Question about AMD Sempron 2400+, 1.667 GHz (sda2400box) Processor in a Box (PIB)
Pc keeps freezing PLEASE HELP
Its gets jittery like windows media player starts skipping the song then the mouse gets skippy then total lockdown please help my computer is my life is as vital as an organ
  • 883 Answers
Step 1: clean up your drive by using "left click desktop My Computer icon-hover drive c then right click and select Properties-look for Disk Cleanup button and select it and proceed to eliminate almost everything that you can. step 2: Then select TOOLS tab and run Error Checking and deselect both optionals then run Defrag. When done, then run Start-All Programs-Accessories-System tools-System restore and then turn off Restore. step 3: Now repeat step 1. step 4: Now repeat step 2 but turn on restore. step 5: power down (using Windows-not power plug). step 6: restart Windows if all worked ok, what you just accomplished was to free up many many bytes of data. The restore function, when used continuously, can use up a sizable portion of the drive which is also looking for free virtual memory space. Also, if you have 1Gbyte of memory or more, you may turn virtual memory off, improving speed.
Posted on Jun 19, 2007
  • Marty marty Jun 19, 2007
    PS: if no noticeable improvements, then re-run entire sequence above except for step 2:"run Error Checking and deselect both optionals" change to "run Error Checking and SELECT both optionals" to check for bad drive sectors.
Live tv skips in media center
no this has no effect. Usually jittery audio is hard drive or resource related as it is writing data and outputting data at the same time.
one reolution may be to scale down the quality of the recording to see if that helps.
Lastly check for updated audio/capture card drivers
Jan 18, 2009 | Microsoft Windows XP Media Center Edition...
Cant download music from windows media to mp3 player
do not open window media ....go to my computer...open the folder that has all of mp3 files (on pc)...now plug up your mp3 player....go to start/ my computer (yes another window)/do you see a new icon/drive (it should be the mp3)...open it.....now resize both windows so that they side by side (or top & bottom)..now click & drag (or copy and paste) all the songs you want from pc folder to the mp3 .....once you are finish do not .........do not just unplug the mp3 player....go to the task bar (your lower left) and look to safely remove this device....hope this help....have fun
Dec 29, 2008 | GPX ML848B Digital Media Player
Songs skip mid tune? not ev song but enuf 2drive u nuts
Update the firmware.
Reload the songs.
If the problem persists:
Re-rip the CD songs in Mp3 format in Windows Media Player
Then reload the songs. WMA format has a checkable option that is normally turned off by default, but must be turned on inside your Windows Media Player - it is much easier to reconvert the songs into Mp3 format than to tell you how to change this WMA option.
-Tha Mp3 doctor
Dec 16, 2008 | Philips SA6025 Digital Media Player
Skipping songs
i bought new songs on itunes and i got a notice when i was syncing my ipod that said "the file or directory is corrupted and unreadable" and now my ipod skips over the songs i just bought.
May 10, 2008 | Apple iPod MP3 Player
Sandisk keeps skipping/freezing songs!
Try this: disconnect the player from the computer, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/Retail/DriverDownloads.aspx
or
http://www.sandisk.com/DriverDownload/driverList.asp
-Tha Mp3 Doctor
Apr 13, 2008 | SanDisk Sansa E280 MP3 Player
Craig MP3 player
1) Disconnect from computer, turn it off, hold in volume + button and reconnect it to your computer - continue holding volume + until the Found Hardware Wizard comes up.
2)
REFORMAT FOR WINDOWS MEDIA PLAYER - Erases Everything: Connect your iLo player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "ILO 2GB" (wording may vary slightly), and then select "Format." - this should erase everything, and give you a fresh start.
Feb 07, 2008 | iLO (2 GB) MP3 Player
Re my downloaded songs skip one or two they play fine, but all donot play
You need to renew your Rhapsody sub, and re-sync in Rhapsody
Jan 25, 2008 | SanDisk Sansa m230 MP3 Player
Can't delete songs on my SanDisk m230 MP3 Player
Disable Auto-Sync in Windows Media Player before trying any other method.
These are the most common methods for recovering Sandisk's Sansa Mp3 Players. I have been almost universally successful in recovering Sansa players using one or a combination of these methods. These methods do not work if you are having synchronization or music format issues - they are for recovering a player that will not power up, freezes, flashes, is not recognized by the computer, and a host of other issues.
Reset the Sansa Player first. On most models, restart is done by holding the power button in for 15 seconds or longer. Check your specific manual to be sure. The manuals are available from the Sansa website if they have been misplaced.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/DriverDownload/driverList.asp
If these fail, then:
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If you get the problem where MTP Device keeps popping up continuously, uninstall the “MTP Device” by going to Start à Control Panel àSystem à Hardware à Device Manager (you computer may vary slightly, depending on Windows Version).
You may have to restart your computer after each of these methods to get them to work properly. Disconnect your Sansa player BEFORE shutting down your computer.
-Tha Mp3 Doctor
Nov 02, 2007 | SanDisk Sansa m230 MP3 Player
Phantom Songs on my Sansa e250
Use Windows Media Player to delete, or double-check the format of those songs
Feb 04, 2007 | SanDisk Sansa e250 MP3 Player
Skipping songs
Just find the songs details, and unclick skip when shuffle!! OR Windows media player 10 and 11, are almost the same, I use both, and I don't really know the difference. Go to start, click contrl panel, then change or remove programmes. Go to windows media player 11, and press delete! It won't delete it, it will change it back to windows media 10!!
Dec 30, 2006 | Samsung Yepp YP-Z5AB / YP-Z5AS MP3 Player
AMD Sempron 2400+, 1.667 GHz (sda2400box) Processor in a Box (PIB) Logo
97 people viewed this question
Top AMD Computers & Internet Experts
Alun Cox
pankaj rautela
pankaj rautela
Computer Links
Are you an AMD Computer and Internet Expert? Answer questions, earn points and help others
