Make sure both hot and cold water supplies are turned on. Select a cold wash cycle and start the wash cycle, do you get cold water? Now select a hot wash cycle and start the wash cycle, do you get hot water? If you only get cold water replace the hot water fill valve. If you only get hot water replace the cold water fill valve. If you get neither replace both fill valves.
Please post the model number for your washer. It sounds like your hot water valve has failed and is not closing. Unplug your washer's power cord and turn the hot water spigot that comes out of the wall on. If you still get water filling your washing machine, it's definitely the washer's valve and you will need to install a new set (hot and cold valves are both part of the same assembly).
If it works O.K. in a different wash cycle, then the timer could well be the issue. Using that last cycle you described, will it perform a complete normal cycle ???
Why has nobody mentioned the fact that if you “draw off” hot water
using a tap beside the washing machine you can get “instant” hot water
to your hot-fill. I have been doing this for years – now that all my
hot water is heated by a crabon-neutral energy source (either wood or
solar) I feel it is even more energy efficient.
As for water consumption, my house has a secondary return pipe on the
hot water circuit with a temperature sensor fitted to the pump so that
it only switches on when you turn a hot water tap on – you than turn
the tap off, wait 5-10 minutes while the water circulates, then turn it
on again, by which time the hot water only has ashort distance to
travel and you don’t waster much down the drain.
However, I have been interested to read about the pros of cold fill
only, especially the arguments about such a small volume of water being
used anyway and the possibly improved wash performance? Also, I was
dismayed to read that washing machines with hot and cold fill don’t use
the hot wate very efficiently.
So would I be better off going for a hot and cold machine while they’re
still available or going for a high-efficiency cold fill only machine?
I am still minded to get an LG with hot and cold fill… comments please?
This is often, if not all the time, a faulty fill valve, the fill
valve has mechanically stuck open and is not fully shutting off when
not the washer is not in use. This normally will become worse and could
flood over the top of the washer = big mess .... replace the fill
valve. The fill valve is the part the hot and cold water hoses are attached to.
