Question about Konica Minolta bizhub 161f All-In-One Laser Printer
Top ADF will not recognize paper in the feed tray.
I have a Konica Minolta Bizhub Di1610, the upper Auto Document Feeder will not recognize when paper is set for copy or faxing.
I have checked the paper sensors, the cover open sensor works, the paper missfeed sensor works. could it be the PCB for the Doc. feeder, or is it further down in the system? If it is the control board, where can I source one?
  • 210 Answers
Try to replace the 'paper is present' sensor with the 'cover open' one to see if now it is detecting the paper. Also, check the actuator that enter in that sensor.
Posted on Aug 23, 2009
Adf konica minolta bizhub 350. theres adf working good but no printout. a few minute machine says jam paper at adf. actualy original it was throw out.. help me please...
Konica Questions answered here ' FixYourOwnPrinter
Aug 22, 2008 - Am working on a Magicolor 2300 DL that sometimes fails to lift the paper tray ... good afternoon I have a konica minolta bizhub c550 when I open the ... I'm no printer tech, but in most other lasers (HPs, etc) the paper tray lifts, .... It seemsthere is a "waste toner sensor" which only lets the printer print out a few ...
Konica Minolta paper jam adf scanner Questions & Answers ... > Forum > Tags > paper jam adf scanner
Question about bizhub 350 All-In-One Laser Printer ... Konica Minolta bizhub 250 jammed but no paper ... Good luck. ... ...paper is there if the switch is working the adfboard is fualty or the cable between the machine and adf broke from all the ...
Konica Minolta bizhub document feeder not working ...
Jan 23, 2016 | Konica Minolta Office Equipment & Supplies
Hi, Bizhub c450: i have a problem on scanning over the rear tray if i put paper inside message will appears close section properly but there is no other error code appearing on the screen.
When you say the rear tray what do you mean, ON the document feeder tray or raising the document feeder up placing the document on the big glass. Never heard of a rear tray?????
Feb 04, 2015 | Konica Minolta bizhub C450P Laser Printer
Konica minolta c350 error code c204
C 204 Tray 2 feeder up/down abnormality.Check the M9 paper feed tray 2 lift up motor connector for proper connection,the PS15 paper feed tray 2 upper limit sensor actuator,the motor coupling.
Jul 27, 2014 | Konica Minolta bizhub Office Equipment &...
How do I fix trouble code c- 0204 on my bizhub C554e Photocopier machine?
Tray 2 feeder up/down abnormality.The paper feed tray 2 upper limit sensor is not blocked even after the lapse of a given period of time after the lifting motion has been started.Check the sensor and the sensor actuatos.
Jul 14, 2014 | Konica Minolta bizhub 250 All-In-One Laser...
Clean the feeder paper feed,separator roller with cloth and alcohol.
Feb 01, 2013 | Konica Minolta bizhub Office Equipment &...
ADF of Minolta C450 is not working
the sensor switch were you put the paper in detects the paper is there if the switch is working the adf board is fualty or the cable between the machine and adf broke from all the open and closeing after that the board in the copier were the cable plug in may be faulty swop the around with annother machine if avalible.
Mar 14, 2012 | Konica Minolta bizhub C450P Laser Printer
When trying to fax I get an error "open adf cover"...
You should be able to. It sounds like you've got a paper jam in the document feeder. Chances are there was a jam and part of the document (a small peice perhaps) is still lodged in the document feeder unit.
Aug 31, 2009 | Konica Minolta PagePro 1390MF All-In-One...
Please check the sensors and actuators ,open & close front door to reset nisfeed.Clarification Top feed = Automatic Document Feeder?If YES,please verify misfeed paper beetween coverplaten and feedbelt(Yellow).Is necessary disassembly the ADF.Good luck.You will find a little paper.
Jul 31, 2009 | Konica Minolta bizhub 250 All-In-One Laser...
Konica Minolta Bizhub 920
You need to set machine for extra cassette.
Nov 23, 2008 | Konica Minolta Di1610 Copier
Bizhub C650 (Minolta printer, copier)
setup for adf if is new machine u have the setup **** for adf
the setup **** (A4 page) with black border
Oct 13, 2008 | Konica Minolta bizhub 350 All-In-One Laser...
Konica Minolta bizhub 161f All-In-One Laser Printer Logo
524 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
