Question about Pioneer XVDV830/SDV830 DVD AUDIO HTP System
DVD is dead
The dvd player in my unit has hasn't worked for about 2 1/2 years now. Before I get a new system, is there anything I can do to resurrect the dvd player. When you put in a dvd, it spins up for about 3-4 seconds, then the unit ejects the dvd. The unit says "Loading" while spinning up. That's all. Any help would be greatly appreciated.
    President:
  • 3,130 Answers
Wow , with the unit sitting for two years, you could have all sorts of problems now. Most likely back when the unit stopped working, the spindle motor was bad, as that was the problem on almost all of these types of CD players. Now though, if the power supply capacitors are not shot, the laser assembly could also be bad. My best advice on this unit? Can it and start out with new equipment. Good Luck
Posted on Jun 19, 2007
SOURCE:
I need warranty for portable dvd player from walmar
As far as I can tell this product hasn't been sold in years. If you bought it new and recently ask Walmart for warranty info. It would have had a 90 day or 1 year warranty when new.
Jul 04, 2012 | RCA DRC630N Portable DVD Player
DVD player loads then stops and says no disc, havent used it in about 4 years ,how do i get it to play dvd, tried to set up like it says but must be doing something wrong
Tries to play more than one DVD disc.Tries to play many DVD disc should be original DVD disc ok no DVD+R copying disc ok.If ur are still getting signal just saying loading signal awhile than say no disc show up, and u did playing it with many dvd original disc.Than the DVD player laser eye reader could be ditry.Tries websites like Amazon.com,Ebay.com to buy a DVD disc set that said like DVD players lasers eyes cleaners.Used it as directions said,if u still getting the same result mean ur DVD player laser eye reader it is dead,not worth repairing the DVD player if the DVD player laser eye reader it it dead,because the laser eye reader it is 90% important to the DVD player unit and the cost of it by replacing it will cost the same as a new DVD player unit.
Aug 29, 2011 | Polaroid 7'' Portable DVD Player
Hi I have a portable LG DP472B and it has just stopped working, disk will not load red charging light is on but the unit is dead, it has not been dropped or over use, maybe 15 times playing a...
Litium battery in this portable DVD player already in the unit like the last 2 years?Yes.The litium battery require replacement.Tries websites like Partstore.com,Ebay.com,Amazon.com to buy a new litium battery for the replacement.
May 16, 2011 | LG DP781 Portable DVD Player
My sony mhc-rv990d dvd does not play or open or even react to comands. it has worked for the last 8 years no problem till beginning of this year. how do i resolve this?
This problems could be anythings wrong in it unit circuitries.Tries the unit unplug,replug it back like about an hour later.For the unit to do a resetting back to the factory setting.The unit should be working again.If still have the same result,the unit have dead circuitries board problems.This unit just a basic DVD player only wright?Yes,unit not worth the price to repair it.The basic DVD player only cost like about $40 only brand new.
Apr 03, 2011 | Televison & Video
No power to Insignia dvd player.
Pop the top of the DVD player and check the fuse. It's located right next to the AC power plug on the inside. If the fuse is OK, replace the DVD player. Repairs cost more than a new unit. Sony has DVD players from $ 40. Any repair on any device would cost more than that. If your lucky, the unit just took a surge and blew the fuse. Hope this helps
Oct 14, 2009 | Audio Players & Recorders
Panasonic LA95 Portable DVD
any flashing red powerlight ?? (assuming theres any charge left)
if the powerlight flashes quickly then the units kaput ( bin it)
slow flashing means the microswitch may be stuck (the one that turns off the screen when you close the lid.
you may have to be sneaky at a dealer and ask to plug in to a new mains unit ( most new panasonics still use the same power supply voltage and ampage. if it works then run away quickly and go buy a universal power supply, if it doesnt , well your in the right place tobuy a new one ??
Mar 11, 2009 | Panasonic DVD-LA95 Portable DVD Player
MY DUAL IN-DASH DVD WON'T LOAD ANY DVD OR CD.
OK so be said the player will not load the CD...how in the world is he going 2 clean the lens if the player won't load anything? I'm just sayin...
Feb 03, 2009 | Dual XDVD8181 Car Video Player
Samsung DVD/VCR Recorder
Unit dead.
Local repair shop said it's un-econimical to repair.
Admitted they had no service manual.
Said they could 'have a look' but likely repair cost would be over $300. Charged me $50 for quote. Useless Gits.
My opinion & findings.
Power supply sensative to spikes.
I Suggest a power filter in-line with unit.
Disconnected all sub-boards from main.
Hiccuping PSU (5v wobbles between 2&3V).
Replace switchmode IC & feedback IC. No change.
Eventualy identified short-cct diode as listed below.
0402-001194 Diode is a Gen-purpose 200V 2A diode. I used a 1n4007 (1A), so I expect to have to replace it in future. It's "D1S35" located very close to right rear corner of main board, part of 15V and 12V rails. Next time I'll use a 'faster', higher rated diode.
I also had no clock progression. Time could be set but would not advance. Been like that for ages - I thought it was a user clock-setting error. Identified Dead 32.768 khz crystal (XT601).
Hired manual $10 +postage
Non-faulty parts + postage $40
1 diode $1
Satisfaction, plenty.
Jan 07, 2008 | Samsung DVD-VR320 DVD Recorder/VCR
How to connect other dvd or HDMI player into dav-sc5 for amblification
If your alternate DVD player has digital audio out you can make this connection via the 'optical digital in' port on the rear of the unit which corresponds to the Video 2 function. I have done this myself because the inbuilt DVD function in the Sony unit is dead (fixed once under warranty, problem recurred about a year later, same issue as other unsolved posts on this board, DVD function hangs, system won't switch off, etc. common problem with this unit, crap product).
Oct 18, 2007 | Sony DAV-SC5 System
Completely dead
Hi This is my opinion only, but I have worked on many many DVD players, and if you don't need anything fancy, then go for the $30.00 unit. Actually, I would look for something in the $50.00 range, as the $30.00 units are very cheaply made. I have often worked on a $100.00 unit, followed by a $50.00 unit, which had the exact same laser and mechanism inside, the only difference being the brand name stamped on the front. But.... You could purchase three $30.00 units, for $100.00 and if you used them one at a time until the last one died, I dare say they would very likely outlast the $100.00 unit by far. I've probably just confused you now, so I'll just end by saying that on a regular t.v., the picture will look just as good using either option, and you can have good luck or bad luck with any piece of electronics expensive or not. Good Luck!
Aug 12, 2006 | Toshiba SD-3980 DVD Player
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
Morne Olivier
Steve Sweetleaf
Steve Sweetleaf
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
