Question about Casio Exilim EX-Z750 Digital Camera
Photo remains on screen, will not disappear without pressing "Menu" button
There's probably a simple solution to this problem but it's driving me crazy. Whenever I take a photo the shot remains on the screen until I press the "Menu" button. All settings appear to be set to normal; I've even turned the "Review" function completely off but it hasn't helped. It's as if the review function freezes the photo on the screen and won't disappear until that button is pressed. It's incredibly annoying and I'm at my wits end - any help someone could provide would be greatly appreciated.
    Genius:
  • 2,985 Answers
Is there a Reset option available Read the manual If this is not remedied by your action then get onto Casio Technical Support. If this is a young camera it may be replace able by Casio or they may advise you to return it to the seller. If it is an older camera - then it will be new camera time if you find the fault is not livable with
Posted on Jun 19, 2007
Acer al707 menu box keeps popping up
Make sure there is no button is stuck and if so then there is a card that to be repaired or replaced.
Regards
Mar 05, 2015 | Acer AL707 17" LCD Monitor
Screen refresh problem
Sometimes it is as simple as separating the wires behind the computer, so they are not touching. With the interference gone, all is fine.
Apr 06, 2014 | Computers & Internet
OSD Locks Automatically
Power off your computer and then remove the monitor cable from the port on the back side of the computer case.
Reattach the cable and make sure the pins are correctly screwed in. Power the computer back on and check to see if the OSD lockout message is still being displayed.
Check the manual that came with your computer or monitor and locate the troubleshooting section if you are still receiving the OSD lockout message.
Find the OSD lockout heading and read the method that your particular model uses to remove the lockout.
Attempt generic lockout removal procedures if you no longer have the manual that came with your monitor.
Press and hold the "Menu" button located at the bottom of your monitor for 15 seconds and wait to see if the OSD lockout message disappears.
Press the "Menu" button again if the lockout message remains on the screen.
Use the arrow buttons to navigate through the main menu options.
Highlight the "Settings" or "OSD Menu" option and then hit the Menu key again to access the new list of settings.
Scroll down to the "OSD Lock" heading. Use the arrow keys to change the setting to "No." Hit the Menu key again to return to the main menu. Scroll to the "Exit" setting and then hit the Menu key a final time to exit the menu setting and remove the OSD lockout.
hope this helps
Jun 07, 2012 | HP Computers & Internet
Live TV onscreen menu wont go away
Thanks for the pic. As long as the image is paused, your menu will remain up. Your set was designed that way.
May 18, 2012 | Televison & Video
Osd main controls locked
*NOTE* This answer was actually found on another source.
The easiest solution to try is to reset the on screen display in the menu. Hold down the Menu button (it is probably marked Ok) for at least a minute. A menu list will appear on your monitor screen. Using the adjust button, press the arrows to enter the menu. Scroll down to the Reset section. On the right side of your screen, you will see an alternating Yes/No choice. When the Yes message flashes, press the Ok button. The menu should be reset and the flashing OSD control message should disappear.
If resetting the OSD doesn't work, then you probably have a physical problem with your Menu button. Sometimes, particularly on older machines, the connections to the circuit board are dirty or failing. Because you have to actually get into the monitor itself, you will probably void any remaining warranty by attempting this fix. If your monitor is still under warranty, contact the manufacturer to see if there is a local repair shop that can help you.
If you want to tackle this issue yourself, grab a screwdriver and take the plunge. Remove the casing on the monitor itself and locate the contact switch for the menu button on the circuit board. Sometimes, just working it with your fingers or a screwdriver is enough to unstick it - you can try to clean off any dust or grime that has accumulated around it to see if that is the cause.
Nov 27, 2010 | Philips 200W6 Monitor
The main menu appears and disappears without any input. And also a picture of a lock also appears and disappears without any inputs. The picture of the lock is either locked or unlocked
It seems that the problem is the monitor is detecting that the menu button is continually being pressed or the switch is shorted. Try pressing the menu button a few times to see if you can make this stop. Otherwise, the monitor needs to be repaired. Hope this helps.
Jul 03, 2010 | Dell E172FP 17" LCD Flat Panel Monitor
Stupid padlock/main menu keeps opening and closing DELLe152fp
That is the OSD (On Screen Display) system built-in to your computer monitor. Check that when you hit the ON/OFF button on your monitor, that you do *NOT* hit the 'OSD ON/OFF' button.
Most of the time, the OSD will disappear after 10 seconds of "non-use".
Dec 11, 2009 | Dell E152FP 15" Flat Panel LCD Monitor
Blue menu screen stays on
Hi! the blue menu screen can be turned off by pressing the same button that caused it to appear. In most cases pressing the "Menu" button on the remote or TV-control will make the blue menu screen disappear..
I hope this helps!
Mar 10, 2009 | Zenith C27A24T 27" TV
SMALL ICON APPEARS ON THE SCREEN (TOP L/HAND CORNER)
Hi there
Have you tried pressing the Menu button when this happens ?
Dec 12, 2007 | Office Equipment & Supplies
Black box on screen
go into menu find
cc settings and
change setting to off
(make note of the one thats
causing the problem)
Dec 02, 2007 | Sansui DTV2760 27" TV
Casio Exilim EX-Z750 Digital Camera Logo
172 people viewed this question
Top Casio Cameras Experts
atollminsk
Level 1 Expert
Steven Wander
Steven Wander
Damen Wong
Damen Wong
Are you a Casio Camera Expert? Answer questions, earn points and help others
