Question about Coby DVD-224 DVD Player
I have a coby dvd player which is connected to my home theatre sound system. However, i canot increase the volume to a satisfatory level past #20. the theatre sound system is at max volume.
    President:
  • 563 Answers
I work for Coby technical support. Our customer service phone number is 1-800-727-3592.
Unfortunately, there is no way to increase the output of the Coby dvd player within the player itself. It may be that the player isn't outputting very well through the audio coaxial output which i presume your using. If this is the case, there is no fix for that type of issue. You would want to replace the player.
If you feel this solution doesn't deserve a good rating, please let me know why so that I may better assist you. If there is anything more I can do to help, I will!
Posted on Feb 05, 2009
I have a phillips hts5560 home theatre system and im getting no sound through the speakers! I have tried everything the blue ray player workz but no sound at all through speakers can anyone help?
Hi Candice, Does your blue-ray DVD player have volume control as well as your television, I have blue-ray DVD with volume control as well as the television volume control.... I have the television volume turned up full and control the volume through my blue-ray DVD.... Hope this helps... CHEERS...
Apr 16, 2016 | home Audio Players & Recorders
Tip
How to set up a home theatre system ?
Considering a home theatre system, you will have to connect both the audio and the video cables of your home theatre system to your DVD player, so let us first start with the connection of the audio cable.
Step 1:Firstly you must find the digital output point on the back of your DVD player. It will be labelled as "COAXIAL" or "OPTICAL". Some of the DVD players may have both the Coaxial and the Optical output. In that case you must connect only either of them. Both the outputs require different kind of output cable. The Coaxial output uses a standard shielded RCA cable which is plugs in an RCA jack which is labeled "COAXIAL DIGITAL". The Optical output uses a fiber-optic cable which has a square shaped connector at both the ends. Both the outputs deliver almost the same quality of sound but the Optical cable sometimes allows us to prevent ground loops. Both these digital cables do not carry any video signals. Now connect either of these to the digital audio input which is at the rear of your reciever.
Step 2:Now you must connect the video cables. Before you start doing that you must decide if you want to connect the video cables through the A/V reciever and then connect it to the TV or just directly connect it to the TV. By connecting the wires to the A/V reciever and then to the TV usind two separate cables has its advantages in which you find convenience if you want to switch the reciever to watch a DVD and also you will be able to see the on-screen menu on your TV. By directly connecting the cable to the TV you will find it easier but again you would not be able to see the on-screen menu.
Most of the DVD players will have three video outputs. Connect all three of them inorder to recieve maximum video clarity from a DVD. It is necessary to have component outputs on your TV and/or your AM reciever inorder to connect all the three video outputs. In case you dont have an component output then you will have to connect only one s-video cable to your TV input. This s-video cable is a single cable with a multi pin plug. In case there is an component output for your TV. then you will require three cables(RCA) which have different colour codes(which are sometimes binded togethr). the colours are usualy Red , Green and White. Using the component output gives you the best video quality next to which is using the s-video output. The DVD player may also have an HDMI or DVI connectors. These help in maintaining the video in its digital form rather than converting it to anolog form.
Step 3: Make sure you dont turn the volume of your surround sound too high in which case any one of the speakers might call attention to themselves. In other words, in case the volume of the surround sound is too high then sometimes one of the speakers on your rear may call your attention separately. Hence it is recomended to keep the volume in its optimum level. Many of you might even wonder if the surround system is actually functioning properly until you experiance an of-screen sound such as a phone ringing at the backround or the sound o thunder in case of a rainstorm . Hence you must know that a surround system is not for loud noises and rather to experiance a three dimensional environment in between a movie.
There are certain things which you can do inorder to experiance a better feel using your surround sound system. Few of them are as follows,
1. It is advisable to get a test DVD which will help you adjust the surround sound levels and make maximum use of the system. For instance get a Sound and Vision magazine home theatre tune up DVD. IT will help you in maximizing the effects of the system.
2. Always remember to keep the central channel speakers setting at low. In case the setting is high then there is a loss of clarity of speech.
3. Try changing the seating arangements around the surround speaker system. Sometimes you might feel better audio quality at certain positions.
4. Always keep the brightness of the TV on optimum range. This is better for viewing more particular details in the picture quality as well as increases the life of the TV. Hence high brightness will reduce the life of the TV as well as give u less details on the picture being viewed.
5. Always have the volume of the sub-woofer at medium when you play music and then gradually increase it to how much ever necessary.
on Sep 12, 2010 | Audio Players & Recorders
Sony BDVE870 Low Volume
use equalizer to increase volume
May 19, 2012 | Sony Audio Players & Recorders
I have an old JCX TS750 Home theatre system.Is it possible to put the tv sound into the speakers. many thanks ...
Yes. Connect the audio from the cable box to the home theatre. Just change your function when u are watching tv to video 2 or where ever u plugged it in. Then turn your tv volume down and use volume on this sanyo
Jan 06, 2011 | Sanyo Televison & Video
Coby DVD765 Theater System and can't control the TV volume through it...I saw the previous post...We have it in our bedroom and rarely watch DVDs in there. Could I plug my RCA audio cables into some of...
The connections will have to go directly into your tv set. On your tv, you should have 3 connnecting points. Red, White and Yellow. On your Theatre system amplifier you should have audio outputs like CD, AUX, etc. Pick one of these outputs and connect to your Red and White RCA on the tv set. Next, connect the DVD player's audio to dvd on your amplifier under the DVD connection. Your VIDEO (yellow) Cable should still go to your tv directly from the DVD player. Now, if you want to listen to the TV channels throug the system, simply select the channel that you pluged the TV audio into. Hope this helps.
Jun 11, 2010 | Coby DVD765 Theater System
Panasonic home theatre keeps making a popping
try cleaning all your connections for your speakers with isopropyl alcohol and a q-tip, if no luck it could be an internal problem
Jan 09, 2010 | Panasonic Home Theater System System
Audiovox VD1400HT Home Theatre System. Volume of radio too loud. If Radio is set at 7 it is very loud, but a DVD requires at least 25 before you can hear it.
that is normal. different sources have different output levels.. increase volume at dvd player will also increase volume of you home theater..
cheers!
Jul 11, 2009 | Audio Players & Recorders
Is my tv audio doomed or will the home theatre system work anyways.
some devices these days have a built in volume control, try using your remote for which ever dvd player or satalite bix you use, on push the volume up button on it while you have the volume on the tv maxed out so that you will be able to tell a defference if it works or not.
Jun 02, 2009 | Philips HTS 6600/12 Home Theatre...
LG dvd player connected to 5.1 home theatre
Dont now your sytem but check Home theatre sytem must be switch to 5.1 display and not dvd display. if stil no sound check in setup off dvd for soundsetting like PCM, RAW , 5.1etc and select each one till you get desired sound.
Presume your conections from dvd to hometheater is conected 5.1 cables or 1 digital cable and not stereo(2cables)
Jan 05, 2009 | LG RH177 DVD Recorder/HDD Recorder
Home theatre but TV without audio outlet
I would suggest that you smash
Philips HTS w/a hammer!
I had better sound from TV alone! Only 2 speakers put out sound from TV. Recordings from DVR can not be heard very well w/all volumes at max. System sucks! You get what you pay for! $2500 LCD TV sounds worse w/Philips HTS than my son's $300 TV! ALL cables hooked up as instucted!!!!
Dec 17, 2007 | Audio Players & Recorders
Coby DVD-224 DVD Player Logo
83 people viewed this question
Top Coby Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Coby Televison and Video Expert? Answer questions, earn points and help others
