On the konica 2223 when printing it leaves a dark thick line down the center of the paper.
    Problem Solver:
  • 5 Answers
Konica 2223 copiers are analog meaning the image that comes out on copies is a direct reflection off of the copy. Dirty mirrors in the optic section can cause a dark band, but it is more of a shading effect. Drum assembly's can be removed.The image drum has a cleaning section that uses a urethane blade to clean excess toner off of the drum after the copy passes through.It is simply called a "Cleaning Blade" these blades can be ordered through most online copier part stores. Last but not least is the "Upper Fuser Roller". this is the hot roller the paper passes through to "set" the toner to the paper. These are coated with teflon to prevent toner from sticking to them. They have "seperator claws" that keep the paper from adhereing to the roller, and they sometimes gouge the teflon. this exposes bare metal, and the toner can come off of the copies and stick to the roller.
Posted on Jan 19, 2009
I see where to change color density settings in thick paper. Can I do this for plain paper? (Normal printing is too dark.)
The only changes you can make are in the printer preferences menu, so if you have lightened it up there you have made the only adjustment allowed or provided for.
Jan 20, 2012 | Konica Minolta Bizhub c203 Copier
My HP laserjet 3015 puts thick dark line down the copy
Put paper in the manual feed tray(tray 1). Print something. When the paper gets about 1/2 way into the printer, open the top cover. Pull out the toner. Look down at the paper in the printer. Do you see a thick dark line? Replace the toner. No thick dark line, check the fuser for damage.
Jul 21, 2011 | HP LaserJet 3015 All-In-One Printer
Paper will stuck at the heater
HI i think you have a bad upper fuser roller thats why the paper rolled up with it or maybe there are finge clow are not good first of all just remove paper and just clean the upper fuser roller with fuser oil if yours fuser roller and finger clow are not damaged it will work fine enjoy
thanks
May 14, 2010 | Konica Minolta DiALTA Di200 Copier
How do i set up a konica 2223 copier to print using it as a network printer
the 2223 does not have that feature if you want a copier that is comparable to the same speed and features you would have to buy the konica minolta bizhub 222 new model or there are a lot of low mileage used bizhub 200 machines coming off lease for sale
Sep 28, 2009 | Konica Minolta Office Equipment & Supplies
PANASONIC FAX MACHINE PRINTING BLACK THICK LINE
Open the front of the fax machine. Then pull down the the tray that has the down arrow imprinted on it. Locate the glass strip towards the back, just behind the center roller. Use a cloth and rubbing alcohol to clean the glass and that should remove the black line.
Apr 22, 2009 | Panasonic KX-FL511 Plain Paper Laser Fax
Konica Minolta BizHub C451 printing red lines down documents
your imaging unit is damaged. call minolta guys to have a look it at and change it if neccessary
Mar 30, 2009 | Konica Minolta bizhub C450P Laser Printer
Frequent paper jams with my Konica 2223 photocopier
I wish I could help you, You need to call for service for your copier. An authorized dealer or Konica minolta branch service in your area. You might need a fuser unit that the upper separating claws disloge or broken, exit paper detect actuator is broken or disloged, or you need a new developer.
Feb 05, 2009 | Konica Minolta DiALTA Di200 Copier
I have a Konica 2223 copier - wont print on edges
check all edge settings .f28 is code for charger corona just clean corona assembly with cerosene oil and change corona wire with new one.
Dec 16, 2008 | Office Equipment & Supplies
Konica Minolta Magicolor 2430DL--black line on right side of paper
Sry but you have to change drum cartridge, the line is caused form drums cleaning system, and it cant be repaired.
Oct 18, 2007 | Konica Minolta magicolor 2430 DL Laser...
Can't print onto thick card
Have you tried specifying the paper type and weight INSTEAD of the tray. Set the tray properties first, then print. If you leave it on auto tray it will use the tray that matches your paper type and weight.
Jan 09, 2007 | Konica Minolta bizhub C351 All-In-One...
154 people viewed this question
k24674
jasbo
jasbo
