Question about HP 1040 Plain Paper Inkjet Fax
What does mode G3 send error mean?
What does this mean "G3 send error mode"?
    Genius:
  • 2,120 Answers
The other fax machine is not G3, which is the latest configuration. Maybe a very old fax machine.
Posted on Jan 16, 2009
  • johnsonemman
    johnsonemman Jun 28, 2012
    G3 error comes up only on VOIP connection, Most of the printers or fax machines support analog connection.
  • Millie Andry
    Millie Andry May 12, 2014
    What is a VOIP connection?
I would like to know what Error300 means on a Canon Super G3.
there is no error 300 on this model
g3 is a fax standard---all current fax machines on the market are G3 not a machine model
Jan 12, 2015 | Canon imageCLASS D-480 - 23 PPM...
How to disable ECM and Reduce Baud rate for Canon MF4270 G3 Fax ?
Your approach is correct however it doesn't look like the MF4270 provides for these settings. One might expect to be able to select G3 or ECM or set a lower TX speed.
I located the settings for different Canon Fax machines here:
VoIP Fax Settings
Jul 25, 2014 | Canon imageCLASS MF4270 All-In-One Laser...
How to send fax? activity report shows MODE:tx g3 and resust shows:ng00ff
The result NG 00FF means that the machine has tried to send a fax and gone through it's 3 redials and ended up failing to transmit. You do not say if you can receive faxes?
1. Make sure the telephone line you are connected to will make an outgoing and an incoming call. try this with a good working telephone.
2. Make sure you are using the genuine canon telephone line lead.
3. Make sure the line lead is plugged into the LINE socket and NOT the TEL socket.
4. Press the HOOK button on the fax and you should hear the dial tone through the speaker.
If all the above works and is correct then the machiine has a problem but i doubt it as you are getting 00FF and if the machine was at fault you would get a different error.
I reckon the above should cure your problem.
Good luck.
Jul 09, 2011 | Canon imageCLASS MF4150 All-In-One Laser...
Muratec F-320 Super G3 we are getting a fax ready Please call Service message
Please Call Service means the machine "thinks" it has detected a fault.
To check do the following..
Press PROGRAM,*, 6
Then press PROGRAM to select Service Call mode, then press ENTER....the error message will be displayed in the display.
Most common error given machine age was "Heater Error".
If this is the case you will need a Serviceman to do repairs to the Fuser Unit.
Oct 25, 2010 | Muratec F320 Plain Paper LED Fax
We have a HP 1050 fax machine. Usually when we send something, it displays send ECM and the number of pages. Occasionally it displays send G3 and the number of pages. I can't find anywhere in the user...
this is just the transition speed and line condition and you dont have to worry about it , the machine will give you an error code if the faxes dont go through alturnativly contact the reciever of the fax to check that they have recieved it
G3 means poor line condition
Apr 09, 2010 | HP 1050 Plain Paper Inkjet Fax
On the transmission journal what does g3 stand for mean on the mode section?
G3 means you have the latest version of the UNIVERSAL FAX STANDARDS and is compatible with all other fax machines.
Sep 29, 2009 | Samsung SF-750 Plain Paper Laser Fax
Sending error
I try sending a fax then the paper goes through it makes a loud beep and the message says theres been an error try again this happens all the time no matter who I fax. then it prints out error confirmation stating Mode G3 send error
Jul 29, 2008 | HP 1040 Plain Paper Inkjet Fax
Samsung Multijet FX4200 Fax/Copy/Telephone
THERE IS COMMUNICATION ERROR , PLEASE CHECK THE PHONE LINE. HAPPY FAXNG OMNIPRESENT
Mar 30, 2007 | Samsung HP 4200 Laserjet Printer
HP 1040 Plain Paper Inkjet Fax Logo
3,638 people viewed this question
Ben Johnson
