Question about HP D8597A Keyboard
Some keys on my new laptop stop working
The 1,Q,A,Z and caps lock keys on my brand new (less than 1 month old) G60-100EM HP laptop sometimes stop working. Operation can often be restored by holding down another key, i.e. "fn", and pressing one of the non functioning ones. Often these keys operate normally for quite a while and then for no obvious reason the problem occurs again. Any advice would much appreciated. Charlie
  • Anonymous Feb 12, 2009
    Same here... sometimes space, end x and a few other keys are locked. they start working in 30-45 seconds. Please help... is this a software error?
I need the driver of v220
Posted on Jan 17, 2009
  • emailo Jan 17, 2009
    I need driver of logitech v220 version 4.60.122
My laptop screen is black and caps lock and scroll key are flashing
That is a security configuration on HP Laptops, depending on the way they blink is the problem your machine has.
Here is the web page where this info is posted, in case you need more info, hope this helps you to determain.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01443366&lc=en&dlc=en&cc=uk&lang=en&rule=26781&product=3816592
This document pertains to HP Notebook PCs with the HP Unified Extensible Firmware Interface (UEFI) beginning in late-2008. On startup, you may see a blank screen. If the diagnostic utilities detect a specific problem with hardware components, the fan turns on, but the screen remains blank. To help identify the cause of the problem, various LED lights on the keyboard blink a series of codes. The diagnostic utilities use the LEDs near the Num Lock or Caps Lock keys to blink a series of error codes. At the end of the series the blinking stops. The pattern of blinks will occur any time you attempt to start the computer until the error is resolved. Battery power LED blinks The Battery power LED indicates the condition of the power supply. When starting the computer, or when the computer is in operation, use the chart to identify the power condition. Battery Power LED Component Tested Error Condition Battery power LED off, and Caps Lock/Num Lock off Battery or AC Adapter AC adapter not connected or failure
Battery low charge or failure Battery power LED blinking Battery Insufficient charge on the battery When new computer is used for first time, the white LED light for the AC power connector blinks. Battery is still in "Shipping Mode", the light continues to blink even when AC power is connected.
To resolve, turn off notebook, connect AC power and allow battery to charge for at least 30 minutes, then start computer. LEDs near Caps Lock and Number Lock keys blink when starting notebook The LED lights near the Caps Lock and Num Lock keys will blink if an error is detected during the start up process. The LEDs will blink a number of times in a sequence and then stop. The number of blinks in the sequence indicates what component caused an error when it was being tested during start up. If the LEDs stop blinking and the computer does not start, you can press the power button again to repeat the tests. Count the number of blinks, and use the chart to identify the error condition. Knowing the number of blinks is helpful when you contact an HP support agent for technical help. Caps Lock/Num Lock LED Component Tested Error Condition LEDs blink 1 time CPU CPU not functional LEDs blink 2 times BIOS BIOS corruption failure LEDs blink 3 times Memory Module error not functional LEDs blink 4 times Graphics Graphics controller not functional LEDs blink 5 times System board General system board failure LEDs blink 6 times BIOS BIOS authentication failure
Dec 01, 2011 | HP Computers & Internet
My HP Pavilion D6 laptop's keyboard is not working. When the caps lock is on, the letters are getting displayed in combination of caps and small. Also the numbers are not getting displayed, instead the...
If the laptop is brand new then I suggest you return it to the supplier to get it repaired or swapped out under warranty.If you try to repair it you most likely void your warranty.
Apr 15, 2011 | Computers & Internet
Hi guys we have made the mistake in buying 3 laptops brand new from you guys first one replaced under warranty less than a year old a lot of money to replace the software 2 one fixed under warranty 8...
So, what is your question?
There is nobody on FIXYA that "officially" speaks for either HP or their COMPAQ subsidiary.
Buy the "three-year-extended-warranty" from HP before the "standard" warranty expires.
Review your "backup" strategy, to eliminate/minimize any "data" loss that you might experience when each laptop fails.
Mar 15, 2011 | Compaq Computers & Internet
Wot key is the enter key
Look old chap the enter key is(if you have a qwerty keyboard)usually to the right with an arrow on it sometimes the largest button the keyboard. on the opposite side to "Caps lock!
Oct 21, 2010 | HP Pavilion Ze4900 Notebook
USB mouse problems with Windows 7 Laptops
You MUST disable digital driver signing to install ANY driver.software on any 64 bit system. you MUST press F8 at boot up to install the driver, & then EVERY time you boot up you MUST press F8 to disable driver signing to USE it too, every time....
Mar 06, 2010 | Dell Inspiron 1545 Notebook
My hp mini laptop fan grinds when the fan kicks on, I can push down on the caps lock key and stop it, but any movement of the lap top it starts back..
when u push down on the caps lock key you are stopping the fan because it is under the caps lock key..thats why when you move the laptop it starts back up..my sugjestion would be to replce the fan
Feb 11, 2010 | HP Mini 1000 Netbook
MY KEYBOARD DOES NOT WORK WELL. FOR INSTANCE, I CAN NOT TYPE M WIthout holding the right side shift.
brand new Compaq 620 the keys stopped working. FIrst with 6,7, "_", then some other character keys also stopped working. Please let me know how to fix it.
Jun 20, 2009 | Computers & Internet
Keyboard problem on brandnew laptop
Several reasons: 1. because of spilled liquid on this keyboard area, 2. because of heavy and/or hard thing fell on this keyboard area
3. because the laptop fell from the high height on the left side.
4. because you bought it already damaged
5. hardly probably software malfunction
For the first case you might need to disassemble the keyboard and clean all the metallic surfaces of these buttons. It's not so easy to disassemble it in right way. Second-third case - you'll need to purchase a new keyboard for it and replace with the damaged. Fourth case - claim your seller to change your laptop with the new one or get your money back. Good luck
Jan 19, 2009 | HP D8597A Keyboard
Keys coming off my HP Pavilion 5000 laptop
I'm afraid that if the keys "keep coming off" then the very small bits of plastic that keep them down have permanently broken (very common) and that you must replace the keyboard. Page 5-28 of this document from HP explains how to replace the keyboard of that model.
Jan 17, 2009 | HP Pavilion dv1000 Notebook
CAPS LOCK PROBLEM!!! URGENT HELP NEEDED!!!!
On some keyboards, there's a hidden 'feature' where if you hit CAPS LOCK and Shift at the same time, everything works backwards, until you hit that combo again.
Try this and let me know if it pertains to you...
Dec 29, 2007 | Computers & Internet
HP D8597A Keyboard Logo
600 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
