Question about RIM BlackBerry Pearl 8100
Blackberry curve 8310 trackball wont go down
Im sitting in my school library and the trackball just stopped going down. is there a way i can:
A) FIX IT SOON.
or B) get to my Options to change the Sensitivity Settings without using the downward motion on the trackball because that wouldnt work.
Thanks so much!
Hi there
I had exactly the same problem. I spent a while trying to use a qtip to flush out the dirt but this didn't work.
I eventually sorted it by carefully lifting the cover (use a credit card to lift it up - slip it in the gap above the y key).
Then carefully hold the bb upside down and the trackball will fall out. Catch it in your hand.
Remove any obvious grit. I also used something out of a manicure set. I am not sure what it is called but it looks like a small tick remover. Anyway using one side I carefully slotted it into the small gap between the rubber ring and the trackball and lots of other bits of grit fell out.
Then once it was clean, I popped it back into the bb and refitted the cover - making sure to put the legs in the correct position.
It now works fine
Hope this helps
Phil
Posted on Mar 28, 2009
My trackball doesnt work so well on a blackberry 8310
Maybe you mean the blackberry trackball wont scroll in certain directions? Then you should read the tricks at  http://www.unique-stuff.co.cc/fixing_sticky_blackberry_trackball.html
Good luck
Mar 05, 2010 | AT&T Blackberry Curve 8300 Smartphone
How do i divert my blackberry 8310
To reset the device back to default settings, and remove all previous data:
1. Go to the main applications view.
2. Choose Options (it's the little crescent wrench icon) and select it.
3. Scroll down to Security Options and click the trackball.
4. Highlight General Settings and click the trackball.
5. Now just click the menu button and select Wipe Handheld.
6. Click Continue, and enter BlackBerry when prompted.
Jan 11, 2010 | RIM BlackBerry Curve 8310 Smartphone
Cell phone blackberry trackball stopped working!
Use a alcohol swab and gently rub it over the trackball. Rub it and roll the ball.. Eventually this cleaned the ball and it worked perfectly!!!!
Dec 17, 2009 | AT&T BlackBerry Curve 8310 Cell Phone -...
How to clean up trackball for curve, cause it won't scroll down....only to the left and right...thx
everyone has the same problem with blackberry trackball. i wonder why the rim installed such a hardware in their phone. it makes a lot of trouble.
to fix it simply use a straw, no need ro replace or disassemble the blackberry, read more from the source http://www.unique-stuff.co.cc/fixing_sticky_blackberry_trackball.html
Dec 07, 2009 | RIM BlackBerry Curve 8310 Smartphone
My trackball on the curve 8910 is not smooth when i direct it to the right? how do i fix this
Make small changes in the settings.
Go to options
Screen and keyboard
change the trackball sensitivity to 90 percent horizontally.
press Menu and click on save.
Nov 13, 2009 | RIM BlackBerry Curve 8310 Smartphone
I cannot click using my trackball (AT&T Blackberry Curve 8310).I can scroll up and down but when i go to click on any applications, a menu comes up just as if the menu button to the left of the...
Trackball doesn't work if you have not selected the sensitivity. To select the sensitivity, kindly follow the steps: 1. Select menu. 2. Select option. 3. Select screen/key board. 4. Scroll down to find horizontal and verticle 5. Select horizontal-100 and verticle-100.
Oct 19, 2009 | AT&T BlackBerry Curve 8310 Cell Phone -...
Want to remove contacts on a blackberry 8310 i have purchased how do i reset
To reset the device back to deafult settings, and remove all previous data:
Oct 14, 2009 | RIM BlackBerry Curve 8310 Smartphone
BB Curve 8310 keys and trackball not working
is there a way to navigate thru options with no trackball
May 30, 2009 | RIM BlackBerry Curve 8310 Smartphone
Cannot scroll up with my Blackberry Curve 8310 trackball
It is a very common problem. You just need a new trackball. Should be about $25. If you want to make it work temporary, then just removed it and clean the trackball and the phone part under it (on the phone itself) with 99% alcohol. It might work for a while again
May 13, 2009 | AT&T BlackBerry Curve 8310 Cell Phone -...
RIM BlackBerry  Pearl  8100 Logo
201 people viewed this question
Top RIM Computers & Internet Experts
Computer Repairing
Computer Repairing
Andrew Wright
David
Are you a RIM Computer and Internet Expert? Answer questions, earn points and help others
