Question about Whirlpool Duet GHW9150P Front Load Washer
Washer continues to leak fresh water into washer tub
The washer continues to leak fresh water into washer tub just like a leaky faucet. what is causing the problem? should i change the water intake values? if yes, how can i the washer's schematics?
also is there a lint screen on the whirlpool deut washer?
Thanks
  • Whirlpool Master
  • 744 Answers
This video will show you how to find that leak on any front loading washing machine
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
And don't forget to like us on facebook
Posted on Aug 05, 2013
  • 61 Answers
You water valve is not closing good you could have a bad valve the valve is not closing properly the easiest thing to do is replace the water valve remove the top off the washer the schematic is the taped to the inside the cabnet or remove the bottom cover and it will be taped to the inside cabnet there. I would get a new valve though. Dissconect the power and turn off the water. remove the top by tacking out the 3 1/4" screws from the back and sliding the top to the rear and lifting off. Disconect to hot and cold water fill hoses from the machine, remove the mounting screws from the valve remove the valveinstall new valve and put mounting screw back in then remove wires from old valve one at a time and place on new valve in the proper position. reconect hot and cold fill hoses be shure to hook the up to the right side reconct power and turn the water on and put the top back on you machine should be back in good working order now .
Posted on Jan 16, 2009
Have changed all washers and reseated taps in shower but shower head still leaks
hi mark.
this is all i could find on the internet,if this is no good to you go to the link at the bottom and see if it helps you out.
First, feel the water leaking from the tub spout or shower head. If it's warm, you know that the leak is coming from the hot-water valve. If the water has been dripping for a while and it is cold, the leak is probably coming from the cold-water valve. 1Start by removing the faucet handle.22 Nov 2016
How to Repair a Leaky Shower Faucet Valve - HomeTips
shower head leaks Google Search
Nov 18, 2017 | Home
Washer leaks a little water when I put in a full load in it. Also leaks bleach when poured into dispenser. This is a top loader
Do you now where the leak is coming from? You may have to remove the outside sheet metal to observe the motor and tub. More than likely, the leak may be caused by a faulty pump or a seal in the pump.
If the machine overfills, you can get water on the floor as well, but you would notice that the machine appears too full.
The leaky bleach dispenser probably just needs to be removed, inspected and thoroughly cleaned. Water gets pumped thru it and any clog or problem with the pathway the water follows can cause overflow or a leak. BUT deal with the water problem first, that's the most important. A leaky pump will only get worse.
Also check the hose connections on the back of the washer. Old and cracked rubber washers can allow water to leak.
Sep 25, 2015 | Kenmore Washing Machines
Water continues to leak into the tub after the washing process, including spinning process has been completed and the washer has cut off.
That is a leaky water supply valve. They are not very much money and easy to replace. Before you do the rapair place the washer in spin and shut off the water faucets. You can finish the washing for the day. You remove the inlet hoses and these 2 screw that hold it to the frame. You must flip up the controls and remove the case to get to the water valve.themobilian_2393.jpg
Video: How to get into the machine
May 24, 2011 | Roper RAS8445KQ Top Load Washer
Leaky Tub Faucet (Antique Reproduction)
sometimes check the faucet screws they come loose or if they are old you might want to replace the whole diverter, take them to lowes or home depot and have them guys in the plumbing department hook you up. trust me you are opening a can of worms with rubber valve seats just get new ones. Make sure before pulling you cut off water supply to them.
Jul 20, 2010 | Home
Leaky faucet
From the sounds of it. It is time to call in a Pro. Be sure to check references. I hope all goes well.
May 26, 2010 | Grohe Seabury Roman Tub Faucet with...
I have an older Whirlpool Model #LBR5232EQ1 which is starting to leak into the tub. Within a week it is full enough I either have to run a load or else run the drain cycle. What can be causing this? This...
It is a leaky water valve. They develop a leak just like a faucet. To change the valve you need to flip the controls up to access the valve. I have some repair videos which show how to get into the machine: HERE
Feb 16, 2010 | Washing Machines
How do I repair a leaky Moen faucet handle. When I
It needs a new cartridge. Moen gaurantees most of their products for life, so if you have the original instructions check for contact info. They'll send you a new cartridge for $0.00
Jan 13, 2010 | Moen & One Handle Tub & Shower Faucet
It is leaking under the washer tub
Leaking water from a washing machine usually comes from hoses or connections. Be sure that water appearing to be a
leak isn’t drain water from a backed-up standpipe. To prevent potential flood damage, which can occur if washing
machine supply hoses burst, be sure to install “no-burst” stainless-steel mesh hoses and lever-type shutoff valves,
as shown below. With these, you can easily turn off the levers for both hot and cold water between wash days.
1) Check the fittings where the hoses connect to the faucets and to the back of the washing machine. Also look for
worn or leaky hoses. Tighten couplings or hose clamps if needed, or replace the hoses altogether. Be sure to turn
the water off before removing the hoses, and drain them into a bucket after disconnecting them.
2) Determine whether the machine is oversudsing, which can cause the machine to overflow. Reduce suds by pouring 1/2
cup white vinegar in 1 quart water into the washer. Then switch to either less detergent or a low-sudsing variety.
3) The machine may have a faulty basket gasket or tub seal and bearing that must be replaced; in this case, call an
appliance repairperson.
Thank You for contacting fixya.com
Oct 12, 2009 | Washing Machines
Leaking underneath but all hoses are connected
When a washer is leaking, there are several areas where the liquid could be coming from.
If it only leaks during a spin cycle, it's probably caused by a leaky drain hose
Leaks on a front-load washer can occur around the door seal. This can happen because of a build-up of dirt and soap on the seal itself preventing a proper seal from taking place. Wipe the door seal carefully making sure that the edge of the gasket is clean.
Parts of a plastic bleach dispenser can crack or break off, causing a leak intermittently during the flush process. This is because bleach is a very corrosive chemical. Heavy use of liquid chlorine bleach can pit and rust stainless steel parts..
You'll want to confirm that the fill hoses are connected and properly tightened. Always use new rubber washers when re-installing the hoses. Take care not to over-tighten the connection. Other leaks may be caused by the drain hose being cracked, or by a leaky connection at the water-inlet valve. Too many suds may cause the appearance of a leak when actually it's just a sudsy overflow. Sometimes a drain hose leak occurs at the end of the hose where it attaches to the washer. If the hose is long enough you can cut the leaky end off and re-clamp the hose back on. Usually though, when a hose begins to leak, it is best to just replace the hose.
Many pump leaks happen around the seal on the pulley. Some pumps have a weep hole that lets water drip out when this seal begins to go bad. The solution is to rebuild or replace the pump.
Tub leaks are usually caused by a rotted tub. If this is your problem, consider buying a new washer. Sometimes a constant imbalance can be the culprit. This imbalance can rub a hole in the tub if it consistently runs off-balance. It may be possible to repair the tub with an epoxy kit. Tub replacement isn't usually very economical.
The main tub seal can also leak. This is located where the transmission and the outer tub in the centre. If this seal goes bad, it can be very difficult to replace.
Sometimes the water-inlet valve develops a buildup of mineral deposits and rust. To check this, remove the water-inlet valve and visually inspect the surface.
There is a cool product that is designed to help prevent water damage from a leaky washer. It's called a Washer Floor Tray This tray catches water leaks and prevents floor damage from overflows. This product is a must for upstairs laundries
Sep 07, 2008 | Frigidaire ATF6000ES Front Load Washer
Water leaks out from underneth
We have a WDSR2080D GE washer and had the same exact problem. We replaced the water pressure switch ($30) to see if that was the cause. A malfunction in this switch would cause the leaking from the bottom because there would be no way for the washer to "know" that the tub was filled to the appropriate level--causing the tub to overflow. Then we found out that the water pressure switch was not the cause and found that the water pump switch was the problem. A malfunction with this switch would cause water to continue to fill the tub without stopping--which would cause an overflow. Think of it as turning on a faucet without the ability to turn it off. Happily, we are now with a working and non-flooding washer at only a minimal expense. Note that the schematics for your washer are not in the manual. They are inside the control panel, which means you have to take the front of the washer off as well as the control panel in order to see what's really going on. My guess is that GE would rather consumers not try to fix their own appliances so they put instructions and helpful hints INSIDE the appliance.
Jul 23, 2008 | GE WDSR2080D Top Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
103 people viewed this question
Dan Webster
Dan Webster
Sal De
