, see page bottom
And you are installing a fan/light combo with separate wires for fan and light.
Bare ground wires and green wires connect to each other and to green screw. A ground wire runs from fan/light to switch box where it connects to other bare copper wire and these wires will not be discussed.
Lets work from the fan/light down to the switch.
Blue-wire-fan connects to either brass screw on switch1
White-wire-fan connects to white Neutral (we'll talk about this wire as we go)
Black-wire-light connects to either brass screw on switch2
White-wire-light connects to same Neutral as White-wire-fan.
So you need 3 wires running from fan/light to your switch box.
One wire arrives at switch box and connects to brass screw on switch1
One wire arrives at switch box and connects to brass screw on switch2
One wire is the Neutral wire and it arrives at switch box and connects to other white wires inside switch box. Twist these wires together and cover with wire nut.
Now your white Neutral is connected to other white wires in switch box.
Each switch still needs another wire.
The Hot black wire from breaker box connects to brass screw on both switches
Pardon the crude drawing.
The switches would actually be located next to each other, but it was easier to draw like this.
Drawing shows 3 wires coming from fan-light to switch box.
The drawing shows the black and white wire arriving from breaker
The drawing does not show how the white wires are joined with a wire nut
If you have a double switch, with 2 switches stacked vertically.
The screw colors can be different.
Double switch could have brass screws on both sides, in which case your Load (fan-light) wires connect on one side of device, and your Hot from breaker connects to other side. It doesn't matter which side, but loads on one side, hot on other side.
Double switch could also have dark screw(s) on one side and brass screws on other side.
In this case, the black Hot from breaker connects to dark-colored screw(s)
And your Load (fan-light) connect to brass colored screws.
If you need more information, or if something is still confusing, answer back.
Oct 26, 2010 | Broan-NuTone Fan,Bathroom Exhaust Broan...
I just bought a switch to control both fan speed and light control (dual switch) i hooked it up every thing worked fine. then to realize that the outlets that follow dont work. just as a clue on the...
The key seems to be that you changed wiring in the ceiling box.
I suggest you make a drawing of the wires before and after. Track the route that the Hot wire takes.
The key question is this: Does Hot wire from breaker box arrive in the ceiling box first? Or does it arrive in wall box first?
I think Hot from breaker arrives in wall box first. And from there Hot wire goes to ceiling box ... and from ceiling box the hot wire goes to other plugs in room. If this is true, you will be one wire short for installing fan control switch.
I always make a drawing of existing wires before starting, so I can put it back the way it was. It sounds like you got a good handle on which wire goes where.
We used to solve the one-wire-short problem by making a simple project bigger. Figure out which direction ceiling joist run. See if you can slide fish line from fan ceiling box over to wall. If that works. Over at the wall, chop small hole in ceiling so you can feed wire up to fish line. Pull wire over to ceiling box. Next, staple other end of wire along ceiling over to location above wall box. Chop another small hole so you can feed wire down to wall box. And then install beautiful crown molding to hide the mess, and paint the room so you need new furniture.
Oct 02, 2010 | Electrical Supplies
How do I replace bank 1
memory goes into a spot on bottom of pc. flip it and remove the trapdoor and put in more or switch the ram. make sure it is the right type and speed and that it wont exceed the motherboards limit per slot. look up the specs for your laptop and it will tell you what you can or cant use
Dec 01, 2009 | E-Machines M5305 Notebook
Head gasket replacement procedure, and what to look out for, re/ complications, if any BTW, engine is 3.1
Best bet is to get yourself a Haynes manual. It will give you all the specs that you will need when putting it back together.
One thing to be sure to do. Put 6 holes on each side of a box. Label one end crank and the other end trans. There should be two rows of 6 holes between your label's. As you take the push rods out put them in the corresponding soles in the box. Your intake and exhaust rods are different lengths.
Also check real close before you replace the head gaskets. These 3.1's and 3.4's are famous for the intake gaskets being bad at the corners.
I can't begin to tell you how many I have replace over the years, and I can only remember one head gasket.
Hope this helps.
Aug 13, 2009 | 1997 Chevrolet Monte Carlo
McCulloch FH180A Electric Pressure Washer Logo
129 people viewed this question
Top McCulloch Garden Experts
Roland W VanLue
Roland W VanLue
Are you a McCulloch Garden Expert? Answer questions, earn points and help others
