Question about Toshiba TP50F60/61 TV
No cable picture or sound
Tv will play dvd movies and video games beautifully, but that's it. Regular satellite tv is all snowy and no sound. Hooked up different tv and works fine so not satellite. Happened once before a week later worked fine. It's been 2 1/2 weeks now and I think it's not coming back. Any suggestions?
  • 23 Answers
Only thing I can think of is for you to check your cables... assuming you are using a coaxial cable for the satelite and rca cables for games and dvds, I would recommend trying a different coaxial cable. There is also the chance that the coaxial connection on the tv itself is messed up. you may try buying an RF modulator that will convert coaxial to rca, most rf modulators convert rca to coax. so make sure it does what you need before you buy it. tech guys at store should be able to help if you can't figure it out.
Posted on Jun 19, 2007
SOURCE:
Snowy picture
  • 1 Check the power. Don't be embarrassed if your problem is as simple as an unplugged power cord. It's better that you should discover this than pay a repair technician to come out to your house and find out.
  • 2 Isolate the problem. The main troubles that will crop up with a TV set are either no picture, no sound or both.
  • 3 Check the input setting on your remote control. If you have other devices connected to the TV, such as a video game system, those devices must be used with a different input setting than the input you use for watching programs or movies on a DVD or Blu-Ray player. Chances are, the kids were playing a game and forgot to turn the input back the way it was.
  • 4 Press the Input button on your remote control to return to the setting you wish to use. For example, the cable box might be connected to Input 1 and your DVD player might be connected to Input 2. Newer television sets have at least 3 inputs.
  • 5 Check the coaxial connection from your cable or satellite receiver to the television. The cable should be attached securely by twisting the round lock nut clockwise. Also check the power connections for the satellite or cable receiver. If either is unplugged, you won't receive a programming signal on the TV.
  • 6 Make sure the video cable is securely attached to the TV jack if you have a home theater system. The video cable runs from the Video Out jack on your home theater receiver to the Video In jack on the back of your TV.
  • 7 Check your receiver setting. Home theater receivers manage several components, so if you have the receiver set to operate the CD player but you are trying to watch a movie on your Blu-Ray player, you'll need to change the selection to Blu-Ray to watch the movie on your TV.
  • 8 Check the TV speakers to see whether they have been muted by accident. Press the volume button on your remote control or go to the Menu section and scroll down until you reach TV Speakers. Toggle left or right to turn the speakers on or off.
  • 9 Press the speaker button on your receiver to make sure your external home theater speakers are activated. Many home theater systems use external for their superior audio rather than the speakers inside a television
  • pls rate or vote on me
    Feb 05, 2011 | Sony KP-61S75 TV
    TV screen shows static
    change the input back to what it was before he got ahold of it .
    Aug 12, 2017 | Emerson EWF2004 20" TV
    Xbox 360 plays movies fine but colour is wrong on games
    i will suggest if you new tv has more inputs, just try a different imput, and make sure the plugs are in all the way. this is a new tv so it will be tight.
    same with the video connection on the back of xbox well plugged and straigt.
    hope this woks. and remember to rate me if i helped you
    Oct 09, 2009 | Microsoft Xbox 360 Console
    Volume low when watching dvd
    Not much you can do about this. The movie industry sets movies to low volume when recording for better sound. They expect you to have the equipment to boost the sound. This cuts down on their outside noise. Only solution for this is to install external speakers as I have done for my movie or TV playing (I installed a TV adapter so I could hook up a projector and display the BIG game outside) but as you say, we couldn't hear it until I hooked up external speakers.
    Dec 27, 2008 | Toshiba Satellite A135 Notebook
    Screen flickers when I play a BD movie on my PS3
    Does it do this with all Blu-Ray movies?
    Have you tried a different HDMI cable?
    Jun 18, 2017 | Sony Playstation 3 (PS3) Console
    PHILIPS TV SOUND PROBLEM
    My phillips tv model # 55pl9773/17 sound is too low when im watching regular tv, but when i switch from tv to av1 or av2 (watching a dvd movie or playing video games) the sound is normal. How do i get my cable TV to sound the same?
    Sep 28, 2008 | Televison & Video
    Snowy screen just pops up
    Bad tuner in tv....might be possible to solder bad connect in
    tuner...........T.
    Dec 14, 2007 | Hitachi 43FDX01B TV
    Phillips Projection TV
    make sure you have the correct video input connected, play a movie in the dvd player do you get anything, can you use a different video input?
    if all is correct go to the menu and see if the menu screen comes up.
    Dec 02, 2007 | Philips Magnavox 51MP392H Rear Projection...
    Hitachi screen goes snowy and sound is totally distorted
    Sounds like bad solder connect in tv tuner....can usually be
    repaired or replaced.......................T.
    Nov 30, 2007 | Hitachi 43FDX01B TV
    MDVD-6838 and Panasonic Plasma TV incompatibilty
    1 click SETUP(left just below the four arrow w/ enter button in the middle)
    2 click DISPLAY
    set tv system to AUTO
    tv image to 16:9 WIDESCREEN
    video setup (depend on the connection)
    s video or RGB
    Nov 08, 2007 | Wanlida Group MDVD-6838 DVD Player
    Televison & Video Logo
    107 people viewed this question
    Top Toshiba Televison & Video Experts
    Jaime Hernandez
    Steve Allison
    Steve Allison
    Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
