Question about Seagate Barracuda 7200.7 ST380011A 80 GB Hard Drive
Barracuda 7200.7 be used with NTFS drive?
Can Barracuda 7200.7 ATA/100 be used as second drive with NTFS drive? Can the drive be formatted? When during installation?
  • 98 Answers
Yes, it can be used that way. Do you already have an operating system installed on your first drive?
Disk can be formatted after installing operating system on the first disk or prior to installation if you intend to install the operating system on this disk.
Posted on Jan 16, 2009
After formatting my PC then also showing the hard disk failure error and telling to backup all programs. so what to do?
Buy a new hard drive, and start over.
www.newegg.com You want a 3.5 ATA (not SATA) hard drive somewhere around 500 GB 7200 RPM not 5400 RPM. Something like: http://www.newegg.com/Product/Product.aspx?Item=N82E16822136109
Jun 10, 2011 | Seagate Barracuda 7200.10 320 GB ATA-100...
I have a seagate external hard drive that I dropped, and now the blue light stays on, but the computer does not recognize it. is there a way to retrieve the info?
Are you using XP?
It should show up. Are yo sure you are plugged in correctly everywhere?
Check your device manager ...
Let me know if this works for you.
a
Sep 26, 2009 | Seagate USB 2.0 External Enclosure + 300GB...
Hard drive failure segate barracuda 7200.9 it is two disks raid striped is there any way to remove data from disk or any way to connect them to another machine as a slave
how about scanning and trying to repair the sectors with hirens boot cd. There is a utility on it called hd regenerator or something like that http://www.hiren.info/pages/bootcd. I think you have to download this cd from piratebay first. There is no download from his website.
Sep 14, 2009 | Seagate Barracuda 7200.10 / 500GB / 7200 /...
Firmware update for Seagate Barracuda 7200 10 80 gb ultra ATA. I got problem due to firmware detection. the firmware on the Hard disk said it going with type 3.AAC, but when I try to open with Sea tool, it...
Dear FixYa team,
Thx for your kind offering to me. I already call my friend to help me here. And he seems already found the solution. The problem was comes from USB cable malfuction, and I think it somehow affect the firmware detection. Gladly he can back up it again with another harddisk, just try to baiting it to make the firmware read. Now I'm still waiting for data recovery only. I'm so sorry that I can't use ur helps now, coz I needed it in hurry. Thx
Regards,
Angeliczone
Jun 26, 2009 | Seagate Barracuda 7200.10 - 80GB - 7200rpm...
Cloned full small drive to large drive now both full
You might have the option of Defragmenting it as some files might be unorganised and also by freeing some space on thee disk by simply some files and data which yo don't need or might have cloned themselves repeatedly, that is Duplication of a same file or data and/or multiple amount of files.And if you think that you simply don't need the files then in that case simply format it in the respective file system whichever might be compatible,say,cdfs,FAT32,NTFS, and so on.
Apr 03, 2009 | Seagate Barracuda 7200.9 500 GB ATA-100...
Seagate sata hdd error
Quick format removes files from the partition, but does not scan the disk for bad sectors, while a normal format does that. That's why the formatting takes so much longer.
You should definitely check your drive for bad sectors by issuing "chkdsk /r" in the command line, which scans for and attempts the recovery of bad sectors.
If there is a bad sector somewhere, your system might crash at any time and it might be at a very inconvenient moment.
If you find bad sectors, you should consider replacing the drive
Mar 02, 2009 | Seagate Barracuda 7200.10 ST3160815A -...
Seagate satat error
the firmware is damaged,sir,nothing can do.you should go to the dr company to repair your hdd first by using HD Doctor or other tools,it is a typical bug for 7200.11,seagate's big bug
Hard disk drive
try reading the hard disk drive myths....it may explain more.
http://www.techarp.com/showarticle.aspx?artno=84&pgno=1
Feb 04, 2009 | Seagate Barracuda 7200.10 - 250GB -...
Seagate barracuda + usb harddrive enclosure cant access hard dive
First, neither of the links work. The amazon shows a power adapter and the Seagate defaults to their home page. But I think I get the idea. You purchased a usb drive enclosure and a new hard drive and now it doesn't work.
The problem is that the hard drive has not been initiated, formatted or assigned a drive letter.
Plug in the drive
Click on the Start button
Right click on Computer
Select Manage
A screen opens, click on Disk Management
All the drives known and unknown will appear on the right.
Find the drive that says unknown, right click over the text and select Initialize Disk.
When done, right click the blank space to the right labelled Unallocated and select new simple volume then follow the steps to format and assign a drive letter.
If you are only going to be using this drive on this computer then format ntfs, if it maybe be connected to other devices including Mac, you may want to use fat32 or exfat.
Whats the Difference Between FAT32 exFAT and NTFS
Mar 01, 2017 | Seagate USB 2.0 External Enclosure + 300GB...
Seagate Barracuda 7200.7 160GB
You don' t say what OS or even type of computer (PC, Mac, Windows XP, 98, vista etc) you are running, or whether the drive has been used before. If it's a new drive then it probably needs formatting, so you can allow the OS to do that. If it contains data that you need then DO NOT allow the OS to format it.
If you know it is formatted & contains data, then it sounds like the OS is not recognising the format. Windows 98 typically won't recognise NTFS disks formatted on Windows XP for example or Linux Ext3/4 format disks won't be recognised by Windows. In the latter case, you can download a free driver which will do that for you - google Ext 4 and Windows.
Aug 26, 2008 | Seagate Barracuda 7200.7 160GB 7200rpm...
Seagate Barracuda 7200.7 ST380011A 80 GB Hard Drive Logo
95 people viewed this question
Top Seagate Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Computer Links
Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
