My hot water pipes were froze this morning. Michigan! I have cold(almost froze) There is not any water coming out in kitchen from hot side. I have cold though in every room. There is water coming out a little bit from hot side in both bathrooms, its all cold water though. Lit the pilot light on hot water heater, has stayed lit since. The burner will not light though?
    President:
  • 267 Answers
No easy fix . your water heater should be fine most likely its up to temp ,thats why its not lighting its main flame . the frozen pipe is another story you need to get the heat up in the house open any cuppord doors that have pipes in them like under a sink ( to let heat from the room get it there ) leave a faucet on hot and wait . at some point you will unfreeze . but you migh end up with a broken pipe so keep your eye out for a water leak . good luck
Posted on Jan 16, 2009
When handle in shower is turned to hot cold water comes out when turned to cold hot water comes out how to fix
Who ever hooked the pipes up to the tap they put the cold pipe on the hot side of tap. Same the other side. You need to change the pipes to opposite side of tap.
Jan 25, 2018 | Home
No water on the hot side of line. Have rinnai gas tankless water heater. 22 degrees last night but had pipes wrapped. Have cold water pressure but not pressure on hot side. Tried to thaw pipes
You will need to have heat in the room to thaw pipes . Cold will come in from flue pipe and freeze pipes . its a slow thaw so pipes don't split .
Jan 18, 2018 | Rinnai Water Heaters
Cold water coming through hot tap in kitchen but hot everywhere else
have you got hot water coming through the cold tap?
not possible unless the pipes are not connected corectly
Jul 05, 2017 | Water Water Heaters
No COLD water flow to washing machine
it could be frozren depends the temp. of the room u have it in. if thats the case get ur blow dryer out put heat to it. my boyfriend and i have had to do this to our pipes 3xs already.my cold water in the kitchen did to, i just turned it on and waited for it to unthaw. i hope this will help.
Feb 08, 2014 | Kenmore Washing Machines
Hot water in kitchen only froze
good idea to let the cold water to run a bit to stop freezing up . Pity that you didn't do the same with the hot water. There is only hot water in the tank but the water in the hot water pipes will freeze as the heat goes out of the pipes. (Always to have to wait for the hot water to come through when you use the shower or bath.) The water will freeze up right back to the hot water tank
Jan 29, 2014 | Cars & Trucks
Our hot water in the kitchen froze due to -20 degree weather. When it came back on , we had very little pressure for the hot, but cold was normal. It has been this way for about 3 weeks now. Any...
Hello. When the pipe froze it may have dislodged a piece of scale or rust from inside the pipe. When the water flowed again the particle moved up to the small hole at the valve and caused a partial block. You'll have to shut off the water supply and disconnect the supply line on the hot side. You may be able to open the faucet and blow back through to try to remove the blockage. If this don't work remove the faucet handle and pull the cartdrige out to clean it. Remember to close the water supply.
builderdale
Jan 22, 2010 | Moen 7310 Legend Single-Handle Kitchen...
No stop tap. cold water coming through cold taps in caravan but no hot water the carver cascade water heater is getting the water hot but it just wont come through the taps in the shower room or kitchen in...
your pipes are clogged, what if you were to not turn on the cold and turn on the hot does any water come out at all, with just the hot side turned on,, if not there could be a valve that has been turned off, or the pipes are clogged
Jun 17, 2009 | Reliance & 40 Gal Mobile Home Water Heater...
I have two hot water tanks in an 11 unit building One side of the building has water coming out of the hot water spigots and the other side of the building has no water coming out of the hot spigots. There...
Duissamble the faucet after turning off the shutoff vavev and look for an obstruction. The only shutoff if the tempature gets too high is the pressure/tempature pop off valve which would redrirect the discharge down another path. Go to the waterheater and see if it is coming out from another open pipe from the heater.
Jan 17, 2009 | Water Heaters
Washer won't drain
Yes Get a space heater and run it by the frozen pipe. Turn off all electricity to avoid shock and it should break free by the morning. Run it at a drip from now on during really cold night just like the sink but set washer on DRAIN this will help. Good LUCK
Dec 07, 2008 | Kenmore 44042 Front Load Washer
Heating & Cooling Logo
137 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
