Question about Brother Sewing Machines
Clutch Release Problem
Model #XL2022
When I could not 'release knob' by turning toward me, to wind bobbin, I loosend the small screw on the knob. Threaded bobbin, but it is messy, and now cannot tighten the clutch release knob. Therefore cannot sew. Seems maybe screw is stripped???? Please help. I've seen a long time, and never had a problem with any sewing machine needing repair I could not do myself. Thank you for your prompt response! Kathy
Could not find this product number listed anywhere????
  • 323 Answers
You will need to remove the clutch release knob and the 3 eared positioner (the clutch) under that knob. Reposition the clutch on the shaft, put the knob back on and see if you can put the screw back in the hole. If it hits something, remove the knob, remove the clutch and turn it 180 degrees. This will reposition the ears. Put the clutch back on the shaft, put the knob back on the shaft and screw the screw into the hole. Test to be sure the knob releases the hand wheel to wind the bobbin.Be sure the thread is under the thread guide when you wind the bobbin and that there is a slight tension on it.
sewman7
Posted on Jan 17, 2009
How do I add thread to the bobbin
The small box you will turn towards you while you hold the big handwheel. It might me very tight but it isn't going to break by turning hard. Tighten the small screw before you begin. When it is loose you can wind your bobbin.
Feb 23, 2015 | Sewing Machines
The Balance Wheel and the Clutch Release knob will not tighten together again after filling a bobbin. How do I fix this?
THERE IS A SMALL SCREW AT THE MIDDLE KNOB ON THE HAND WHEEL THAT YOU NEED TO LOOSEN. AFTER THAT TIGHTEN THE HAND WHEEL KNOB JUST AS YOU WOULD WHEN YOU ARE GOING TO SEW. NOW, TIGHTEN THE SMALL SCREW. YOUR MACHINE SHOULD BE OK FOR SEWING AND YOUR BOBBIN WINDING.
Jan 07, 2015 | Brother Sewing Machines
Clutch stuck
Could be the release knob has simply been wound on too tightly. Normally the missing screw is there to prevent the knob being wound out too far and nothing to do with free motion of the balance wheel
Feb 11, 2014 | Brother Sewing Machines
Needle does not move when I try to sew.
On these old singers, there is a locking washer that controls the tighten and release mechanism. If it is not in the proper place your efforts to tighten and loosen to engage the sewing functions do nothing.
Aug 11, 2012 | Sewing Machines
How to wind bobbin on white 1418
1 Release the stop-motion knob on the right side of the sewing machine by turning it oward you.2 Place a spool of thread of your choice on the spool pin located toward the back of the sewing machine.3 Pull thread from the spool through the threading knob on the top of the machine.4 Pull 2 to 3 inches of thread through one of the holes on the bobbin. Hand-wrap thread around the bobbin in an anti-clockwise direction five or six times.5 Place the wrapped bobbin on the bobbin spindle.6 Push the winder spindle to the right, against the stopper, and depress the foot pedal to begin winding.7 Wind bobbin until completed, then return winder spindle to its original position.8 Tighten the stop-motion knob.
Oct 14, 2011 | White Sewing 1418 Mechanical Sewing...
The clutch on my kenmore 1310 won't disengage when i go to wind the bobbin. i turn the clutch knob toward me, and the clutch is still engaged.the machine needle continues to operate while i wind the bobbin
May be one of two problems.
1st you should be able to turn the nob about 90-120 degrees. Not a full turn.
If this is not the case follow these steps.
Turn the small screw on the nob about 2 full turns
Carefully turn the nob all the way off.
Inside there is a round part with 3 small prongs on it.
spin that 180 degree and put everything back together.
2nd your clutch is gummed up
You will need to remove the handwheel and motor belt for this.
Remove the nob, small 3 prong part, and motor belt.
Pull the handwheel off (it may be stuck on and hard to get off).
Clean inside the handwheel and the machine main shaft.
Lubricate the Main shaft and put handwheel back on.
When you put the small 3 prong part back on it needs to have the prongs sticking away from the machine.
Hope this fixes your machine
Apr 06, 2011 | Kenmore Sewing Machines
On my Kenmore 15250 sewing machine to wind the bobbin I need to release the clutch by turning clutch knob towards me, so says the instructions booklet. But the clutch knob does not move apart from the...
On my Kenmore I had to pull the knob out to release the clutch, then push it bak in. I don't know if that is the same for you. You can try it, if it doesn;t move, it was worth a try. You could just take to Sears, sewing machine department and ask the salesperson what to do, they should help you for free, our Sears is pretty good about such matters.
Sep 13, 2010 | Kenmore 15208 Mechanical Sewing Machine
Can't tighten clutch on Kenmore zig zag sewing machine.
The clutch has fallen off the shaft. Remove the very small screw in the clutch release screw to remove the clutch release. Place the clutch(round thing with ears on it) back on the shaft with the center ears pointing towards the outside. Put the clutch release screw back on. Tighten it to make sure it works
properly. Put the small screw back in the clutch release screw and test it again. If it will not tighten or release properly, remove the clutch ,rotate it180 degrees and try it again.This should solve your problem.
sewman7
Feb 14, 2009 | Kenmore 15516 Mechanical Sewing Machine
Winding the bobbin?
Most of the entry level machines will have either a clutch knob or an automatic release when the bobbin winder mechanizm is engaged (put a bobbin on and more the unit to you right). If it does not disengage the clutch automaticly then either loosen the clutch wheel by turing or pulling. Sometines you have to grab the whole clutch wheel to disenage the mechanism to free wheel while winding the bobbin. Now press you foot control to wind the bobbin.
SewTech
Apr 21, 2008 | Janome Mini Compact
Kenmore Sewing Machine model # c877.15
I have a Kenmore as well ,I hope that this will work for you ,too bad that I don't live close to you otherwise I would give a hand. This is the way I fill the bobbin on mine. Mine is located on the top right ,I put the thread into the bobbin hole leaving a small piece of thread hanging for me to hold when I begin the winding, I pull the wheele out to stop the needle from moving while winding, when I am done just push it back in .I run the thread from the spool into the top left it looks like a U turn with a screw go around that without winding just pull it into the bobbin hole. press the foot control and it will begin winding .
Jul 17, 2007 | Kenmore 15208 Mechanical Sewing Machine
Sewing Machines Logo
593 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
