Question about Yamaha RX-V463 Receiver
Connecting a Technics SL-BD20D turntable to a Yamaha RX-V463 Rece
I just recently "upgraded" to a Yamaha RX-V463 receiver, and went to connect my Technics SL-BD20D turntable to it, but there isn't a 75 ohm connector on the back, as far as I can tell. I plan on connecting the RCA terminals to an AUX input in the back. Obviously I haven't yet, but I'm curious to know what the lacking 75 ohm connection will do. I need to record the aging LP's to CD.
After further research, I learned that I need to plug the turntable into a preamp before plugging it into my newer receiver. As with cassettes, record players are fading away. I ordered a preamp, but won't be able to experience success until it arrives.
Posted on Jan 17, 2009
I recently purchased an onkyo tx-nr626 receiver with phono input. When playing albums , I don't get full sound. Sound is clear but not full and loud.
Different cartridges put out various levels based upon their technology - make sure you are using the proper input for their output. A line level input 1V P-P won't work on most phono cartridges and will require a preamp to boost it to the higher level.
Dec 23, 2013 | Technics SL-BD20D Turntable
I recently purchased an onkyo tx-nr626 receiver with phono input. When connected I don't get full sound.
I have a Technics SL-BD20D turntable and want to connect it to a Technics SA-EH50 amp. Can this be done. Please tell how
Hi, you need a preamp to boost the line level if no dedicated phono input is on amp. Cheers John. Styluscity
Dec 28, 2011 | Technics Audio Players & Recorders
I dont have the orginal ground wire for my Technics SL-BD20D turntable someone told me i could use rca cables to ground it, i have a pre amp cause my main amp didnt have phono jacks on the back of it.
You don't need the original ground wire for Technics SL-BD20D turntable,
any plain cable can be used for this purpose...
you should connect turntable to your pre amp,should be a "phone" input at the back...
here are some suggestions for grounding....
  • Plug in a surge protector to the outlet, and then plug all the components into that surge protector
  • Connect a ground plug to the surge protector and then plug the ground plug into the main outlet. A ground plug is available at any hardware store, and turns a three prong connection into a two prong. Ground plugs help eliminate 60 cycle hum.
  • Connect the ground wire from your turntable to the ground wire connection on the receiver. If this doesn't work, looking on the back there should be a grounding point,
    Unplug your receiver.. Split a wire and attach one of the splits to the receiver where you will see the text, "ground" or something similar. Attach the other end to something metal such as a pipe that goes into the ground. Secure with electrical tape. Plug in.
    connect the ground wire to a screw on the electrical outlet.
    Take care and please Remember to rate/vote and give me 4 Thumbs Up
    for Helping out the Community :)
    Hope this helps!
    Jun 22, 2011 | Technics SL-BD20D Turntable
    Connecting a PS2
    the rxv463 will not upconvert any video signals. its what they call a pass thru video switch. chances are you are using a red, white. yellow (composite) connection. you will then need to pass this yellow thru the receiver to the yellow output of the receiver and into the yellow input on the tv. the same rule would apply to the component inputs and outputs as well as the hdmis
    Dec 07, 2009 | Yamaha RX-V463 Receiver
    Turntable output level too low and plain compared to CD, etc.
    Get an external pre-amp. They range in price from 25-100 and more, depending on the capabilities. All over Ebay, and electronics sites. That will fix your problem. Hope this helps
    Jul 06, 2009 | Technics SL-BD20D Turntable
    Buzz coming from speakers on phono input
    is the wire loose on either end? sometimes the electrical plugs can cause noise due to resistance, so trying different outlets might help too
    Jun 21, 2009 | Technics SL-BD20D Turntable
    Yamaha rx v663 receiver, turntable input
    What you will need is a phono pre-amp, then you can run into the receiver with a line level input to an empty audio input on the receiver, you can try Radio Shack to obtain one.
    Feb 10, 2009 | Yamaha RX-V463 Receiver
    Yamaha RX-V463 Receiver Logo
    338 people viewed this question
    Top Yamaha Audio Players & Recorders Experts
     Grubhead
    Grubhead
    Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
