Question about Brother IntelliFAX 2800 Laser Fax
Black Smudge of ink along top edge paper Brother Intelifax 2800
I changed the ink cartridge and now I get a black smudge of ink along the top of the paper using our Brother intelifax 2800.
I tried a new cartridge, same thing.
I put back the old cartridge, same thing.
No smudge before changing cartridge.
    Champion:
  • 320 Answers
Try cleaning the grid on the drum unit otherwise there could be some thing on the fuser preasure roller.
Posted on Jan 16, 2009
Gray smudge on edge of paper
If you get only black smudge even when you're printing in color your problem is most likely the black cartridge. If it smudge in colors look at your transfer belt, open the front door, the big belt that hangs on the door.
Dec 02, 2010 | HP Color LaserJet 2600n Printer
Printing has smudge on edge
If it is right along the edge then the drum (well the cleaning blade of the drum) is faulty. In a unit like that I suspect it is all part of a toner cartridge. Try replacing that and I think you will be good.
Jan 01, 2010 | Epson AcuLaser C900 Printer
4 - black ink smudges (1/32" wide x 1/16" high) in right margin
Very nice trouble shooting. The image defect you describe point to the OPC or drum unit this is essentially the toner cart. In your case black. Measureing the distance between repetitive defects is a sure way of diagnosing problems such as yours. Again nice work.
Google repetitive defect ruler for your model to help in the future.
Hope this helps
Apr 07, 2009 | HP Color LaserJet 2600n Printer
1 inch ink smudge down right side of paper
try going on ur computer that the printer is contected to and have the printer align itself
Mar 17, 2009 | HP LaserJet 1020 Printer
After paper jam, prints total smudge on Intellifax 2800...please
This is the test to determine toner/drum or fuser issue.
Print a test page
When you hear the paper feed into the machine open the top to stop the machine
Remove the toner/drum cart.
You should be able to see the page with printing on it. (This is before the page hits the fuser)
If you can see the smudge or marks on the page the problem is most likely the cartridge but NOT the fuser.
If the page is clean the problem is most likely the fuser.
Mar 13, 2009 | Brother IntelliFAX 2800 Laser Fax
Black smudge on side of paper when printing quanities
Hey, Pleas check Black imagine unit,if needed change it.
Jan 07, 2009 | Konica Minolta Magicolor 5450 Printer
Black smudge marks along left side edge of paper.
Its probably a defective toner. If the film on the toner drum is scratched it can cause toner to stick to the drum everytime it spins causing the constant marks.
Jul 08, 2008 | HP LaserJet 1320 Printer
BLACK SMUDGING
Hmm... This sounds like it is a toner problem. If your roller is getting too much toner then it just globs it onto the paper even though the drum is not asking for it. Are you using a new toner cartridge or a re-filled one? Is it from Brother or a 3rd party? I suggest you remove the toner cartridge and check inside the printer. Clean any spilled toner. Check the toner cartridge for leaks .. give it a good shake and see if it is leaking. If you have another toner cartridge, you can replace it to test. You may need to pint a few pages to see a change. Another test could be to print a few (2-5) "BLANK" pages. The printer should not be depositing any toner. If no smudge or the smudge stays the same, then the toner cartridge is the likely problem. If the smudge is there, but gets smaller, then clean your printer.
Jan 10, 2008 | Brother HL 2700CN Laser Printer
Ink smudges
Pease check:
thet consumables is originals,
drum cartridge is not damaged
transfer belt is clean and not damaged.
you may have problem there, but if not you can try update firmware, maybe its a firmware problem.
first check consumables and if possible try changing them
Oct 23, 2007 | Konica Minolta magicolor 2430 DL Laser...
Ink smudge on corner of brochure paper
Ink getting onto the paper when it should not is usually a sign the waste ink tank need cleaning out. Go to www, fixyourownprinter,com for a deeper insight. Also the Canons own Tech Support team
May 31, 2007 | Canon PIXMA MP780 All-In-One InkJet...
Brother IntelliFAX 2800 Laser Fax Logo
377 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
